仿真好好的到了單片機上出現了這個問題看圖
這字母一直從左到右循環,按鍵的話下面還會出現數字5和7.
LCD顯示屏
2019-5-20 00:03 上傳
麻煩看一下哪里有問題!!!代碼在下面:
#include <reg52.h>
#include <intrins.h> //包含_nop_( )空函數指令的頭文件
#define out P0
sbit RS=P3^4; //位變量
sbit RW=P3^5; //位變量
sbit E=P3^6;
sbit YES=P2^3;
sbit ST=P3^7;
sbit START=P3^0;
void lcd_initial(void); //位變量
void lcd_initial(void); //LCD初始化函數
void check_busy(void); //檢查忙標志函數
void write_command(uchar com); //寫命令函數
void write_data(uchar dat); //寫數據函數
void string(uchar ad ,uchar *s);
void delay(uint); //延時函數
unsigned char key_scan()
unsigned char key_temp0,key_temp1;
unsigned char key_num=0;
P2=0x0f;
key_temp0=P2;
if(key_temp0!=0x0f)
delay(5);
key_temp0=P2;
if(key_temp0!=0x0f)
P2=0xf0;
key_temp1=P2;
if(key_temp0==0x0e)
switch(key_temp1)
case 0xe0: key_num=4;break;
case 0xd0: key_num=3;break;
case 0xb0: key_num=2;break;
case 0x70: key_num=1;break;
default:key_num=0;break;
else if(key_temp0==0x0d)
switch(key_temp1)
case 0xe0: key_num=8;break;
case 0xd0: key_num=7;break;
case 0xb0: key_num=6;break;
case 0x70: key_num=5;break;
else if(key_temp0==0x0b)
switch(key_temp1)
case 0xe0: key_num=12;break;
case 0xd0: key_num=11;break;
case 0xb0: key_num=10;break;
case 0x70: key_num=9;break;
else if(key_temp0==0x07)
switch(key_temp1)
case 0xe0: key_num=16;break;
case 0xd0: key_num=15;break;
case 0xb0: key_num=14;break;
case 0x70: key_num=13;break;
return key_num;
void main(void) //主函數
unsigned char key_num;
lcd_initial( ); //調用對LCD初始化函數
do
key_num=key_scan();
string(0x82,"zhijing"); //顯示的第1行字符串
switch(key_num)
case 1 :string(0xC8,"1"); break;
case 2 :string(0xC8,"2"); break;
case 3 :string(0xC8,"3"); break;
case 4 :string(0xC8,"4"); break;
case 5 :string(0xC8,"5"); break;
case 6 :string(0xC8,"6"); break;
case 7 :string(0xC8,"7"); break;
case 8 :string(0xC8,"8"); break;
case 9 :string(0xC8,"9"); break;
case 10:string(0xC8,"0"); break;
case 11:string(0xC8,"."); break;
case 12:string(0xC8,"YES"); break;
case 13:string(0xC8,"YES"); break;
case 14:string(0xC8,"YES"); break;
case 15:string(0xC8,"YES"); break;
case 16:string(0xC8,"YES"); break;
delay(100); //延時
write_command(0x01); //寫入清屏命令
delay(1); //延時
} while(ST==1);
delay(1); //延時
if(START==1) //有按鍵按下
delay(2000);
string(0x80,"3614.1 cm3/s");
delay(10000000);//延時
write_command(0x01);//寫入清屏命令
delay(1);//延時
while(1);
void delay(uint j) //1ms延時子程序
uchar i=250;
for(;j>0;j--)
while(--i);
i=249;
while(--i);
i=250;
void check_busy(void) //檢查忙標志函數
uchar dt;
do
P0=0xff;
E=0;
RS=0;
RW=1;
E=1;
dt=P0;
}while(dt&0x80);
E=0;
void write_command(uchar com) //寫命令函數
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_( );
E=0;
delay(1);
void write_data(uchar dat) //寫數據函數
check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay(1);
void LCD_initial(void) //液晶顯示器初始化函數
write_command(0x38); //寫入命令0x38:8位兩行顯示,5×7點陣字符
write_command(0x0C); //寫入命令0x0C:開整體顯示,光標關,無黑塊
write_command(0x06); //寫入命令0x06:光標右移
write_command(0x01); //寫入命令0x01:清屏
delay(1);
void string(uchar ad,uchar *s) //輸出顯示字符串的函數
write_command(ad);
while(*s>0)
write_data(*s++); //輸出字符串,且指針增1
delay(50);
