查看: 2706|回復: 5
8051單片機控制8*8點陣時,不用譯碼器可以嗎?
ID:546210 發表于 2019-5-24 11:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
8051單片機控制8*8點陣時,不用譯碼器可以嗎?8*8總共燈的數量大于51單片機接口數量,但是又不會用譯碼器,有沒有不用譯碼器實現控制的方法啊,比如顯示特定兩位數字之類的。
ID:582173 發表于 2019-7-18 10:06 | 只看該作者
protuse可以做到的 8*8點陣陽極接P2口,陰極接P1口,用下面的代碼就可以實現!
void Init_int();
void Init_time();
void display(int yin,int yang);
uchar num_num[10][5]={{0xf0,0xf6,0xf6,0xf6,0xf0},                                  //0
                                          {0xf7,0xf7,0xf7,0xf7,0xf7},                                  //1
                                          {0xf0,0xfe,0xf0,0xf7,0xf0},                              //2
                                          {0xf0,0xfe,0xf0,0xfe,0xf0},                                  //3
                                          {0xf6,0xf6,0xf0,0xfe,0xfe},                                  //4
                                          {0xf0,0xf7,0xf0,0xfe,0xf0},                                  //5
                                          {0xf0,0xf7,0xf0,0xf6,0xf0},                                  //6
                                          {0xf0,0xfe,0xfe,0xfe,0xfe},                                  //7
                                          {0xf0,0xf6,0xf0,0xf6,0xf0},                                  //8
                                          {0xf0,0xf6,0xf0,0xfe,0xf0}};                                  //9
uchar num_zero[5]={0xf0,0xf6,0xf6,0xf6,0xf0};
uchar num_one[5]={0xfe,0xfe,0xfe,0xfe,0xfe};
uchar num_two[5]={0xf0,0xfe,0xf0,0xf7,0xf0};
uchar num_three[5]={0xf0,0xfe,0xf0,0xfe,0xf0};
uchar num_fore[5]={0xf6,0xf6,0xf0,0xfe,0xfe};
uchar num_five[5]={0xf0,0xf7,0xf0,0xfe,0xf0};
uchar num_six[5]={0xf0,0xf7,0xf0,0xf6,0xf0};
uchar num_seven[5]={0xf0,0xfe,0xfe,0xfe,0xfe};
uchar num_eight[5]={0xf0,0xf6,0xf0,0xf6,0xf0};
uchar num_nine[5]={0xf0,0xf6,0xf0,0xfe,0xf0};
unsigned int count,i=1,weiyi,timer,shu,n=1;
        Init_time();
        Init_int();
void Init_time()                                   //定時器初始化
        TMOD|=0x01;
        TH0=0xff;
        TL0=0x10;
        TR0=1;
        ET0=1;
        EA=1;
void Init_int()                   //中斷初始化
        EA=1;
        EX0=1;
        ET0=1;
void time() interrupt 1                          //定時器函數
        TH0=0xfd;                     //50微秒
        TL0=0xa8;
        count++;
        if(count>8)
                count=0;
                display(i-1,i);
                i++;
                if(i>5)
                i=1;
        timer++;
        if(timer>250)
                timer=0;
                weiyi++;
                if(weiyi>10)
                        weiyi=0;
                        shu++;
                        if(shu>9)
                        shu=0;
void display(int yin,int yang)                   //顯示函數
        P2 = 0x00;
        P1 = ~(~num_num[shu][yin]<<weiyi);
        if(weiyi<3)
                P1 = ~(~num_num[shu][yin]>>3-weiyi);
                P1 = ~(~num_num[shu][yin]<<weiyi-3);
        switch(yang)
                case 0 : P2 = 0x01;break;
                case 1 : P2 = 0x02;break;
                case 2 : P2 = 0x04;break;
                case 3 : P2 = 0x08;break;
                case 4 : P2 = 0x10;break;
                case 5 : P2 = 0x20;break;
                case 6 : P2 = 0x40;break;
                case 7 : P2 = 0x80;break;
                default : P2 = 0x00; break;
ID:95809 發表于 2020-2-5 09:11 來自觸屏版 | 只看該作者
只要單片機有16個口就行,陽極接一組,比如P2口,陰極接一組,比如P0。
ID:679147 發表于 2020-2-6 11:12 | 只看該作者
可以,我之前就做過
ID:168996 發表于 2020-2-6 12:58 | 只看該作者
矩陣(并行,不用譯碼)接法,8+8個IO可行
ID:462827 發表于 2020-2-6 13:55 | 只看該作者
可以,不用譯碼器(74HC138等)還可以用其它鎖存器的嘛,比如74HC595、74HC573等等,也可以直接單片機引腳加三級管直接驅動都行。
但是,如果你是用現成的板,那么它用了什么東西你就得用它的呀。
