如圖是電路原理圖如下:
單片機(jī)源程序如下:
- * 【外部晶振】: 11.0592mhz
- * 【主控芯片】: STC89C52
- * 【編譯環(huán)境】: Keil μVisio3
- * 【程序功能】: LCD1602顯示DS1302時(shí)鐘 ,按鍵可以調(diào)
- * 【使用說明】: 液晶1腳接1602黑色排母的1腳 如果是無背光的液晶只有14個(gè)腳 排母右邊空2個(gè)位
- 請把液晶對比度電位器順時(shí)針調(diào)制10點(diǎn)鐘方向,請勿多調(diào)超出極限位置會損壞電位器!
- 使用前是用杜邦線分別把DS1302旁邊3個(gè)腳的排針與P1口的0~2接相接
- 接線方式是 請看開飯背面有絲印
- TSCLK - P10
- TIO - P11
- TRST - P12
- -------------------------------調(diào)節(jié)時(shí)鐘--------------------------------------------
- 按下S2依次選擇秒分時(shí)、星期日月年,S3 加,S4減
- * 說明:免費(fèi)開源,不提供源代碼分析.
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar a,miao,shi,fen,ri,yue,nian,week,flag,temp,key1n;
- uchar ge,shi,bai,qian;
- #define yh 0x80 //第一行的初始位置
- #define er 0x80+0x40 //第二行初始位置
- #define keyport P2
- //sbit dula=P2^6;
- //sbit wela=P2^7;
- bit f_systick_1ms=0;
- bit f_systick_2ms=0;
- uchar cnt_systick_2ms=0;
- bit f_systick_4ms=0;
- uchar cnt_systick_4ms=0;
- bit f_systick_10ms=0;
- uchar cnt_systick_10ms=0;
- uchar cnt_systick_101ms=0;
- bit f_systick_505ms=0;
- uchar cnt_systick_505ms=0;
- bit f_systick_1s=0;
- uchar cnt_systick_1s=0;
- uchar data current_Event = 0;
- bit flag_Alarm_blink;
- bit swatch_Start_Flag = 0; //秒表計(jì)時(shí)開始標(biāo)致位
- sbit wr=P1^1;
- sbit rs=P1^0;
- sbit en=P1^2;
- sbit SCLK=P3^5;
- sbit IO=P3^6;
- sbit RST=P3^7;
- sbit ACC0=ACC^0;
- sbit ACC7=ACC^7;
- sbit key=P2^0;
- sbit key1=P2^1;
- sbit key2=P2^2;
- sbit key3=P2^3;
- uchar keyvalue=0;
- uchar code tab1[]={" - - "};
- uchar code tab2[]={" : : "};
- uchar code tab3[]={"SWITCH"};
- void delay(uint xms)//延時(shí)函數(shù)
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- /*************定時(shí)器T0的初始化********************/
- void Timer1_Init(void)
- TMOD=0x11; //T1定時(shí)器工作方式1
- TH1=0xfc; //1ms初值
- TL1=0x18;
- ET1=1; //開定時(shí)器T0中斷
- EA=1; //開總中斷
- // TR1=1; //啟動定時(shí)器T0
- /****************T0定時(shí)器中斷*********************/
- void ISR_T1(void) interrupt 3 //1ms中斷
- TH1=0xfc;
- TL1=0x18; //重裝1ms中斷
- f_systick_1ms=1; //1ms時(shí)基標(biāo)志位
- /*****************時(shí)基處理函數(shù)**********************/
- void SysTick_intgnd(void)
- if(f_systick_1ms==1)
- f_systick_1ms=0;
- cnt_systick_2ms++;
- if(cnt_systick_2ms==2)
- cnt_systick_2ms=0;
- f_systick_2ms=1; //按鍵掃描標(biāo)志位
- cnt_systick_4ms++;
- if(cnt_systick_4ms==4)
- cnt_systick_4ms=0;
- f_systick_4ms=1; //數(shù)碼管掃描標(biāo)志位
- cnt_systick_10ms++;
- if(cnt_systick_10ms==10)
- cnt_systick_10ms=0;
- f_systick_10ms=1;
- cnt_systick_1s++;
- if(cnt_systick_1s==100)
- cnt_systick_1s=0;
- f_systick_1s=1; //時(shí)鐘1s更新一次標(biāo)志位
- cnt_systick_101ms++;
- if(cnt_systick_101ms==101)
- cnt_systick_101ms=0;
- flag_Alarm_blink = ~ flag_Alarm_blink; //鬧鐘報(bào)警標(biāo)志位
- cnt_systick_505ms++;
- if(cnt_systick_505ms==5)
- cnt_systick_505ms=0;
- f_systick_505ms=1;
- /******************液晶寫入************************/
- write_1602com(uchar com)//液晶寫入指令函數(shù)
- rs=0;//置為寫入命令
- P0=com;//送入數(shù)據(jù)
- delay(1);
- en=1;//拉高使能端
- delay(1);
- en=0;//完成高脈沖
- write_1602dat(uchar dat)
- rs=1;//置為寫入數(shù)據(jù)
- P0=dat;//送入數(shù)據(jù)
- delay(1);
- en=1;
- delay(1);
- en=0;
- /*********************over***********************/
- /********************ds1302****************************/
- void write_byte(uchar dat)
- ACC=dat;
- RST=1;
- for(a=8;a>0;a--)
- IO=ACC0;
- SCLK=0;
- SCLK=1;
- ACC=ACC>>1;
- uchar read_byte()
- RST=1;
- for(a=8;a>0;a--)
- ACC7=IO;
- SCLK=1;
- SCLK=0;
- ACC=ACC>>1;
- return (ACC);
- void write_1302(uchar add,uchar dat)
- RST=0;
- SCLK=0;
- RST=1;
- write_byte(add);
- write_byte(dat);
- SCLK=1;
- RST=0;
- uchar read_1302(uchar add)
- uchar temp;
- RST=0;
- SCLK=0;
- RST=1;
- write_byte(add);
- temp=read_byte();
- SCLK=1;
- RST=0;
- return(temp);
- uchar BCD_Decimal(uchar bcd)
- uchar Decimal;
- Decimal=bcd>>4;
- return(Decimal=Decimal*10+(bcd&=0x0F));
- void ds1302_init()
- RST=0;
- SCLK=0;
- write_1302(0x80,miao|0x00);//允許寫
- void write_sfm(uchar add,uchar dat)//寫時(shí)分秒
- uchar gw,sw;
- gw=dat%10;
- sw=dat/10;
- write_1602com(er+add);
- write_1602dat(0x30+sw);
- write_1602dat(0x30+gw);
- void write_nyr(uchar add,uchar dat) //寫年月日
- uchar gw,sw;
- gw=dat%10;
- sw=dat/10;
- write_1602com(yh+add);
- write_1602com(yh+6);
- void write_week(uchar week)//寫星期函數(shù)
- write_1602com(yh+0x0d);
- switch(week)
- case 1:write_1602dat('M');//delay(5);
- write_1602dat('O');//delay(5);
- write_1602dat('N');
- break;
- case 2:write_1602dat('T');//delay(5);
- write_1602dat('U');//delay(5);
- write_1602dat('E');
- break;
- case 3:write_1602dat('W');//delay(5);
- write_1602dat('E');//delay(5);
- write_1602dat('D');
- break;
- case 4:write_1602dat('T');//delay(5);
- write_1602dat('H');//delay(5);
- break;
- case 5:write_1602dat('F');//delay(5);
- write_1602dat('R');//delay(5);
- write_1602dat('I');
- break;
- case 6:write_1602dat('S');//delay(5);
- write_1602dat('T');//delay(5);
- write_1602dat('A');
- break;
- case 7:write_1602dat('S');//delay(5);
- break;
- lcd_init()//液晶初始化函數(shù)
- { wr=0;
- write_1602com(0x38);//設(shè)置液晶工作模式
- write_1602com(0x0c);//開顯示不顯示光標(biāo)
- write_1602com(0x06);//整屏不移動,指針加一
- write_1602com(0x01);
- delay(10);
- // write_1602com(yh+2);//字符寫入的位置
- // for(a=0;a<14;a++)
- // write_1602dat(tab1[a]);
- // //delay(3);
- // write_1602com(er+4);
- // for(a=0;a<8;a++)
- // write_1602dat(tab2[a]);
- // //delay(3);
- void keyscan()
- //key=0;
- if(key==0)
- delay(5);
- if(key==0)
- TR0=0;
- TR1=0;
- delay(1);
- if(keyvalue==2)
- keyvalue=0;
- keyvalue++; //設(shè)置菜單界面
- switch(keyvalue)
- case 0:
- case 1: //鐘表
- TR0=1;TR1=0;
- if(key1==0)//key1為功能鍵
- delay(5);
- if(key1==0)
- TR0=0;
- TR1=0;
- while(!key1);
- key1n++;
- if(key1n==9)
- key1n=1;
- switch(key1n)
- case 1:
- TR0=0; //關(guān)閉定時(shí)器
- TR1=0;
- write_1602com(er+0x0b);//寫入光標(biāo)位置
- delay(5);
- write_1602com(0x0f);//設(shè)置光標(biāo)為閃爍
- delay(5);
- temp=(miao)/10*16+(miao)%10;
- write_1302(0x8e,0x00);
- write_1302(0x80,0x80|temp);//miao
- write_1302(0x8e,0x80);
- break;
- case 2:
- TR1=0;
- write_1602com(er+8);//fen
- //write_1602com(0x0f);
- break;
- case 3:
- TR1=0;
- write_1602com(er+5);//shi
- break;
- case 4:
- TR1=0;
- write_1602com(yh+0x0f);//week
- break;
- case 5:
- TR1=0;
- write_1602com(yh+0x0b);//ri
- break;
- case 6:
- TR1=0;
- write_1602com(yh+0x08);//yue
- break;
- case 7:
- TR1=0;
- write_1602com(yh+0x05);//nian
- break;
- case 8:
- write_1602com(0x0c);//設(shè)置光標(biāo)不閃爍
- TR0=1;//打開定時(shí)器
- write_1302(0x80,0x00|temp);//miao
- break;
- if(key1n!=0)//當(dāng)key1按下以下。再按以下鍵才有效
- if(key2==0) //上調(diào)鍵
- delay(5);
- if(key2==0)
- while(!key2);
- switch(key1n)
- case 1:miao++;
- if(miao==60)
- miao=0;
- write_sfm(0x0a,miao);//寫入新的秒數(shù)
- write_1602com(er+0x0b);//因?yàn)樵O(shè)置液晶的模式是寫入數(shù)據(jù)后,指針自動加一,在這里是寫回原來的位置
- //write_1602com(0x0b);
- break;
- case 2:fen++;
- if(fen==60)
- fen=0;
- write_sfm(0x07,fen);
- temp=(fen)/10*16+(fen)%10;
- write_1302(0x82,temp);
- break;
- case 3:shi++;
- if(shi==24)
- shi=0;
- write_sfm(4,shi);
- temp=(shi)/10*16+(shi)%10;
- write_1302(0x84,temp);
- break;
- case 4:week++;
- if(week==8)
- week=0;
- write_week(week);
- break;
- case 5:ri++;
- if(ri==31)
- ri=0;
- write_nyr(10,ri);
- temp=(ri)/10*16+(ri)%10;
- write_1302(0x86,temp);
- write_1602com(yh+11);
- break;
- case 6:yue++;
- if(yue==13)
- yue=0;
- write_nyr(7,yue);
- temp=(yue)/10*16+(yue)%10;
- write_1302(0x88,temp);
- write_1602com(yh+8);
- break;
- case 7:nian++;
- if(nian==100)
- nian=0;
- write_nyr(4,nian);
- write_1602com(yh+5);
- break;
- } //switchkeyln
- }//key2
- if(key3==0)
- delay(5);
- if(key3==0)
- while(!key3);
- switch(key1n)
- case 1:miao--;
- if(miao==-1)
- miao=59;
- break;
- case 2:fen--;
- if(fen==-1)
- fen=59;
- write_sfm(7,fen);
- break;
- case 3:shi--;
- if(shi==-1)
- shi=23;
- write_sfm(4,shi);
- break;
- case 4:week--;
- if(week==-1)
- week=7;
- write_week(week);
- break;
- case 5:ri--;
- if(ri==-1)
- ri=30;
- write_nyr(10,ri);
- break;
- case 6:yue--;
- if(yue==-1)
- yue=12;
- write_nyr(7,yue);
- break;
- case 7:nian--;
- if(nian==-1)
- nian=99;
- break;
- } //switchkeyln
- } //key3
- }//case1 菜單
- break;
- case 2:
- static uint data count;
- TR0=0;TR1=1;
- SysTick_intgnd();
- if(key1==0)//秒表計(jì)時(shí)開始
- delay(5);
- if(key1==0)
- delay(1);
- swatch_Start_Flag =1;
- if(key2==0)//秒表計(jì)時(shí)結(jié)束
- delay(5);
- if(key2==0)
- swatch_Start_Flag =0;
- if(key3==0)//復(fù)位
- delay(5);
- if(key3==0)
- count=0;
- if(swatch_Start_Flag ==1)
- if(f_systick_10ms == 1) //產(chǎn)生跑秒
- f_systick_10ms = 0;
- count++;
- if(count==9999) count = 0;
- ge=count%10;
- shi=count/10%10;
- bai=count/100%10;
- qian=count/1000;
- // lcd_init();
- write_1602com(yh+3);
- write_1602dat(ge+0x30);
- write_1602com(yh+2);
- write_1602dat(shi+0x30);
- write_1602com(yh+1);
- write_1602dat(bai+0x30);
- write_1602com(yh+0);
- write_1602dat(qian+0x30);
- break;
- void init()
- TMOD=0x11;
- TH0=0;
- TL0=0;
- EA=1;
- ET0=1;
- //TR0=1;
- //void cmg(void)//數(shù)碼管鎖存函數(shù)
- //dula=1;
- //P0=0x00;
- //dula=0;
- //wela=1;
- //P0=0x00;
- //wela=0;
- void timer0() interrupt 1
- miao = BCD_Decimal(read_1302(0x81));
- fen = BCD_Decimal(read_1302(0x83));
- shi = BCD_Decimal(read_1302(0x85));
- ri = BCD_Decimal(read_1302(0x87));
- yue = BCD_Decimal(read_1302(0x89));
- nian=BCD_Decimal(read_1302(0x8d));
- week=BCD_Decimal(read_1302(0x8b));
- //keyscan();
- write_sfm(10,miao);
- write_1602com(er+0x09);
- write_1602dat(':');
- write_sfm(7,fen);
- write_1602com(er+0x06);
- write_sfm(4,shi);
- write_1602com(yh+0x06);
- write_1602dat('-');
- write_nyr(10,ri);
- write_nyr(7,yue);
- write_1602com(yh+0x09);
- write_week(week);
- void main()
- // cmg();//數(shù)碼管鎖存
- lcd_init();
- ds1302_init();
- init();
- Timer1_Init();
- SysTick_intgnd();
- while(1)
- //TH0=(65536-60000)/256;
- //TL0=(65536-60000)%256;
- // if(f_systick_1ms==1)
- // timer0();
- keyscan();
【實(shí)驗(yàn)104】DS1302時(shí)鐘顯示.rar
(294.79 KB, 下載次數(shù): 17)
2019-6-2 14:34 上傳
點(diǎn)擊文件名下載附件
