關(guān)于直流電機(jī)的驅(qū)動(dòng)電路仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2019-5-22 15:59 上傳
單片機(jī)源程序如下:
- //四個(gè)按鍵控制步進(jìn)電機(jī):正轉(zhuǎn),反轉(zhuǎn),加1,減1
- //上電時(shí)電機(jī)啟動(dòng),加減檔位,電機(jī)采用單雙八拍方式
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit s1 = P1^0;
- sbit s2 = P1^1;
- sbit s3 = P3^0;
- sbit s4 = P3^1;
- sbit s5 = P3^2;//按鍵定義,s1正轉(zhuǎn),s2反轉(zhuǎn),s3加1,s4減1
- sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脈沖信號(hào)輸入端定義
- uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc}, //9.7 ----1ms
- {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
- uchar num1 = 0;//控制取勵(lì)磁信號(hào)變量
- uchar num2 = 8;
- char k=0;//加減檔位控制,1為最小檔
- char pause=1;//暫停時(shí)保存之前的轉(zhuǎn)速,開機(jī)默認(rèn)1
- bit flag1 = 0;//初始正轉(zhuǎn),正反轉(zhuǎn)標(biāo)志
- //================================定時(shí)器0/1初始化函數(shù)================================
- void T0_T1_init()
- TMOD = 0x11;//定時(shí)器0/1均工作于方式1,16位計(jì)時(shí)方式
- TH1 = time_counter[k-1][0];
- TL1 = time_counter[k-1][1];//定時(shí)器1,定時(shí)10ms用于步進(jìn)電機(jī)轉(zhuǎn)速控制
- TR1 = 0;
- ET1= 1;//開定時(shí)器中斷
- EA = 1;//開總中斷
- //================================ms級(jí)延時(shí)函數(shù)=======================================
- void delay1m(uint x)
- uint i,j;
- for(i=0;i<x;i++) //連數(shù)x次,約 x ms
- for(j=0;j<120;j++); //數(shù)120 次,約1 ms
- //================================主函數(shù)=============================================
- void main()
- T0_T1_init();
- a=b=c=d=0;
- while(1)
- if(s1 == 0)
- delay1m(3);
- if(s1 == 0)
- flag1 = 0;//正轉(zhuǎn)
- while(!s1);
- if(s2 == 0 )
- delay1m(3);
- if(s2 == 0)
- flag1 = 1;//反轉(zhuǎn)
- while(!s2);
- if(s3 == 0) //速度加1檔
- delay1m(3);
- if(s3 == 0)
- k++;
- TR1=1;
- if(k > 10 )
- k = 1;
- while(!s3);
- if(s4 == 0) //速度減1檔
- delay1m(3);
- if(s4 == 0)
- k--;
- TR1=1;
- if(k <= 0)
- k = 10;
- while(!s4);
- if(s5==0)
- delay1m(3);
- if(s5==0)
- if(TR1==1)
- pause=k;
- k=0;
- TR1=0;
- a=b=c=d=0;
- else if(TR1==0)
- k=pause;
- TR1=1;
- while(!s5);
- //==================================定時(shí)器1中斷函數(shù),用于脈沖頻率控制=====================================
- void time1_interrupt()interrupt 3
- static num1 = 0;
- static num2 = 0;
- TL1 = time_counter[k-1][1];//定時(shí)器1,定時(shí)1 用于步進(jìn)電機(jī)轉(zhuǎn)速控制
- if(flag1 == 0)//正轉(zhuǎn)
- switch(num1)
- case 0:a = 1;b = 0;c = 0;d = 0;break;
- case 1:a = 1;b = 1;c = 0;d = 0;break;
- case 2:a = 0;b = 1;c = 0;d = 0;break;
- case 3:a = 0;b = 1;c = 1;d = 0;break;
- case 4:a = 0;b = 0;c = 1;d = 0;break;
- case 5:a = 0;b = 0;c = 1;d = 1;break;
- case 6:a = 0;b = 0;c = 0;d = 1;break;
- case 7:a = 1;b = 0;c = 0;d = 1;break;
- num1++;
- if(num1 == 8)num1 = 0;
- else //反轉(zhuǎn)
- switch(num2)
- case 0:a = 1;b = 0;c = 0;d = 1;break;
- case 1:a = 0;b = 0;c = 0;d = 1;break;
- case 2:a = 0;b = 0;c = 1;d = 1;break;
- case 3:a = 0;b = 0;c = 1;d = 0;break;
- case 4:a = 0;b = 1;c = 1;d = 0;break;
- case 5:a = 0;b = 1;c = 0;d = 0;break;
- case 6:a = 1;b = 1;c = 0;d = 0;break;
- case 7:a = 1;b = 0;c = 0;d = 0;break;
- num2++;
- if(num2 == 8)num2 = 0;
新建文件夾.7z
(16.2 KB, 下載次數(shù): 146)
2019-5-22 16:01 上傳
點(diǎn)擊文件名下載附件
驅(qū)動(dòng)及程序 下載積分: 黑幣 -5
