// 函數說明:main.c
// 說明:該程序用于測試lora模塊
// 編寫人員: sky
// 編寫日期: 2016-11-24
// 版本號:V1.0
// 維護日志:
// 免責聲明:該程序僅供參考學習,若自定義其他功能,請查看參考手冊
// (c) Anxinke Corporation. All rights reserved.
#include "sx1278.h"
//#include "reg51.hcd"
lpCtrlTypefunc_t lpTypefunc = { 0, 0, 0 };
unsigned char power_data[8] = { 0X80, 0X80, 0X80, 0X83, 0X86, 0x89, 0x8c, 0x8f };
lpCtrlTypefunc_t ctrlTypefunc =
{ RF_SPI_MasterIO, RF_SPI_READ_BYTE, cmdSwitchEn,
//unsigned char Frequency[3] = { 0x6c, 0x80, 0x00 };//470Mhz
unsigned char Frequency[3] = { 0x6c, 0x80, 0x00 };//430Mhz 頻率設置
unsigned char powerValue = 7;
unsigned char SpreadingFactor = 12; //擴頻因子7-12
unsigned char CodingRate = 2; //1-4
unsigned char Bw_Frequency = 7; //帶寬6-9
unsigned char RF_EX0_STATUS;
unsigned char CRC_Value;
unsigned char SX1278_RLEN;
//unsigned char recv[512];
void Delay1s(unsigned int ii)
int j;
while(ii--){
for(j=0;j<1000;j++);
function:SX1278 restart
void SX1276Reset(void) {
RF_REST_L;
Delay1s(200);
RF_REST_H;
Delay1s(500);
function:control GPIO-EN
void cmdSwitchEn(cmdEntype_t cmd) {
switch (cmd) {
case enOpen: {
RF_CE_L;
break;
case enClose: {
RF_CE_H;
break;
default:
break;
void RF_SPI_MasterIO(unsigned char out) {
unsigned char i;
for (i = 0; i < 8; i++) {
if (out & 0x80) /* check if MSB is high */
RF_SDI_H;
RF_SDI_L; /* if not, set to low */
RF_CKL_H; /* toggle clock high */
out = (out << 1); /* shift 1 place for next bit */
RF_CKL_L; /* toggle clock low */
unsigned char RF_SPI_READ_BYTE() {
unsigned char j;
unsigned char i;
j = 0;
RF_CKL_H;
j = (j << 1); // shift 1 place to the left or shift in 0 //
if ( SX1278_SDO) // check to see if bit is high //
j = j | 0x01; // if high, make bit high //
// toggle clock high //
RF_CKL_L; // toggle clock low //
return j; // toggle clock low //
unsigned char SX1276ReadBuffer(unsigned char addr) {
unsigned char Value;
lpTypefunc.lpSwitchEnStatus(enOpen); //NSS = 0;
lpTypefunc.lpByteWritefunc(addr & 0x7f);
Value = lpTypefunc.lpByteReadfunc();
lpTypefunc.lpSwitchEnStatus(enClose); //NSS = 1;
return Value;
function:set sx1278 work mode ,here you can control the mode which is send or recieve
parm:
void SX1276LoRaSetOpMode(RFMode_SET opMode) {
unsigned char opModePrev;
opModePrev = SX1276ReadBuffer(REG_LR_OPMODE);
opModePrev &= 0xf8;
opModePrev |= (unsigned char) opMode;
SX1276WriteBuffer( REG_LR_OPMODE, opModePrev);
void SX1276WriteBuffer(unsigned char addr,
unsigned char buffer) {
lpTypefunc.lpByteWritefunc(addr | 0x80);
lpTypefunc.lpByteWritefunc(buffer);
void register_rf_func(lpCtrlTypefunc_t *func) {
if (func->lpByteWritefunc != 0) {
lpTypefunc.lpByteWritefunc = func->lpByteWritefunc;
if (func->lpByteReadfunc != 0) {
lpTypefunc.lpByteReadfunc = func->lpByteReadfunc;
if (func->lpSwitchEnStatus != 0) {
lpTypefunc.lpSwitchEnStatus = func->lpSwitchEnStatus;
void SX1276LoRaSetRFFrequency(void) {
SX1276WriteBuffer( REG_LR_FRFMSB, Frequency[0]);//0x04射頻載波頻率最高有效位
SX1276WriteBuffer( REG_LR_FRFMID, Frequency[1]);//0x07射頻載波頻率中間有效位
SX1276WriteBuffer( REG_LR_FRFLSB, Frequency[2]);//0x00射頻載波頻率最低有效位
void SX1276LoRaSetNbTrigPeaks(unsigned char value) {
unsigned char RECVER_DAT;
RECVER_DAT = SX1276ReadBuffer(0x31);
RECVER_DAT = (RECVER_DAT & 0xF8) | value;
SX1276WriteBuffer(0x31, RECVER_DAT);
void SX1276LoRaSetSpreadingFactor(unsigned char factor) {
SX1276LoRaSetNbTrigPeaks(3);
RECVER_DAT = SX1276ReadBuffer( REG_LR_MODEMCONFIG2);
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG2_SF_MASK) | (factor << 4);
SX1276WriteBuffer( REG_LR_MODEMCONFIG2, RECVER_DAT);
void SX1276LoRaSetErrorCoding(unsigned char value) {
RECVER_DAT = SX1276ReadBuffer( REG_LR_MODEMCONFIG1);
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG1_CODINGRATE_MASK)
| (value << 1);
SX1276WriteBuffer( REG_LR_MODEMCONFIG1, RECVER_DAT);
// LoRaSettings.ErrorCoding = value;
void SX1276LoRaSetSignalBandwidth(unsigned char bw) {
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG1_BW_MASK) | (bw << 4);
// LoRaSettings.SignalBw = bw;
void SX1276LoRaSetImplicitHeaderOn(BOOL enable) {
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG1_IMPLICITHEADER_MASK)
| (enable);
void SX1276LoRaSetPayloadLength(unsigned char value) {
SX1276WriteBuffer( REG_LR_PAYLOADLENGTH, value);
void SX1276LoRaSetSymbTimeout(unsigned int value) {
unsigned char RECVER_DAT[2];
RECVER_DAT[0] = SX1276ReadBuffer( REG_LR_MODEMCONFIG2);
RECVER_DAT[1] = SX1276ReadBuffer( REG_LR_SYMBTIMEOUTLSB);
RECVER_DAT[0] = (RECVER_DAT[0] & RFLR_MODEMCONFIG2_SYMBTIMEOUTMSB_MASK)
| ((value >> 8) & ~RFLR_MODEMCONFIG2_SYMBTIMEOUTMSB_MASK);
RECVER_DAT[1] = value & 0xFF;
SX1276WriteBuffer( REG_LR_MODEMCONFIG2, RECVER_DAT[0]);
SX1276WriteBuffer( REG_LR_SYMBTIMEOUTLSB, RECVER_DAT[1]);
void SX1276LoRaSetMobileNode(BOOL enable) {
RECVER_DAT = SX1276ReadBuffer( REG_LR_MODEMCONFIG3);
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG3_MOBILE_NODE_MASK)
| (enable << 3);
SX1276WriteBuffer( REG_LR_MODEMCONFIG3, RECVER_DAT);
void RF_RECEIVE(void) {
SX1276LoRaSetOpMode(Stdby_mode);
SX1276WriteBuffer(REG_LR_IRQFLAGSMASK, IRQN_RXD_Value); //打開發送中斷
SX1276WriteBuffer(REG_LR_HOPPERIOD, PACKET_MIAX_Value);
SX1276WriteBuffer( REG_LR_DIOMAPPING1, 0X00);
SX1276WriteBuffer( REG_LR_DIOMAPPING2, 0X00);
SX1276LoRaSetOpMode(Receiver_mode);
// lpTypefunc.paSwitchCmdfunc(rxOpen);
void SX1276LoRaSetPacketCrcOn(BOOL enable) {
RECVER_DAT = (RECVER_DAT & RFLR_MODEMCONFIG2_RXPAYLOADCRC_MASK)
| (enable << 2);
void SX1276LoRaFsk(Debugging_fsk_ook opMode) {
opModePrev &= 0x7F;
void SX1276LoRaSetRFPower(unsigned char power) {
SX1276WriteBuffer( REG_LR_PADAC, 0x87);
SX1276WriteBuffer( REG_LR_PACONFIG, power_data[power]);
function :you must call it ,the function is to init the module.
void SX1276LORA_INT(void) {
SX1276LoRaSetOpMode(Sleep_mode); //設置睡眠模式0x01
SX1276LoRaFsk(LORA_mode); // 設置擴頻模式,只能在睡眠模式下修改
SX1276LoRaSetOpMode(Stdby_mode); // 設置為普通模式
SX1276WriteBuffer( REG_LR_DIOMAPPING1, GPIO_VARE_1);
SX1276WriteBuffer( REG_LR_DIOMAPPING2, GPIO_VARE_2);
SX1276LoRaSetRFFrequency();
SX1276LoRaSetRFPower(powerValue);
SX1276LoRaSetSpreadingFactor(SpreadingFactor); // 擴頻因子設置
SX1276LoRaSetErrorCoding(CodingRate); //有效數據比
SX1276LoRaSetPacketCrcOn(true); //CRC 校驗打開
SX1276LoRaSetSignalBandwidth(Bw_Frequency); //設置擴頻帶寬
SX1276LoRaSetImplicitHeaderOn(false); //同步頭是顯性模式
SX1276LoRaSetPayloadLength(0xff);//0x22 timeout中斷
SX1276LoRaSetSymbTimeout(0x3FF);
SX1276LoRaSetMobileNode(true); // 低數據的優化
RF_RECEIVE();
uartSendString("\r\ninit finish\r\n");
function :if you want to send data,you can call it
RF_TRAN_P:data
ASM_i:the length of the data
void FUN_RF_SENDPACKET(unsigned char *RF_TRAN_P,
unsigned char LEN) {
unsigned char ASM_i;
// lpTypefunc.paSwitchCmdfunc(txOpen);
SX1276WriteBuffer( REG_LR_HOPPERIOD, 0); //不做頻率跳變
SX1276WriteBuffer(REG_LR_IRQFLAGSMASK, IRQN_TXD_Value); //打開發送中斷
SX1276WriteBuffer( REG_LR_PAYLOADLENGTH, LEN); //最大數據包
SX1276WriteBuffer( REG_LR_FIFOTXBASEADDR, 0);
SX1276WriteBuffer( REG_LR_FIFOADDRPTR, 0);
lpTypefunc.lpByteWritefunc(0x80);
for (ASM_i = 0; ASM_i < LEN; ASM_i++) {
lpTypefunc.lpByteWritefunc(*RF_TRAN_P);
RF_TRAN_P++;
SX1276WriteBuffer(REG_LR_DIOMAPPING1, 0x40);
SX1276WriteBuffer(REG_LR_DIOMAPPING2, 0x00);
SX1276LoRaSetOpMode(Transmitter_mode);
