2019-6-2 05:27 上傳
里面有三種方式實現(xiàn)LED呼吸燈,還有計算器,秒表
- #include <REGX51.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define PIN0 P0 //數(shù)碼管段選端
- sbit LSA=P2^2; //38譯碼器數(shù)碼管位選
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit beep = P1^5;
- sbit start=P3^2; //啟動/暫停按鈕
- sbit reset=P3^3; //復(fù)位按鈕
- uint cnt=0; //1s的次數(shù)的計數(shù)值
- uint num=0; //進(jìn)入中斷次數(shù)的計數(shù)值(一次50ms)
- uint num1=0; //0.1s的次數(shù)的計數(shù)值
- uint num2=0;
- uchar code table[]={0x3f,0x06,0x5b,
- 0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f};
- //不帶小數(shù)點的共陰極數(shù)碼管段碼0-9
- uchar code table1[]={0xbf,0x86,
- 0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
- //帶小數(shù)點的共陰極數(shù)碼管段碼0-9
- //<span style="font-size:14px;">
- char code table2[]={0xc0,0xf9,0xa4,
- 0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- //不帶小數(shù)點的共陽極數(shù)碼管段碼0-9
- void Display(uint w,uint a,uint b,uint c,uint d); //聲明顯示函數(shù)
- void InitTimer0(); //聲明定時器初始化函數(shù)
- void Delayms(uint x); //聲明延時函數(shù)
- void main()
- uint ms100=0;uint ms10=0; //秒的十分位
- uint s,s1,min,minu=0;
- //依次是秒的個位,秒的十位,分的個位,分的十位
- InitTimer0(); //初始化定時器
- while(1) //進(jìn)入死循環(huán)
- if(start==0) //檢測啟動/暫停鍵是否按下
- Delayms(20); //延時消抖
- if(start==0) //消抖之后再次檢測
- TR0=~TR0; //定時器的控制位取反
- while(!start); //等待按鍵釋放
- if(reset==0) //檢測復(fù)位鍵是否按下
- if(reset==0) //消抖之后再次檢測
- num=0;
- num1=0; //進(jìn)入中斷次數(shù)值清0
- ms100=0;
- ms10=0; //十分位的計數(shù)值清0
- cnt=0; //秒的計數(shù)值清0
- minu=0; //分的計數(shù)值清0
- while(!reset); //等待按鍵釋放
- if(num1>=2) //檢測是否達(dá)到0.1s,(兩個50ms)
- num1=0; //進(jìn)入中斷次數(shù)值清零
- ms10++;
- if(num2>=20)
- ms10=0;
- ms100++;
- num2=0;
- } //秒的十分位的計數(shù)值加1
- if(ms100>=10) //若秒的十分位計數(shù)值達(dá)到10
- ms100=0; //清零秒的十分位的計數(shù)值
- num1=0;//</span><span style="font-size:14px;"> </span><span style="font-size:14px;">//進(jìn)入中斷次數(shù)值置0
- if(num>=200) //判斷計時時間是否達(dá)到1s(20個50ms)
- num=0; //進(jìn)入中斷次數(shù)值置0
- cnt++;
- switch(cnt)//判斷是否達(dá)到60s
- case 5: beep=~beep;
- beep=~beep;
- Delayms(2);beep=~beep;
- Delayms(2); break;
- } //秒的計數(shù)值加1
- if(cnt>=60) //判斷是否達(dá)到60s
- cnt=0; //若達(dá)到60s,將秒的計數(shù)值置零
- minu++;
- if(minu>=60) //判斷是否達(dá)到60分鐘,一般秒表是用不到60分的,這是為了程序的嚴(yán)謹(jǐn)性
- TR0=!TR0; //達(dá)到60分鐘則關(guān)閉定時器并清零所有的計數(shù)值
- num1=0;//
- num=0;
- ms100=0;
- cnt=0;
- minu=0;
- s=cnt%10; //從秒的計數(shù)值里面分離秒的個位
- s1=cnt/10; //從秒的計數(shù)值里面分離秒的十位
- min=minu%10; //從分的計數(shù)值里面分離分的個位
- Display(ms100,s,s1,min,ms10); //顯示這5個數(shù)
- void InitTimer0() //定時器初始化函數(shù)
- TMOD=0x01; //選擇定時器0的工作方式1
- TH0=(65536-5000)/256; //裝初值(定時50ms),晶振11.0592MHz
- TL0=(65536-5000)%256;
- EA=1; //打開總中斷
- ET0=1; //打開定時器中斷
- TR0=0; //先不要啟動定時器
- void TIMER0() interrupt 1 //定時器中斷服務(wù)函數(shù)
- TH0=(65536-5000)/256; //重裝初值
- num++; //讓進(jìn)入中斷次數(shù)值加1,用于判斷是否達(dá)到1s
- num1++;
- num2++; //讓進(jìn)入中斷次數(shù)值加1,用于判斷是否達(dá)到0.1s
- void Delayms(uint x) //延時xms
- uint i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void Display(uint w,uint a,uint b,uint c,uint d) //定義顯示函數(shù)
- LSA=0; LSB=0; LSC=0; PIN0=table[d];
- LSA=1; LSB=0; LSC=0;PIN0=table[w]; //秒的十分位的段選
- Delayms(5);
- LSA=0; LSB=1; LSC=0;
- PIN0=table[a]; //秒的個位的段選
- Delayms(5);
- LSA=1; LSB=1; LSC=0;
- PIN0=table[b]; //秒的十位的段選
- Delayms(5);
- LSA=0; LSB=0; LSC=1;
- PIN0=table[c]; //分的個位的段選(帶小數(shù)點)
- //分的個位的位選
- Delayms(5);
單片機.7z
(31.15 KB, 下載次數(shù): 28)
2019-6-2 05:29 上傳
下載積分: 黑幣 -5
