查看: 1167|回復: 1
stm32 030 超聲波使用代碼
ID:548229 發表于 2019-5-28 16:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
                                            u32 m = 0;
                                                int i = 0;
                                          int J = 0;
                                                float lengthTemp = 0;
                                                float sum = 0;
                                                while(i!=5)
                                                        GPIO_SetBits(GPIOB,GPIO_Pin_6);
                                                        delay_us(20);
                                                        GPIO_ResetBits(GPIOB,GPIO_Pin_6);
                                                        while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_7)==0)
        J++;      //??????????
        if(J == 2000) break;
                                                        if(J < 2000)
        TIM16->CNT=0;
        msHcCount_B=0;
        TIM_Cmd(TIM16,ENABLE);
        i = i + 1;
        while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_7)==1);
        TIM_Cmd(TIM16,DISABLE);
        m = msHcCount_B*50000;//??MS
        m+=TIM16->CNT;
        TIM16->CNT = 0;  //TIM2
        delay_ms(50);
        lengthTemp = ((float)m/58.0);//cm
        sum = lengthTemp + sum ;
        i = i + 1;
        //        sum=0;
        printf("distance_B=ERROR \r\n");
        J=0;
                                            lengthTemp=sum/5;
                                                printf("distance_B=%03.f \r\n",lengthTemp);
        if(lengthTemp<50.00)
        sendData[75] = 0x31;
        sendData[75] = 0x30;
ID:1 發表于 2019-5-30 18:16 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
