基于51單片機和Proteus仿真的數字示波器
#include <AT89X52.h>
#include <intrins.h>
//12864控制引腳定義
sbit DI = P2 ^ 2; //數據\指令選擇引腳
sbit RW = P2 ^ 1; //讀\寫選擇引腳
sbit E= P2 ^ 0; //讀\寫使能引腳
sbit CS1 = P2 ^ 4; //片選1引腳
sbit CS2 = P2 ^ 3; //片選2引腳
sbit BUSY= P1 ^ 7; //忙標志位
//按鍵控制定義
sbit Y1 = P3 ^ 0;
sbit Y2 = P3 ^ 1;
sbit X1 = P3 ^ 3;
sbit X2 = P3 ^ 7;
//ADC0832控制引腳
sbit START=P3^4;
sbit OE=P3^6;
sbit EOC=P3^5;
unsigned int ADdata; //AD采集值
unsigned int Ldata;
unsigned char ye,lei,shu;
unsigned char ADViewdata[91]; //AD顯示數據存儲區
char code FrameData[]={ //提示字符存儲區
0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x01,0x00,
0x01,0x00,0x11,0x10,0x11,0x08,0x21,0x04,0x41,0x02,0x81,0x02,0x05,0x00,0x02,0x00, //示
0x00,0x20,0x20,0x20,0x10,0x20,0x13,0xFE,0x82,0x22,0x42,0x24,0x4A,0x20,0x0B,0xFC,
0x12,0x84,0x12,0x88,0xE2,0x48,0x22,0x50,0x22,0x20,0x24,0x50,0x24,0x88,0x09,0x06, //波
0x00,0x00,0x3E,0x7C,0x22,0x44,0x22,0x44,0x3E,0x7C,0x01,0x20,0x01,0x10,0xFF,0xFE,
0x02,0x80,0x0C,0x60,0x30,0x18,0xC0,0x06,0x3E,0x7C,0x22,0x44,0x22,0x44,0x3E,0x7C, //器
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //" "
//AD轉換軟件
void ADCChage()
START=1;
START=0;
while(EOC==0) //等待轉換完成
OE=1;
ADdata = P0; //讀取AD數據
OE=0;
//檢查12864液晶狀態
void CheckState()
DI=0;
RW=1;
do
E=1;
E=0;
//僅當第7位為0時才可操作(判別busy信號)
}while(BUSY==1);
//向12864寫入一個字節的命令
void WriteCommand(unsigned char cmd)
CheckState(); //檢查當前的12864狀態
DI = 0;
RW = 0;
P1 = cmd; //送出相應的命令
E = 1;
E = 0;
//向12864寫入一個字節的數據
void WriteData(unsigned char dat)
DI = 1;
RW = 0;
P1 = dat; //送出相應的數據
E = 1;
E = 0;
//12864液晶的選擇控制引腳
void LCMCSControl(unsigned int csl)
if(csl==1) //根據參數不同判斷當前的12864控制引腳狀態
CS1=0,
CS2=1;
if(csl==2)
CS1=1,
CS2=0;
if(csl==3)
CS1=0,
CS2=0;
//12864顯示函數
void LCMView()
LCMCSControl(Ldata); //先發送控制命令
WriteCommand(ye);
WriteCommand(lei);
WriteData(shu); //然后發送數據
//12864的清屏函數
void CleanScreen()
unsigned char page,i;
LCMCSControl(3);
for(page=0xb8;page<=0xbf;page++)
WriteCommand(page);
WriteCommand(0x40);
for(i=0;i<64;i++)
WriteData(0x00);
LCMCSControl(1);
lei=0x40;
for(ye=0xb8;ye<0xbf;ye++)
shu=0xff;
LCMView();
ye=0xb8;
for(lei=0x40;lei<=0x7f;lei++)
shu=0x80;
LCMView();
ye=0xbf;
shu=0x01;
LCMView();
LCMCSControl(2);
ye=0xb8;
for(lei=0x40;lei<=0x5b;lei++)
shu=0x80;
LCMView();
ye=0xbf;
shu=0x01;
LCMView();
lei=0x5b;
for(ye=0xb9;ye<=0xbe;ye++)
shu=0xff;
LCMView();
//12864的初始化函數
void InitLCM(void)
WriteCommand(0xc0);
WriteCommand(0x3f);
//50us的延時函數
void Delay50us(unsigned int t)
unsigned char j;
for(;t>0;t--)
for(j=19;j>0;j--);
//刷新12864液晶
void RefreshLCM()
unsigned char i;
for(i=0xb9;i<=0xbe;i++)
ye=i;
shu=0x00;
LCMView();
//主函數
unsigned int r,j,q,k;
unsigned int Xaxis =0;
unsigned int Yaxis = 1;
unsigned char l;
unsigned char d1,d2,d3,d4,d5;
CleanScreen();
InitLCM();
LCMCSControl(2);
l=0xb8;
for(k=0;k<4;k++,l=l+0x02) //首先顯示右側的提示
ye=l;
lei=0x70;
for(r=0;r<16;r++)
shu=FrameData[2*r+1+32*k];
LCMView();
lei++;
ye=l+0x01;
lei=0x70;
for(r=0;r<16;r++)
shu=FrameData[2*r+32*k];
LCMView();
lei++;
while(X2==0) //調節X軸
while(X2==0);
Xaxis = Xaxis + 1;
while(X1==0)
while(X1==0);
if(Xaxis!=0)
Xaxis = Xaxis - 1;
while(Y1==0) //調節Y軸
while(Y1==0);
Yaxis = Yaxis + 1;
while(Y2==0)
while(Y2==0);
if(Yaxis!=1)
Yaxis=Yaxis-1;
for(j=0;j<90;j++) //AD采樣最大值
ADCChage();
ADViewdata[j]=ADdata;
if(ADViewdata[j]>ADViewdata[91])
ADViewdata[91]=ADViewdata[j];
Delay50us(Xaxis);
while(ADdata!=ADViewdata[91]) //如果采集值不相等,則繼續
ADCChage();
for(j=0;j<90;j++) //連續采樣90次
ADCChage();
Delay50us(Xaxis);
lei=0x41;
for(r=0,j=0;r<90;r++,j++)
if(j<63)
Ldata=1;
if(j==63)
lei=0x40;
if(j>=63)
Ldata=2;
RefreshLCM(); //刷新當前顯示
if(ADViewdata[j>=127])//正電壓
ADdata=(ADViewdata[j]-127)*0.196/Yaxis; //計算電壓值
if(ADdata<=7)
ye=0xbb;
shu=(0x80>>ADdata);
else if(ADdata<=15)
ye=0xba;
shu=(0x80>>(ADdata-8));
else if(ADdata<=23)
ye=0xb9;
shu=(0x80>>(ADdata-16));
else if(ADdata<=31)
ye=0xb9;
shu=(0x80>>(ADdata-24));
if(ADViewdata[j]<127) //負電壓
ADdata=(127-ADViewdata[j])*0.196/Yaxis; //計算電壓值
if(ADdata<=7)
ye=0xbc;
shu=(0x01<<(ADdata));
else if(ADdata<=15)
ye=0xbd;
shu=(0x01<<(ADdata-8));
else if(ADdata<=23)
ye=0xbe;
shu=(0x01<<(ADdata-16));
else if(ADdata<=31)
ye=0xbe;
shu=(0x01<<(ADdata-24));
if(r==0)//判斷正負
d1=shu;
d2=ye;
if(r!=0)
d3=shu;
d4=ye;
if(ye==d2) //如果相等,則判斷是否顯示完成
if(shu>d1)
d5=shu;
d5=d5>>1;
while(d5!=d1)
d5=d5>>1;
shu=shu|(shu>>1);
if(shu<d1)
d5=shu;
d5=d5<<1;
while(d5!=d1)
d5=d5<<1;
shu=shu|(shu<<1);
if(ye<d2)
for(q=0;q<7;q++)
shu=shu|(shu<<1);
LCMView();
ye++;
while(ye<d2)
shu=0xff;
LCMView();
ye++;
if(ye==d2)
shu=0x01;
if(shu<d1)
d5=shu;
d5=d5<<1;
while(d5!=d1)
d5=d5<<1;
shu=shu|(shu<<1);
if(ye>d2)
for(q=0;q<7;q++)
shu=shu|(shu>>1);
LCMView();
ye--;
while(ye>d2) {shu=0xff,LCMView(),ye--;}
if(ye==d2)
shu=0x80;
if(shu>d1)
d5=shu;
d5=d5>>1;
while(d5!=d1)
d5=d5>>1;
shu=shu|(shu>>1);
if(r!=0)
d1=d3;
d2=d4;
LCMView();
if(lei!=0x7f)
lei++;
Keil代碼與Proteus7.5版本的dsn文件下載:
基于51單片機和Proteus仿真的數字示波器.zip
(81.01 KB, 下載次數: 420)
2019-5-9 17:24 上傳
