查看: 3354|回復: 0
VHDL設計洗衣機含暫停和開始鍵待機2秒正轉8秒待機2秒反轉8秒待機2秒循環3次結束響鈴
VHDL設計洗衣機電路,暫停和開始鍵,待機2秒正轉8秒待機2秒反轉8秒待機2秒,循環3次結束后響鈴3秒結束。
按鍵對照表:
CLK_50M                     91
start1              KEY1     11
Zhanting         KEY2     25
led_zheng       LED1     39
led_fan           LED2      31
led_stop         LED3       3
beep                             7
WEI[0]           SEG_C1    98
WEI[1]           SEG_C2    99
WEI[2]           SEG_C3    86
WEI[3]           SEG_C4    87
LED7[0]            G          103
LED7[1]            F           101
LED7[2]            E           106
LED7[3]            D          110
LED7[4]            C          104
LED7[5]            B           111
LED7[6]            A           100
vhdl源程序如下:
  1. LIBRARY IEEE;
  2. USE IEEE.STD_LOGIC_1164.ALL;
  3. USE IEEE.STD_LOGIC_ARITH.ALL;
  4. USE IEEE.STD_LOGIC_UNSIGNED.ALL;
  5. ENTITY xiyiji IS
  6.   PORT( CLK_50M,Zhanting,start1:IN STD_LOGIC;
  7.                   WEI,time_1:OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
  8.                  LED7:OUIS
  9.     COMPONENT div
  10.            PORT(CLK_IN:IN STD_LOGIC;T STD_LOGIC_VECTOR(6 DOWNTO 0);
  11.                   led_zheng,led_fan,led_stop,beep:out std_logic
  12.        );
  13. END ENTITY xiyiji;
  14.   ARCHITECTURE BHV_0 OF xiyiji
  15.            CLK_OUT:OUT STD_LOGIC);
  16.     END COMPONENT;
  17.
  18.          COMPONENT decoder
  19.            PORT(D_IN : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
  20.            DOUT : OUT STD_LOGIC_VECTOR(6 DOWNTO 0));
  21.     END COMPONENT;
  22.
  23.          COMPONENT keshe
  24.            PORT(
  25.         emergency,clk,start: IN STD_LOGIC;
  26.                   counter,times :OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
  27.                   zheng,fan,stop,ring:OUT STD_LOGIC
  28.            );
  29.     END COMPONENT;
  30.
  31. SIGNAL H:STD_LOGIC;
  32. SIGNAL S:STD_LOGIC_VECTOR(3 DOWNTO 0);
  33. BEGIN
  34.   U1:div PORT
  35.   MAP(CLK_IN=>CLK_50M,CLK_OUT=>H);
  36.   U2:keshe PORT
  37.   MAP(CLK=>H,counter=>S,emergency=>Zhanting,start=>start1,
  38.       ring=>beep,times=>time_1,zheng=>led_zheng,fan=>led_fan,stop=>led_stop);
  39.   U3:decoder PORT
  40.   MAP(D_IN=>S,DOUT=>LED7);
  41.   WEI<="0111";
  42.
  43. END BHV_0;
全部資料51hei下載地址:
keshe.zip (3.46 MB, 下載次數: 41)
收藏收藏3 分享淘帖 頂 踩
