查看: 5391|回復: 1
MSP430F5529LP板上兩燈交替閃爍程序,需要的拿去
ID:542544 發表于 2019-5-26 22:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <msp430f5529.h>
void Delay(unsigned int ms);
* main.c
int main(void)
        WDTCTL = WDTPW | WDTHOLD;        // stop watchdog timer
        P4DIR |= BIT7; //P4.7輸出模式
        P1DIR |= BIT0; //P1.0輸出模式
        P4OUT |= BIT7; P1OUT &= ~BIT0;
        Delay(500);
        P1OUT |= BIT0; P4OUT &= ~BIT7;
        Delay(500);
        return 0;
     unsigned int i,j;
     for (i=0;i<ms;i++) { for(j=0; j<215; j++); }
ID:921513 發表于 2021-5-18 23:42 | 只看該作者
不管用呀
