基于51單片機和Proteus仿真的SD卡讀卡器,包含C語言源程序及Proteus仿真電路圖,親測完全可用,部分代碼如下,全部代碼見附件
#include <AT89X52.H>
#define F_OSC 11059200//晶振平率Hz
#define F_BAUD 9600
#define RELOAD 256-F_OSC/12/32/F_BAUD
#define CR 0x0D //回車
//定義SD卡需要的4根信號線
sbit SD_CLK = P1^4;
sbit SD_DI = P1^6;
sbit SD_DO = P1^5;
sbit SD_CS = P1^7;
unsigned char xdata DATA[512];
//定義512字節緩沖區,注意需要使用 xdata關鍵字
//寫一字節到SD卡,模擬SPI總線方式
void SdWrite(unsigned char n)
unsigned char i;
for(i=8;i;i--)
SD_CLK=0;
SD_DI=(n&0x80);
n<<=1;
SD_CLK=1;
SD_DI=1;
//從SD卡讀一字節,模擬SPI總線方式
unsigned char SdRead()
unsigned char n,i;
for(i=8;i;i--)
SD_CLK=0;
SD_CLK=1;
n<<=1;
if(SD_DO) n|=1;
return n;
//檢測SD卡的響應
unsigned char SdResponse()
unsigned char i=0,response;
while(i<=8)
response = SdRead();
if(response==0x00)
break;
if(response==0x01)
break;
i++;
return response;
//發命令到SD卡
void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
SdWrite(command|0x40);
SdWrite(((unsigned char *)&argument)[0]);
SdWrite(((unsigned char *)&argument)[1]);
SdWrite(((unsigned char *)&argument)[2]);
SdWrite(((unsigned char *)&argument)[3]);
SdWrite(CRC);
//初始化SD卡
unsigned char SdInit(void)
int delay=0, trials=0;
unsigned char i;
unsigned char response=0x01;
SD_CS=1;
for(i=0;i<=9;i++)
SdWrite(0xff);
SD_CS=0;
//Send Command 0 to put MMC in SPI mode
SdCommand(0x00,0,0x95);
response=SdResponse();
if(response!=0x01)
return 0;
while(response==0x01)
SD_CS=1;
SdWrite(0xff);
SD_CS=0;
SdCommand(0x01,0x00ffc000,0xff);
SD_CS=1;
SdWrite(0xff);
return 1;
//往SD卡指定地址寫數據,一次最多512字節
unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
unsigned char dataResp;
//Block size is 512 bytes exactly
//First Lower SS
SD_CS=0;
//Then send write command
SdCommand(0x18,address,0xff);
if(SdResponse()==00)
SdWrite(0xff);
SdWrite(0xff);
SdWrite(0xff);
//command was a success - now send data
//start with DATA TOKEN = 0xFE
SdWrite(0xfe);
//now send data
for(count=0;count<len;count++) SdWrite(*Block++);
for(;count<512;count++) SdWrite(0);
//data block sent - now send checksum
SdWrite(0xff); //兩字節CRC校驗, 為0XFFFF 表示不考慮CRC
SdWrite(0xff);
//Now read in the DATA RESPONSE token
dataResp=SdRead();
//Following the DATA RESPONSE token
//are a number of BUSY bytes
//a zero byte indicates the MMC is busy
while(SdRead()==0);
dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token
SD_CS=1;
SdWrite(0xff);
if(dataResp==0x0b)
//printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n");
return 0;
if(dataResp==0x05)
return 1;
//printf("Invalid data Response token.\n");
return 0;
//printf("Command 0x18 (Write) was not received by the MMC.\n");
return 0;
//從SD卡指定地址讀取數據,一次最多512字節
unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
//First Lower SS
//printf("MMC_read_block\n");
SD_CS=0;
SdCommand(0x11,address,0xff);
while(SdRead()!=0xfe);
for(count=0;count<len;count++) *Block++=SdRead();
for(;count<512;count++) SdRead();
SdRead();
SdRead();
SD_CS=1;
SdRead();
return 1;
//printf("Command 0x11 (Read) was not received by the MMC.\n");
return 0;
串口初始化
void UART()
SCON=0x40;//工作與方式1不允許接受
TMOD=0x20;//定時器1工作與方式2自動重裝模式
TH1=RELOAD;
TR1=1;
TI=0;
//通過串口發送一個字符串
void Sen_String(unsigned char *string)
while(*string!='\0')
if(*string=='\n')
SBUF=CR;
SBUF=*string;
while(TI==0);
TI=0;
string++;
UART();
while(!SdInit()); //等待SD卡初始化完成
SdWriteBlock("THIS IS A TEST!",0x000000,15);//寫入字符串,然后讀出進行檢驗
SdReadBlock(DATA,0x000000,15);
Sen_String(DATA); //發出數據
全部資料51hei下載地址:
基于51單片機和Proteus仿真的SD卡讀卡器.zip
(215.48 KB, 下載次數: 186)
2019-5-9 16:22 上傳
