單片機控制超聲波電路原理圖如下:
- #include <reg52.H> //器件配置文件
- #include <intrins.h>
- #include "ds18b20.h"
- sbit RX = P1^5;
- sbit TX = P1^4;
- sbit BEEP = P3^4;
- sbit LCM_RW = P3^6; //定義LCD引腳
- sbit LCM_RS = P3^7;
- sbit LCM_E = P3^5;
- #define LCM_Data P2
- #define Busy 0x80 //用于檢測LCM狀態字中的Busy標識
- void LCMInit(void);
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
- void Delay5Ms(void);
- void Delay400Ms(void);
- void Decode(unsigned char ScanCode);
- void WriteDataLCM(unsigned char WDLCM);
- void WriteCommandLCM(unsigned char WCLCM,BuysC);
- unsigned char ReadDataLCM(void);
- unsigned char ReadStatusLCM(void);
- unsigned char code Cls[] = {" "};
- unsigned char code ASCII[16] = {'0','1','2','3','4','5','6','7','8','9','.','-','M','C',' '};
- static unsigned char DisNum = 0; //顯示用指針
- unsigned int time=0;
- unsigned long S=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- //寫數據
- ReadStatusLCM(); //檢測忙
- LCM_Data = WDLCM;
- LCM_RS = 1;
- LCM_RW = 0;
- LCM_E = 0; //若晶振速度太高可以在這后加小的延時
- LCM_E = 0; //延時
- LCM_E = 1;
- //寫指令
- void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
- if (BuysC) ReadStatusLCM(); //根據需要檢測忙
- LCM_Data = WCLCM;
- LCM_RS = 0;
- LCM_RW = 0;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- //讀數據
- LCM_RS = 1;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- return(LCM_Data);
- //讀狀態
- LCM_Data = 0xFF;
- LCM_RS = 0;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- while (LCM_Data & Busy); //檢測忙信號
- return(LCM_Data);
- void LCMInit(void) //LCM初始化
- LCM_Data = 0;
- WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
- WriteCommandLCM(0x08,1); //關閉顯示
- WriteCommandLCM(0x01,1); //顯示清屏
- WriteCommandLCM(0x06,1); // 顯示光標移動設置
- WriteCommandLCM(0x0F,1); // 顯示開及光標設置
- //按指定位置顯示一個字符
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
- X |= 0x80; //算出指令碼
- WriteCommandLCM(X, 1); //發命令字
- WriteDataLCM(DData); //發數據
- //按指定位置顯示一串字符
- unsigned char ListLength;
- ListLength = 0;
- Y &= 0x1;
- while (DData[ListLength]>0x19) //若到達字串尾則退出
- if (X <= 0xF) //X坐標應小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
- ListLength++;
- X++;
- //5ms延時
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //400ms延時
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- void Conut(void)
- int TEMP;
- time=TH0*256+TL0;
- TH0=0;
- TL0=0;
- TEMP=ReadTemperature();
- S=(time/2.0*(331.45+0.61*TEMP/10))/1000.0; //算出來是MM
- if((S>=7000)||flag==1) //超出測量范圍顯示“-”
- flag=0;
- DisplayOneChar(0, 0, ASCII[11]);
- DisplayOneChar(1, 0, ASCII[10]); //顯示點
- DisplayOneChar(2, 0, ASCII[11]);
- DisplayOneChar(3, 0, ASCII[11]);
- DisplayOneChar(4, 0, ASCII[11]);
- DisplayOneChar(5, 0, ASCII[12]); //顯示M
- else
- if(S<1000)
- BEEP=1;
- else
- BEEP=0;
- disbuff[0]=S/1000;
- disbuff[1]=S/100%10;
- disbuff[2]=S/10%10;
- disbuff[3]=S%10;
- DisplayOneChar(0, 0, ASCII[disbuff[0]]);
- DisplayOneChar(2, 0, ASCII[disbuff[1]]);
- DisplayOneChar(3, 0, ASCII[disbuff[2]]);
- DisplayOneChar(4, 0, ASCII[disbuff[3]]);
- DisplayOneChar(6, 0, ASCII[14]);
- DisplayOneChar(7, 0, ASCII[TEMP/100]);
- DisplayOneChar(8, 0, ASCII[(TEMP/10)%10]);
- DisplayOneChar(9, 0, ASCII[10]);
- DisplayOneChar(10, 0, ASCII[TEMP%10]);
- DisplayOneChar(11, 0, ASCII[13]);
- void zd0() interrupt 1 //T0中斷用來計數器溢出,超過測距范圍
- flag=1; //中斷溢出標志
- RX=0;
- void StartModule() //啟動模塊
- TX=1; //啟動一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- TX=0;
- void Timer_Count(void)
- TR0=1; //開啟計數
- while(RX); //當RX為1計數并等待
- TR0=0; //關閉計數
- Conut(); //計算
- void delayms(unsigned int ms)
- unsigned char i=100,j;
- for(;ms;ms--)
- while(--i)
- j=10;
- while(--j);
- void main(void)
- unsigned int valA;
- //unsigned char TempCyc;
- BEEP=0;
- Delay400Ms(); //啟動等待,等LCM講入工作狀態
- LCMInit(); //LCM初始化
- Delay5Ms(); //延時片刻(可不要)
- ReadDataLCM();//測試用句無意義
- DisplayListChar(0, 1, Cls);
- TMOD=0x01; //設T0為方式1,GATE=1;
- TH0=0;
- TL0=0;
- ET0=1; //允許T0中斷
- EA=1; //開啟總中斷
- while(1)
- delayms(60);
- RX=1;
- StartModule();
- for(valA=7510;valA>0;valA--)
- if(RX==1)
- Timer_Count();
超聲波_LCD_51_溫度補償.7z
(2.64 MB, 下載次數: 22)
2019-5-10 19:25 上傳
