如題沒截圖
單片機(jī)源程序如下:
- name : main.c
- desctiption : mp3 main file for testing serial port
- author : coolfire
- update : 6/17/07
- #include <reg51.h>
- #include "compiler.h"
- #include "init\init.h"
- #include "buffer\buffer.h"
- #include "serial\serial.h"
- extern Uint32 wav_len_w;
- extern Uint32 wav_len_r;
- mode_t mode=download;
- void main()
- init();
- loop: switch(mode)
- case idle:
- while(mode==idle);
- break;
- case download:
- while(mode==download)
- if(!wav_len_w)
- write_buffer(serial);
- read_buffer(flash);
- break;
- case play:
- while(mode==play)
- if(!wav_len_r)
- write_buffer(flash);
- read_buffer(dac);
- break;
- goto loop;
waefd-1.rar
(11.55 KB, 下載次數(shù): 45)
2019-5-27 20:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
