查看: 2251|回復(fù): 0
這個示波器程序的ad標(biāo)度變換是啥
這是程序
#include <STC12c5a.H>
#include<intrins.h>
#include<math.h>
sbit RS=P0^7;
sbit RW=P0^6;
sbit E=P0^5;
sbit jiakey=P3^0;
sbit jiankey=P3^1;
#define  LcdData P2
unsigned char dati=0;
unsigned char dat[100];
unsigned char over=0;
unsigned int temp=0;
unsigned char mode=0;
unsigned int delnop=0;
unsigned char Lcd_CheckBusy(void)
    unsigned char Busy;
         LcdData=0xff;
    RS=0;
    RW=1;
    E=1;
    _nop_();
    Busy=LcdData&0x80;
    E=0;
    return Busy;
void Lcd_WriteData(unsigned char Data)
        while(Lcd_CheckBusy());
        RS=1;
        RW=0;
        E=0;
        _nop_();
        _nop_();
        LcdData=Data;
        E=1;
        _nop_();
        _nop_();
        E=0;
′óLCDÖD¶á3öêy¾Y
unsigned char Lcd_ReadData(void)
        unsigned char Temp;
         LcdData=0xff;
         RS=1;
        RW=1;
        E=1;
        _nop_();
           Temp=LcdData;
           E=0;
           return Temp;
void Lcd_WriteCmd(unsigned char CmdCode)
           RS=0;
           RW=0;
           E=0;
           _nop_();
        _nop_();
           LcdData=CmdCode;
           _nop_();
        _nop_();
           E=1;
           _nop_();
        _nop_();
           E=0;
code unsigned int LcdMaskTab[]={0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000};
void Lcd_PutPixel(unsigned char x,unsigned char y,unsigned char Color)
        unsigned char z,w;
        unsigned int Temp;
        if(x>=128||y>=64)
                return;
        Color=Color%2;
        w=15-x%16;
        x=x/16;
        if(y<32)
                z=0x80;
                z=0x88;
        y=y%32;
        //EA=0;
        Lcd_WriteCmd(0x36);
        Lcd_WriteCmd(y+0x80);
        Lcd_WriteCmd(x+z);
        Temp=Lcd_ReadData();
        Temp=(unsigned int)Lcd_ReadData()<<8;
        Temp|=(unsigned int)Lcd_ReadData();
        //EA=1;
        if(Color==1)
                Temp|=LcdMaskTab[w];
        else         //èç1ûD′èëÑÕé«Îa0
                Temp&=~LcdMaskTab[w];
        //EA=0;
        Lcd_WriteCmd(x+z);
   Lcd_WriteData(Temp>>8);
   Lcd_WriteData(Temp&0x00ff);
        Lcd_WriteCmd(0x30);
        //EA=1;
void Lcd_Clear(unsigned char Mode)
        unsigned char x,y,ii;
        unsigned char Temp;
        if(Mode%2==0)
                Temp=0x00;
                Temp=0xff;
        Lcd_WriteCmd(0x36);
        for(ii=0;ii<9;ii+=8)
                for(y=0;y<0x20;y++)
                        for(x=0;x<8;x++)
                                //EA=0;
                                Lcd_WriteCmd(x+0x80+ii);
                                Lcd_WriteData(Temp);
                                //EA=1;
        Lcd_WriteCmd(0x30);
LCD3õê¼»ˉ
void Lcd_Reset()
        Lcd_WriteCmd(0x30);
        Lcd_WriteCmd(0x0c);
        Lcd_WriteCmd(0x01);
        Lcd_WriteCmd(0x06);
void InitADC()
P1ASF=0X80;
ADC_RES=0;
ADC_CONTR=0xef;
EADC=1;
void adc_isr() interrupt 5 using 1
ADC_CONTR=0xef;
if(over==0)
        temp=delnop;
        while(temp)
        temp--;
        dat[dati]=ADC_RES;
        dati++;
        if(dati>100)
        dati=0;
        over=1;
void disp_0(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+1,1);
Lcd_PutPixel(x+1,y+2,1);
Lcd_PutPixel(x+1,y+3,1);
Lcd_PutPixel(x+2,y+0,1);
Lcd_PutPixel(x+2,y+4,1);
Lcd_PutPixel(x+3,y+1,1);
Lcd_PutPixel(x+3,y+2,1);
Lcd_PutPixel(x+3,y+3,1);
void disp_1(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+4,1);
Lcd_PutPixel(x+2,y+1,1);
Lcd_PutPixel(x+2,y+2,1);
Lcd_PutPixel(x+2,y+3,1);
Lcd_PutPixel(x+3,y+4,1);
void disp_2(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+0,1);
Lcd_PutPixel(x+3,y+0,1);
void disp_3(unsigned char x,unsigned char y)
void disp_4(unsigned char x,unsigned char y)
void disp_5(unsigned char x,unsigned char y)
void disp_p(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+0,1);
Lcd_PutPixel(x+4,y+0,1);
void disp_k(unsigned char x,unsigned char y)
Lcd_PutPixel(x+0,y+1,1);
Lcd_PutPixel(x+0,y+2,1);
Lcd_PutPixel(x+0,y+3,1);
Lcd_PutPixel(x+0,y+4,1);
void disp_hz(unsigned char x,unsigned char y)
Lcd_PutPixel(x+4,y+1,1);
Lcd_PutPixel(x+4,y+3,1);
Lcd_PutPixel(x+4,y+4,1);
Lcd_PutPixel(x+5,y+1,1);
Lcd_PutPixel(x+5,y+2,1);
Lcd_PutPixel(x+5,y+4,1);
void clr(unsigned char starx,unsigned char stary,unsigned char endx,unsigned char endy)
char x=0;
char y=0;
for(x=starx;x<endx;x++)
        for(y=stary;y<endy;y++)
                Lcd_PutPixel(x,y,0);
void disp_bj(void)
unsigned char x=0;
unsigned char y=0;
for(x=13;x<114;x++)
Lcd_PutPixel(x,52,1);
for(y=0;y<52;y++)
Lcd_PutPixel(13,y,1);
for(y=0;y<52;y++)
Lcd_PutPixel(114,y,1);
Lcd_PutPixel(13,51,0);
Lcd_PutPixel(13,41,0);
Lcd_PutPixel(13,31,0);
Lcd_PutPixel(13,21,0);
Lcd_PutPixel(13,11,0);
Lcd_PutPixel(13,1,0);
Lcd_PutPixel(114,51,0);
Lcd_PutPixel(114,41,0);
Lcd_PutPixel(114,31,0);
Lcd_PutPixel(114,21,0);
Lcd_PutPixel(114,11,0);
Lcd_PutPixel(114,1,0);
disp_0(5,50);
disp_1(5,40);
disp_2(5,30);
disp_3(5,20);
disp_4(5,10);
disp_5(5,0);
disp_0(117,50);
disp_1(117,40);
disp_2(117,30);
disp_3(117,20);
disp_4(117,10);
disp_5(117,0);
disp_2(13,58);
disp_hz(18,58);
disp_2(38,58);
disp_0(43,58);
disp_hz(48,58);
disp_2(63,58);
disp_0(68,58);
disp_0(73,58);
disp_hz(78,58);
disp_2(88,58);
disp_k(93,58);
disp_hz(98,58);
void line(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1)
int i,dx,dy,e,x,y;
Lcd_PutPixel(x0,y0,1);
Lcd_PutPixel(x1,y1,1);
dx=x1-x0;
dy=y1-y0;
x=x0;
y=y0;
if(dx>0&&dy>0)
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        Lcd_PutPixel(x,y,1);
        x++;
        e=e+2*dy;
        if(e>=0)
                y++;
                e=e-2*dx;
e=-dy;
x=x0;
y=y0;
for(i=0;i<dy;i++)
        y++;
        e=e+2*dx;
        if(e>=0)
                x++;
                e=e-2*dy;
if(dx<0&&dy<0)
dx=x0-x1;
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x--;
        e=e+2*dy;
        if(e>=0)
                y--;
                e=e-2*dx;
e=-dy;
for(i=0;i<dy;i++)
        y--;
        e=e+2*dx;
        if(e>=0)
                x--;
                e=e-2*dy;
if(dx>0&&dy<0)
dy=y0-y1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x++;
        e=e+2*dy;
        if(e>=0)
                y--;
                e=e-2*dx;
e=-dy;
for(i=0;i<dy;i++)
        y--;
        e=e+2*dx;
        if(e>=0)
                x++;
                e=e-2*dy;
if(dx<0&&dy>0)
dx=x0-x1;
if(dx>dy)
e=-dx;
for(i=0;i<dx;i++)
        x--;
        e=e+2*dy;
        if(e>=0)
                y++;
                e=e-2*dx;
e=-dy;
for(i=0;i<dy;i++)
        y++;
        e=e+2*dx;
        if(e>=0)
                x--;
                e=e-2*dy;
if(dx!=0&&dy==0)
if(dx>0)
for(i=0;i<dx;i++)
        x++;
dx=x0-x1;
for(i=0;i<dx;i++)
        x--;
if(dx==0&&dy!=0)
if(dy>0)
for(i=0;i<dy;i++)
        y++;
dy=y0-y1;
for(i=0;i<dy;i++)
        y--;
void disp_ware()
unsigned char x=0;
unsigned char y=0;
                clr(14,0,15,52);
                for(x=1;x<100;x++)
                        clr(x+14,0,x+15,52);
                        line(x+13,51-(dat[x-1]/5),x+14,51-(dat[x]/5));
main()
Lcd_Reset();
Lcd_Clear(0);
InitADC();
disp_bj();
EA=1;
if(over)
                disp_ware();
                if(jiakey==0)
                if(mode<3)
                        mode++;
                if(jiankey==0)
                if(mode>0)
                        mode--;
        switch(mode)
        case 0:
                delnop=1;
                disp_p(91,54);
                clr(66,54,71,57);
                clr(41,54,46,57);
                clr(16,54,21,57);
        break;
        case 1:
                delnop=40;
                disp_p(66,54);
                clr(91,54,96,57);
                clr(41,54,46,57);
                clr(16,54,21,57);
        break;
        case 2:
                delnop=440;
                disp_p(41,54);
                clr(91,54,96,57);
                clr(66,54,71,57);
                clr(16,54,21,57);
        break;
        case 3:
                delnop=4440;
                disp_p(16,54);
                clr(91,54,96,57);
                clr(41,54,46,57);
                clr(66,54,71,57);
        break;
        default:
        break;
        over=0;
這個是示波器原理圖
這個是示波器原理圖
收藏收藏 分享淘帖 頂1 踩
