查看: 6842|回復: 4
AVR單片機Atmega16電子時鐘程序+仿真,內部定時器實現
Atmega16電子時鐘,內部定時器,有可調鬧鐘。
  1. #include <iom16v.h>
  2. #include <macros.h>
  3. #define  key_bz    0b00000111
  4. char smg_zx[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d, 0x7d,0x07,0x7f,0x6f};// 全局變量
  5.
  6. char hour=12;
  7. char min;
  8. char sec;
  9. char nz_hour=12;
  10. char nz_min=1;
  11. char mode=0;
  12. char set;
  13. void delay_ms(unsigned int k)
  14. {
  15.     unsigned int i,j;
  16.     for(i=0;i<k;i++)
  17.     {
  18.       for(j=0;j<570;j++);
  19.     }
  20. }
  21. // 用定時器實現定時
  22. void T0_init(void)// 端口初始化函數
  23. {
  24. TIFR=0XFF;
  25. TCCR0=0X0B; //64FENPIN, CTC MODE
  26. TCNT0=0;
  27. OCR0=250;
  28. TIMSK=0X02;
  29. }
  30. void port_init(void)// 端口初始化函數
  31. {
  32.   DDRC  |= 0b11110000;  // PC4 5 OUT PUT
  33.   PORTC |= 0b00111111; //m103 output only
  34. PORTD = 0x00; //  上電關閉數碼管, 因為上電電壓不穩
  35. DDRD  = 0xff;
  36. DDRB  |= 0b11100000;  // PC5 6 7OUT PUT
  37. }
  38. //call this routine to initialize all peripherals
  39. void init_devices(void)
  40. {
  41. //stop errant interrupts until set up
  42. CLI(); //disable all interrupts
  43. port_init();//smg_zx[0]=1;
  44.   T0_init();
  45. SEI(); //re-enable interrupts
  46. //all peripherals are now initialized
  47. }
  48. //miao=45;
  49. void key (void)
  50. {
  51. if(!(PINC&0X01))
  52. {
  53.    delay_ms(2);
  54.    if(!(PINC&0X01))
  55.    {
  56.     TIMSK=0X00;
  57.     mode++;
  58.         mode%=3;
  59.         set=0;
  60.         if(mode==0)TIMSK=0X02;
  61.         while(!(PINC&0X01));
  62.    }
  63. }
  64. if(!(PINC&0X02))
  65. {
  66.    delay_ms(2);
  67.    if(!(PINC&0X02))
  68.    {
  69.     if(mode==1)
  70.         {
  71.          set++;
  72.          set%=3;
  73.         }
  74.         if(mode==2)
  75.         {
  76.          set++;
  77.          set%=2;
  78.         }
  79.         while(!(PINC&0X02));
  80.    }
  81. }
  82. if(!(PINC&0X04))
  83. {
  84.    delay_ms(2);
  85.    if(!(PINC&0X04))
  86.    {
  87.     if(mode==1)
  88.         {
  89.          if(set==0)
  90.          {
  91.           hour++;
  92.           hour%=24;
  93.          }
  94.          if(set==1)
  95.          {
  96.           min++;
  97.           min%=60;
  98.          }
  99.          if(set==2)
  100.          {
  101.           sec++;
  102.           sec%=60;
  103.          }
  104.         }
  105.         if(mode==2)
  106.         {
  107.          if(set==0)
  108.          {
  109.           nz_hour++;
  110.           nz_hour%=24;
  111.          }
  112.          if(set==1)
  113.          {
  114.           nz_min++;
  115.           nz_min%=60;
  116.          }
  117.         }
  118.         while(!(PINC&0X04));
  119.    }
  120. }
  121.
  122. }
  123. //主函數
  124. void main()
  125. {/// 變量聲明
  126.
  127. char zz;
  128.   // 調用初始化哈數
  129. //port_init();
  130. init_devices();
  131. // 特定代碼
  132.    while(1)
  133.    {
  134.
  135.
  136. if(mode==0)
  137. {
  138.
  139.     PORTD=~smg_zx[hour/10];  // 給5的字形編碼
  140.     PORTB|=1<<PB6;//選中PC6
  141.         delay_ms(2);
  142.         PORTB&=0B00111111;//
  143.
  144.
  145.     PORTD=~smg_zx[hour%10];  // 給5的字形編碼
  146.          PORTB|=1<<PB7;//選中PC7
  147.          delay_ms(2);
  148.      PORTB&=0B00111111;//
  149.
  150.
  151.
  152.      PORTD=~smg_zx[min/10];  // 給5的字形編碼
  153.      PORTC|=1<<PC7;//選中PC7
  154.          delay_ms(2);
  155.          PORTC&=0B00001111;//
  156.
  157.
  158.     PORTD=~smg_zx[min%10];  // 給5的字形編碼
  159.         PORTC|=1<<PC6;//選中PC6
  160.          delay_ms(2);
  161.     PORTC&=0B00001111;//
  162.
  163.     PORTD=~smg_zx[sec/10];  // 給5的字形編碼
  164.     PORTC|=1<<PC5;//選中PC5
  165.         delay_ms(2);
  166.         PORTC&=0B00001111;//
  167.
  168.
  169.      PORTD=~smg_zx[sec%10];  // 給5的字形編碼
  170.          PORTC|=1<<PC4;//選中PC4
  171.          delay_ms(2);
  172.      PORTC&=0B00001111;//
  173. }
  174. else if(mode==1)
  175. {
  176.
  177.     PORTD=~smg_zx[hour/10];  // 給5的字形編碼
  178.     PORTB|=1<<PB6;//選中PC6
  179.         delay_ms(2);
  180.         PORTB&=0B00111111;//
  181.
  182.
  183.     PORTD=~smg_zx[hour%10];  // 給5的字形編碼
  184.         if(set==0)  PORTD&=0x7f;//控制小數點亮
  185.          PORTB|=1<<PB7;//選中PC7
  186.          delay_ms(2);
  187.      PORTB&=0B00111111;//
  188.
  189.
  190.
  191.      PORTD=~smg_zx[min/10];  // 給5的字形編碼
  192.      PORTC|=1<<PC7;//選中PC7
  193.          delay_ms(2);
  194.          PORTC&=0B00001111;//
  195.
  196.
  197.     PORTD=~smg_zx[min%10];  // 給5的字形編碼
  198.          if(set==1)  PORTD&=0x7f;//控制小數點亮
  199.         PORTC|=1<<PC6;//選中PC6
  200.          delay_ms(2);
  201.     PORTC&=0B00001111;//
  202.
  203.     PORTD=~smg_zx[sec/10];  // 給5的字形編碼
  204.     PORTC|=1<<PC5;//選中PC5
  205.         delay_ms(2);
  206.         PORTC&=0B00001111;//
  207.
  208.
  209.      PORTD=~smg_zx[sec%10];  // 給5的字形編碼
  210.          if(set==2)  PORTD&=0x7f;//控制小數點亮
  211.          PORTC|=1<<PC4;//選中PC4
  212.          delay_ms(2);
  213.      PORTC&=0B00001111;//
  214. }
  215. else if(mode==2)
  216. {
  217.      PORTD=~smg_zx[nz_hour/10];  // 給5的字形編碼
  218.     PORTB|=1<<PB6;//選中PC6
  219.         delay_ms(2);
  220.         PORTB&=0B00111111;//
  221.
  222.
  223.     PORTD=~smg_zx[nz_hour%10];  // 給5的字形編碼
  224.         if(set==0)  PORTD&=0x7f;//控制小數點亮
  225.          PORTB|=1<<PB7;//選中PC7
  226.          delay_ms(2);
  227.      PORTB&=0B00111111;//
  228.
  229.
  230.
  231.      PORTD=~smg_zx[nz_min/10];  // 給5的字形編碼
  232.      PORTC|=1<<PC7;//選中PC7
  233.          delay_ms(2);
  234.          PORTC&=0B00001111;//
  235.
  236.
  237.      PORTD=~smg_zx[nz_min%10];  // 給5的字形編碼
  238.          if(set==1)  PORTD&=0x7f;//控制小數點亮
  239.          PORTC|=1<<PC6;//選中PC6
  240.          delay_ms(2);
  241.      PORTC&=0B00001111;//
  242.
  243. }
  244.    if((hour==nz_hour)&&(min==nz_min))//鬧鐘
  245.    {
  246.     if(zz++>20)
  247.         {
  248.      PORTB^=1<<PB5;//選中Pb5
  249.          zz=0;
  250.         }
  251.    }
  252.    else
  253.    PORTB|=1<<PB5;//選中Pb5
  254.
  255.
  256.          key ();
  257.
  258.
  259.
  260.    }
  261.   }
  262.    //T0中斷服務程序 //  2ms 進入中斷
  263.    #pragma interrupt_handler timer0_ocf_isr:20
  264.   void timer0_ocf_isr(void)
  265.   {static int count=0;
  266.    if(++count>=500)
  267.    { count=0;
  268.      sec++;
  269.          if(sec>=60)
  270.          {
  271.          sec=0;
  272.          min++;
  273.           if(min>=60)
  274.          {
  275.          min=0;
  276.          hour++;
  277.          hour%=24;
  278.          }
  279.          }
  280.    }
  281. }
仿真測試.rar (30.95 KB, 下載次數: 119)
ID:478073 發表于 2019-5-15 00:29 | 只看該作者
正找算開始整這個了,現在出來先看看路數
ID:665601 發表于 2019-12-17 22:10 | 只看該作者
這個的原理是什么呢
ID:668117 發表于 2019-12-19 11:00 | 只看該作者
這個niu
ID:850948 發表于 2020-12-8 17:08 | 只看該作者
請問按鍵是什么作用
