查看: 4890|回復: 1
(資料分享)STC12C5A60S2內部自帶AD的使用
ID:494791 發表于 2019-5-30 21:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sfr P1ASF=0X9D;                 //P1口模擬功能控制寄存器
sfr        ADC_CONTR=0XBC;        //ADC控制寄存器
sfr        ADC_RES=0XBD;        //AD轉換結果存放
sfr        ADC_RESL=0XBE;        //AD轉換結果存放
sfr        AUXR1=0XA2;
//sfr        IE=0XA8;
//sfr        IPH=0XB7;        //中斷優先級控制寄存器高
//sfr        IP=0XB8;        //中斷優先級控制寄存器低
uchar temp;
unsigned int result=0,resulth=0;
void delay1ms(uint z)   //誤差 0us
    unsigned char a,b,c;
    for(c=z;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void ADinit()
   P1ASF=0x01;        //P1^0口作為AD輸入口
   ADC_CONTR=0x20;          //P1^0口作為AD輸入口,360個時鐘周期轉換一次
   AUXR1=0x00;        //高八位存放于ADC_RES,低二位存放于ADC_RESL
   IE=0XA0;                      //開總中斷允許AD中斷
void ADser() interrupt 5
     P2=0xaa;
     _nop_();
         _nop_();
         _nop_();
         _nop_();                                   //延時4個時鐘周期,使其趨于穩定
     temp=(ADC_CONTR|0X10)<<4; //此時ADC_FLAG的值被移入CY位;
     ADC_CONTR=0xC0;           //轉換完成,將ADC_FLAG清零
     resulth=ADC_RES;          //讀取高8位值
     P2=ADC_RES;
     result=(unsigned int)(resulth*5/256);
     P2=result;                               //把ADC_RES的值以點亮小燈的形式顯示出來
    ADinit();
           ADC_CONTR=0XA8;;//開始AD轉換
           delay1ms(1000);  //以下延時非必須,為測試程序而加,
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           ADC_CONTR=0X20;;//關閉AD轉
           P2=0xff;
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
           delay1ms(1000);
我用的是普中的板子,P2口接有8個共陽極的LED燈,不同的結果會有不同的現象,可以通過小燈的亮滅讀取結果
收藏收藏5 分享淘帖 頂 踩
ID:382699 發表于 2020-11-2 00:09 | 只看該作者
非常感謝,找到一個可以理解的AD程序!
