查看: 1696|回復(fù): 0
關(guān)于單片機(jī)LCD顯示程序,頻率計(jì)算問題
ID:536507 發(fā)表于 2019-5-13 09:54 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
         Init_Timer1();
        LCD_Init();
        LCD_Clear();
        LCD_Write_String(0,0,"  Capacitance   ");
        LCD_Write_String(0,1,"Cap:          UF");
                          if(k1==0){TR0=1;TR1=1;}
                          if(k2==0){asd=0;}
                          if(asd>1000000)
                          {LCD_Write_Char(5,1,q1[asd/100000000]);
                          LCD_Write_Char(6,1,q1[asd%100000000/10000000]);
                          LCD_Write_Char(7,1,q1[asd%10000000/1000000]);
                          LCD_Write_Char(8,1,'.');
                          LCD_Write_Char(9,1,q1[asd%1000000/100000]);
                          LCD_Write_Char(10,1,q1[asd%100000/10000]);
                          LCD_Write_Char(11,1,q1[asd%10000/1000]);
                          LCD_Write_Char(14,1,'U');
                          LCD_Write_Char(15,1,'F');}
                          LCD_Write_Char(5,1,q1[asd%1000000/100000]);
                          LCD_Write_Char(6,1,q1[asd%100000/10000]);
                          LCD_Write_Char(7,1,q1[asd%10000/1000]);
                          LCD_Write_Char(9,1,q1[asd%1000/100]);
                          LCD_Write_Char(10,1,q1[asd%100/10]);
                          LCD_Write_Char(11,1,q1[asd%10]);
                          LCD_Write_Char(14,1,'N');
void t0()  interrupt  1        using 1
            TH0=(65536-50000)/256;//重新賦值 10ms
     TL0=(65536-50000)%256;                  //1us
         i++;
         if(i==60) //使用三秒鐘采集
          {i=0;
                num=num1*65535+TH1*256+TL1;
           asd=470000000/num*3;
           TR0=0;TR1=0;
           num1=TH1=TL1=0;
void Timer1_isr(void) interrupt 3
TH1=0x00;              //重新給定初值
TL1=0x00;
num1++;
下面這三個(gè)程序分別是什么意思?
無效樓層,該帖已經(jīng)被刪除
無效樓層,該帖已經(jīng)被刪除
