查看: 4638|回復: 3
基于51單片機和Proteus仿真的手動程控放大器
#include <AT89X52.h>
#include <intrins.h>
sbit sbF1 = P2 ^ 0;   //不進行放大處理
sbit sbF20 = P2 ^ 1;  //放大20倍
sbit sbF30 = P2 ^ 2;  //放大30倍
sbit sbF50 = P2 ^ 3;  //放大50倍
sbit sbDIN = P3 ^ 0;                        //MAX7219的數據引腳
sbit sbLOAD = P3 ^ 1;                      //MAX7219的控制引腳
sbit sbCLK = P3 ^ 2;                       //MAX7219的時鐘引腳
//顯示緩沖區定義
unsigned char Disp_Buffer[8]=            //MAX7219的輸出緩沖
        0,0,0,0,0,0,0,0
unsigned char Disp_Buffer1[8]=            //MAX7219的輸出緩沖
        0,0,0,0,0,0,0,1
unsigned char Disp_Buffer20[8]=            //MAX7219的輸出緩沖
        0,0,0,0,0,0,2,0
unsigned char Disp_Buffer30[8]=            //MAX7219的輸出緩沖
        0,0,0,0,0,0,3,0
unsigned char Disp_Buffer50[8]=            //MAX7219的輸出緩沖
        0,0,0,0,0,0,5,0
void DelayMS(unsigned int ms)              //毫秒級延時函數
        unsigned int i,j;
        for( i=0;i<ms;i++)
                for(j=0;j<1141;j++);
//寫MAX7219函數,Addr為MAX7219的內部寄存器地址,Dat為待寫入的數據
void Write7219(unsigned char Addr,unsigned char Dat)
        unsigned char i;
        sbLOAD = 0;
        for(i=0;i<8;i++)                               //先送出8位地址
                 sbCLK = 0;                                   //時鐘拉低
                Addr <<= 1;                                  //移位送出地址
                sbDIN        = CY;                                    //送出數據
                sbCLK = 1;                                   //時鐘上升沿
                _nop_();
                _nop_();
                sbCLK = 0;
        for(i=0;i<8;i++)                              //再送出8位數據
                 sbCLK = 0;
                Dat <<= 1;                                  //移位送出數據
                sbDIN        = CY;
                sbCLK = 1;
                _nop_();
                _nop_();
                sbCLK = 0;
        sbLOAD = 1;
//MAX7129的初始化函數
void Initialise7219()
        Write7219(0x09,0xff);                 //編碼模式寄存器
        Write7219(0x0a,0x07);                 //顯示亮度控制
        Write7219(0x0b,0x07);                 //掃描控制
        Write7219(0x0c,0x01);                 //關閉模式控制寄存器設置
void  Wobbling ()   //延時程序防止按鍵抖動
  unsigned int i;
  for(i=0;i<1000;i++);
  unsigned char i;
        Initialise7219();                     //首先初始化MAX7129
        DelayMS(1);                         //延時1毫秒
  for(i=0;i<8;i++)
                 Write7219(i+1,Disp_Buffer[i]);      //將顯示緩沖區內的數據循環送出
  P1 = 0x00;    //初始化端口
  P2 = 0xFF;
  P1 = 0x11;   //再不按鍵的情況下默認為不進行放大處理
  if (sbF1 == 0) //判斷是否按下按鍵
    Wobbling();   //時間延時程序,軟件防抖動
    if( sbF1 == 0)  //確定按下按鍵
      P1 = 0x11;   //放大1倍
      for(i=0;i<8;i++)
                     Write7219(i+1,Disp_Buffer1[i]);      //顯示放大1倍
  if(sbF20 == 0)  //判斷是否按下按鍵
    if(sbF20 == 0) //確定按下按鍵
      P1 = 0x22;   //放大20倍
      for(i=0;i<8;i++)
                     Write7219(i+1,Disp_Buffer20[i]);      //顯示放大20倍
  if(sbF30 == 0) //判斷是否按下按鍵
    if(sbF30 == 0) //確定按下按鍵
      P1 = 0x44;   //放大30倍
      for(i=0;i<8;i++)
                     Write7219(i+1,Disp_Buffer30[i]);      //顯示放大20倍
  if(sbF50 == 0) //判斷是否按下按鍵
    if(sbF50 == 0)//確定按下按鍵
      P1=0x88;  //放大50倍
      for(i=0;i<8;i++)
                     Write7219(i+1,Disp_Buffer50[i]);      //顯示放大20倍
基于51單片機和Proteus仿真的手動程控放大器.zip
73.67 KB, 下載次數: 74, 下載積分: 黑幣 -5
ID:207534 發表于 2020-5-12 11:04 來自觸屏版 | 只看該作者
為啥放大倍數好像只有幾倍
ID:771983 發表于 2020-6-30 09:30 來自觸屏版 | 只看該作者
圖不行啊
ID:806551 發表于 2021-10-13 16:21 | 只看該作者
為啥放大倍數好像只有幾倍
