Arduino源程序如下:
- // DIY Smart Scale with Alarm Clock v0.1 by Igor Fonseca @2018
- // Based on Instructables Internet of Things Class sample code and SparkFun HX711 example
- // Saves weight online on Adafruit.io.
- // Displays measured weight on a local display.
- // Read and display current time from an internet server.
- // Configurable alarm clock with buzzer.
- // Modified by Igor Fonseca 2018
- // based on Instructables Internet of Things Class sample code by Becky Stern 2017
- // based on Example using the SparkFun HX711 breakout board with a scale by Nathan Seidle 2017
- // Adafruit invests time and resources providing this open source code.
- // Please support Adafruit and open source hardware by purchasing
- // products from Adafruit!
- // Written by Todd Treece for Adafruit Industries
- // Copyright (c) 2016 Adafruit Industries
- // Licensed under the MIT license.
- // All text above must be included in any redistribution.
- /************************ Adafruit IO Configuration *******************************/
- // visit io.adafruit.com if you need to create an account,
- // or if you need your Adafruit IO key.
- #define IO_USERNAME "XXXXX"
- #define IO_KEY "YYYYY"
- /******************************* WIFI Configuration **************************************/
- #define WIFI_SSID "ZZZZZ"
- #define WIFI_PASS "WWWWW"
- #include <AdafruitIO_WiFi.h>
- AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
- /************************ Main Program Starts Here *******************************/
- /******************************** Libraries **************************************/
- #include <ESP8266WiFi.h> // ESP8266 library
- #include <AdafruitIO.h> // Adafruit IO library
- #include <Adafruit_MQTT.h> // Adafruit MQTT library
- #include <ArduinoHttpClient.h> // http Client
- #include <HX711.h> // HX711 library for the scla
- #include "DFRobot_HT1632C.h" // Library for DFRobot LED matrix display
- #include <EEPROM.h> // Library for reading/writing on the memory
- /******************************* Definitions *************************************/
- #define calibration_factor -22795.0 //-7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
- #define DOUT 0 // Pin connected to HX711 data output pin
- #define CLK 12 // Pin connected to HX711 clk pin
- #define NUM_MEASUREMENTS 10 // Number of measurements
- #define THRESHOLD 2 // Measures only if the weight is greater than 2 kg. Convert this value to pounds if you're not using SI units.
- #define THRESHOLD1 0.2 // Restart averaging if the weight changes more than 0.2 kg.
- #define DATA D6 // Pin for DFRobot LED matrix display
- #define CS D2 // Pin for DFRobot LED matrix display
- #define WR D7 // Pin for DFRobot LED matrix display
- #define MEM_ALOC_SIZE 8
- DFRobot_HT1632C ht1632c = DFRobot_HT1632C(DATA, WR,CS); // set up LED matrix display
- AdafruitIO_Feed *myWeight = io.feed("my-weight"); // set up the 'iot scale' feed
- AdafruitIO_Feed *alarmTime = io.feed("alarm-clock"); // set up the 'iot scale' feed
- String TimeDate = ""; // Variable used to store the data received from the server
- int hours; // Current hour
- int minutes; // Current minute
- int seconds; // Current second
- int seconds0; // Last time the clock was updated
- #define TIMEZONE 3 // Current time zone. Used for correction of server time
- int alarmhour; // Alarm hour
- int alarmminute; // Alarm minute
- boolean alarm = false; // Alarm status. True = turn on the buzzer
- boolean latch = false; // This variable inhibits the alarm until next minute
- int bedtimehour = 23; // Disables the display from this time until next morning
- int bedtimeminute = 00; // Disables the display from this time until next morning
- boolean displayStatus = true; // Display status. True = display on
- HX711 scale(DOUT, CLK); // Scale initialization
- float weight = 0.0; // Last measured weight
- float prev_weight = 0.0; // Previous measeured weigt
- int frequency = 600; // Sound frequency specified in Hz
- #define buzzer D3 // Buzzer positive pin
- #define groundPin D5 // Buzzer negative pin. It's used as a ground pin.
- int timeOn = 200; // Duration for buzzer on (specified in milliseconds)
- int timeOff = 200; // Duration for buzzer off (specified in millisecods)
- /********************************** Setup ****************************************/
- void setup() {
- // Configure IO pins
- pinMode(buzzer, OUTPUT);
- pinMode(groundPin, OUTPUT); // this pin was used to emulate a GND pin
- digitalWrite(groundPin, LOW);
- // Start the serial connection
- Serial.begin(115200);
- Serial.println("");
- Serial.println("***************************************************");
- Serial.println("DIY Smart Scale with Alarm Clock v0.1 by Igor @2018");
- // Setup LED matrix display
- ht1632c.begin();
- ht1632c.isLedOn(true);
- ht1632c.clearScreen();
- delay(500);
- // Connect to io.adafruit.com
- Serial.print("Connecting to Adafruit IO");
- io.connect();
- // Set up a message handler for the 'my weight' feed.
- // The handleMessage function (defined below)
- // will be called whenever a message is
- // received from adafruit io.
- alarmTime->onMessage(handleMessage);
- // Wait for a connection
- ht1632c.print("connecting...",50);
- while(io.status() < AIO_CONNECTED) {
- Serial.print(".");
- ht1632c.print("...",50);
- ESP.wdtFeed();
- delay(500);
- // We are connected
- Serial.println(io.statusText());
- ESP.wdtFeed();
- ht1632c.print("connected...",50);
- // Scale calibration
- scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
- scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
- // Get current time from server
- getTime();
- seconds0 = millis();
- // Read alarm values from EEPROM memory
- EEPROM.begin(MEM_ALOC_SIZE);
- alarmhour = EEPROM.read(0);
- alarmminute = EEPROM.read(1);
- EEPROM.end();
- Serial.print("Alarm set to: ");
- if (alarmhour < 10) {
- Serial.print("0");
- Serial.print(alarmhour);
- Serial.print(":");
- if (alarmminute < 10) {
- Serial.println(alarmminute);
- void loop() {
- // io.run(); is required for all sketches.
- // it should always be present at the top of your loop
- // function. it keeps the client connected to
- // io.adafruit.com, and processes any incoming data.
- io.run();
- ESP.wdtFeed();
- // Read current weight
- weight = scale.get_units();
- float avgweight = 0;
- if (weight > THRESHOLD) { // Takes measures if the weight is greater than the threshold
- float weight0 = scale.get_units();
- delay(1000);
- for (int i = 0; i <= NUM_MEASUREMENTS; i++) { // Takes several measurements
- delay(100);
- Serial.println(weight);
- avgweight = avgweight + weight;
- if (abs(weight - weight0) > THRESHOLD1) {
- avgweight = 0;
- i = 0;
- weight0 = weight;
- avgweight = avgweight / NUM_MEASUREMENTS; // Calculate average weight
- Serial.print("Measured weight: ");
- Serial.print(avgweight, 1);
- Serial.println(" kg");
- alarm = false; // disable alarm
- latch = true; // disable alarm for one minute
- char result[8]; // Buffer big enough for 7-character float
- dtostrf(avgweight, 6, 1, result);
- ht1632c.print(result); // Display measured weight on LED display
- //save myWeight to Adafruit.io
- myWeight->save(avgweight);
- // wait while there's someone on the scale
- while (scale.get_units() > THRESHOLD) {
- ESP.wdtFeed();
- //keep LEDs on for two seconds then restart
- delay(2000);
- // update clock on display every 5 seconds
- if ((millis() - seconds0) > 5000) {
- seconds = seconds + 5;
- // synchronize with the server every 60 seconds
- if (seconds > 59) {
- getTime();
- latch = false;
- // verify bed time
- if ((hours == bedtimehour) && (minutes == bedtimeminute)) {
- displayStatus = false; // disable display if it's already bed time
- // display clock
- char clocktime[5]; // Buffer big enough for 5-character float
- char hourstime[1]; // Buffer big enough for 2-character float
- char minutestime[2]; // Buffer big enough for 2-character float
- // format clock value for the display
- if ((hours < 10) && (minutes < 10)) {
- sprintf(clocktime,"0%d:0%d",hours,minutes); // Concatenate string for display
- if ((hours < 10) && (minutes >= 10)) {
- sprintf(clocktime,"0%d:%d",hours,minutes); // Concatenate string for display
- if ((hours >= 10) && (minutes < 10)) {
- sprintf(clocktime,"%d:0%d",hours,minutes); // Concatenate string for display
- if ((hours >= 10) && (minutes >= 10)) {
- sprintf(clocktime,"%d:%d",hours,minutes); // Concatenate string for display
- if (displayStatus == true) {
- ht1632c.print(clocktime); // Display current time on LED matrix
- // trigger alarm clock
- if ((hours == alarmhour) && (minutes == alarmminute) && (latch == false)) {
- alarm = true;
- displayStatus = true; // turn on display
- // activate buzzer
- if (alarm == true) {
- tone(buzzer, frequency);
- delay(timeOn);
- noTone(buzzer);
- delay(timeOff);
- // this function is called whenever a message
- // is received from Adafruit IO. it was attached to
- // the feed in the setup() function above.
- void handleMessage(AdafruitIO_Data *data) {
- String commandStr = data->toString(); // store the incoming commands in a string
- // read alarm time
- alarmhour = commandStr.substring(0,2).toInt();
- alarmminute = commandStr.substring(3,5).toInt();
- // serial output received values
- // store time on EEPROM memory
- EEPROM.write(0,alarmhour);
- EEPROM.write(1,alarmminute);
- EEPROM.end();
- //Get current time Google server
- void getTime() {
- // connect server
- WiFiClient client;
- while (!!!client.connect("google.com", 80)) {
- Serial.println("connection failed, retrying...");
- ESP.wdtFeed();
- client.print("HEAD / HTTP/1.1\r\n\r\n");
- delay(500); //wait a few milisseconds for incoming message
- //if there is an incoming message
- if(client.available()){
- while(client.available()){
- if (client.read() == '\n') {
- if (client.read() == 'D') {
- if (client.read() == 'a') {
- if (client.read() == 't') {
- if (client.read() == 'e') {
- if (client.read() == ':') {
- client.read();
- String theDate = client.readStringUntil('\r');
- client.stop();
- TimeDate = theDate.substring(7);
- String strCurrentHour = theDate.substring(17,19);
- String strCurrentMinute = theDate.substring(20,22);
- String strCurrentSecond = theDate.substring(23,25);
- // store received data on global variables
- hours = strCurrentHour.toInt();
- hours = hours - TIMEZONE; // compensate for TIMEZONE
- if (hours < 0) {
- hours = hours + 24;
- minutes = strCurrentMinute.toInt();
- seconds = strCurrentSecond.toInt();
- //if no message was received (an issue with the Wi-Fi connection, for instance)
- else{
- seconds = 0;
- minutes += 1;
- if (minutes > 59) {
- minutes = 0;
- hours += 1;
- if (hours > 23) {
- hours = 0;
- // serial output current time
- Serial.print("Current time: ");
- if (hours < 10) {
- Serial.print(hours);
- if (minutes < 10) {
- Serial.println(minutes);
iot-scale-clock-firebeetle-v0-1.zip
(4.1 KB, 下載次數: 15)
2019-5-30 23:20 上傳
