查看: 2894|回復: 0
快速FFT變換C語言程序
ID:551867 發表于 2019-5-31 15:03 | 顯示全部樓層 |閱讀模式
快速FFT變換源程序
  1. #include <stdio.h>
  2. #include <math.h>
  3. typedef struct        //定義復數結構體變量
  4. {
  5.         double real;
  6.         double imag;
  7. }complex;
  8. #define N 5
  9. #define PI 3.1514926535897932384626433832795028841971        //定義圓周率
  10. void c_plus(complex, complex, complex *);                                //復數加運算
  11. void c_sub(complex, complex, complex *);                                //復數減運算o
  12. void c_mul(complex, complex, complex *);                                //復數乘運算
  13. void Wn_i(int, int, complex *);                                                    //旋轉因子
  14. int main()
  15. {
  16.         complex f[N] = { 1, 2, 2, 3 };
  17.         complex wn;
  18.         Wn_i(8, 3, &wn);
  19.         c_mul(f[0], wn, &f[2]);
  20.         c_sub(f[1], f[2], &(f[3]));
  21.         c_plus(f[1], f[2], &(f[4]));
  22.         printf("f[%d]為:%lf + %lf        \n", 2, f[2].real, f[2].imag);
  23.         printf("f[%d]為:%lf + %lf        \n", 3, f[3].real, f[3].imag);
  24.         printf("f[%d]為:%lf + %lf        \n", 4, f[4].real, f[4].imag);
  25.         return 0;
  26. }
  27. void c_plus(complex a, complex b, complex *c)                        //復數加法
  28. {
  29.         c->real = a.real + b.real;
  30.         c->imag = a.imag + b.imag;
  31. }
  32. void c_sub(complex a, complex b, complex *c)                        //復數減法
  33. {
  34.         c->real = a.real - b.real;
  35.         c->imag = a.imag - b.imag;
  36. }
  37. void c_mul(complex a, complex b, complex *c)                        //復數乘法
  38. {
  39.         c->real = a.real*b.real - a.imag*b.imag;
  40.         c->imag = a.real*b.imag + a.imag*b.real;
  41. }
  42. void Wn_i(int n1, int i, complex *Wn)                                        //定義旋轉因子
  43. {
  44.         Wn->real = cos(2 * PI*i / n1);
  45.         Wn->imag = -sin(2 * PI*i / n1);
  46. }
全部資料51hei下載地址:
fft.zip (699 Bytes, 下載次數: 43)
