發一個基于stm32F103的MPU6050 dma算法。詳情請下載。iar文件。共同學習。
#include "include.h"
static signed char gyro_orientation[9] = {-1, 0, 0,
0,-1, 0,
0, 0, 1};
float q0=1.0f,q1=0.0f,q2=0.0f,q3=0.0f;
float Pitch,Roll,Yaw;
unsigned long sensor_timestamp;
short gyro[3], accel[3], sensors;
unsigned char more;
long quat[4];
//下面四個函數對接dmp庫
//addr:器件slave_address
//reg :從器件將要寫入數據的首地址
//len :寫入數據的長度
//data:將要寫入的一串數據
u8 I2C_Write_Buffer(u8 addr, u8 reg, u8 len, u8 * data)
int i;
I2C_Start();
I2C_Send_Byte(addr << 1 | 0);//7位器件從地址+讀寫位
if (I2C_Wait_Ack())
I2C_Stop();
return 0;
I2C_Send_Byte(reg);
I2C_Wait_Ack();
for (i = 0; i < len; i++)
I2C_Send_Byte(*data);
if (I2C_Wait_Ack())
I2C_Stop();
return 0;
data++;
I2C_Stop();
return 1;
//reg :從器件將要讀的數據的首地址
//len :讀出數據的長度
//buf :將要讀出的數據存儲位置
u8 I2C_Read_Buffer(u8 addr, u8 reg, u8 len, u8* buf)
I2C_Start();
if (I2C_Wait_Ack())
I2C_Stop();
return 0;
I2C_Send_Byte(reg);
I2C_Wait_Ack();
I2C_Start();
I2C_Send_Byte(addr << 1 | 1);
I2C_Wait_Ack();
while (len)
*buf = I2C_Read_Byte();
if (len == 1)
I2C_NAck();
I2C_Ack();
buf++;
len--;
I2C_Stop();
return 1;
//返回值 0:讀成功
// -1:讀失敗
int I2C_Read(u8 addr, u8 reg, u8 len, u8 *buf)
if(I2C_Read_Buffer(addr,reg,len,buf))
return 0;
return -1;
//返回值 0:寫成功
// -1:寫失敗
int I2C_Write(u8 addr, u8 reg, u8 len, u8* data)
if(I2C_Write_Buffer(addr,reg,len,data))
return 0;
return -1;
void MPU6050_Init(void)
int result=0;
I2C_Init_IO();
result=mpu_init();
if(!result)
if(!mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL)) //mpu_set_sensor
if(!mpu_configure_fifo(INV_XYZ_GYRO | INV_XYZ_ACCEL)) //mpu_configure_fifo
if(!mpu_set_sample_rate(DEFAULT_MPU_HZ)) //mpu_set_sample_rate
if(!dmp_load_motion_driver_firmware()) //dmp_load_motion_driver_firmvare
if(!dmp_set_orientation(inv_orientation_matrix_to_scalar(gyro_orientation))) //dmp_set_orientation
if(!dmp_enable_feature(DMP_FEATURE_6X_LP_QUAT | DMP_FEATURE_TAP |
DMP_FEATURE_ANDROID_ORIENT | DMP_FEATURE_SEND_RAW_ACCEL | DMP_FEATURE_SEND_CAL_GYRO |
DMP_FEATURE_GYRO_CAL)) //dmp_enable_feature
if(!dmp_set_fifo_rate(DEFAULT_MPU_HZ)) //dmp_set_fifo_rate
run_self_test(); //??
if(!mpu_set_dmp_state(1));
void MPU6050_Pose(void)
dmp_read_fifo(gyro, accel, quat, &sensor_timestamp, &sensors,&more);
if(sensors & INV_WXYZ_QUAT )
q0 = quat[0] / q30;
q1 = quat[1] / q30;
q2 = quat[2] / q30;
q3 = quat[3] / q30;
Pitch = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; // pitch
Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; // roll
Yaw = atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * 57.3; //yaw
//通用定時器中斷初始化
//這里時鐘選擇為APB1的2倍,而APB1為36M
//arr:自動重裝值。
//psc:時鐘預分頻數
//這里使用的是定時器2!
void Timer2_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //時鐘使能
TIM_TimeBaseStructure.TIM_Period = arr; //設置在下一個更新事件裝入活動的自動重裝載寄存器周期的值 計數到5000為500ms
TIM_TimeBaseStructure.TIM_Prescaler =psc; //設置用來作為TIMx時鐘頻率除數的預分頻值 10Khz的計數頻率
TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設置時鐘分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計數模式
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根據TIM_TimeBaseInitStruct中指定的參數初始化TIMx的時間基數單位
TIM_ITConfig(TIM2,TIM_IT_Update ,ENABLE );//使能或者失能指定的TIM2中斷
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //TIM3中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占優先級1級
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //從優先級3級
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根據NVIC_InitStruct中指定的參數初始化外設NVIC寄存器
TIM_Cmd(TIM2, ENABLE); //使能TIMx外設
//定時器2中斷服務程序
//void TIM2_IRQHandler(void)
// if(TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //溢出中斷
// MPU6050_Pose();
// TIM_ClearITPendingBit(TIM2, TIM_IT_Update); //清除TIMx的中斷待處理位:TIM 中斷源
iic.rar
2019-6-2 11:29 上傳
下載積分: 黑幣 -5
1.31 KB, 下載次數: 8, 下載積分: 黑幣 -5
MPU6050.rar
2019-6-2 11:29 上傳
下載積分: 黑幣 -5
2.47 KB, 下載次數: 7, 下載積分: 黑幣 -5
MPU6050_DMP.rar
2019-6-2 11:29 上傳
下載積分: 黑幣 -5
35.2 KB, 下載次數: 17, 下載積分: 黑幣 -5
