查看: 1210|回復: 0
單片機NT0中斷計數程序
ID:500398 發表于 2019-5-31 10:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
uchar code DSY_CODE[]=
         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f,0x6f,0x00
uchar Display_Buffer[3]={0,0,0};
uint Count = 0;
sbit Clear_Key = P3^6;
void Show_Count_ON_DSY()
         Display_Buffer[2] = Count / 100;
        Display_Buffer[1] = Count % 100 /10;
        Display_Buffer[0] = Count % 10;
        if(Display_Buffer[2]==0)
                 Display_Buffer[2] = 0x0a;
                if(Display_Buffer[1]==0)
                         Display_Buffer[1]=0x0a;
        P0 = DSY_CODE[Display_Buffer[0]];
        P1 = DSY_CODE[Display_Buffer[1]];
        P2 = DSY_CODE[Display_Buffer[2]];
         P0 = 0xff;
        P1 = 0xff;
        P2 = 0xff;
        IE = 0x81;
        IT0 = 1;
                 if(Clear_Key == 0)
                        Count = 0;
                Show_Count_NO_DSY();
void EX_INT0() interrupt 0
         Count ++;
