這是我之前做的用STC89C516單片機芯片做的控制6188藍牙模塊的程序
都是自己原創的,還有很多不是很完善的地方(比如按鍵響應有點長了點)
- #include<reg51.h>
- #include"lcd.h"
- typedef unsigned int u16; //對數據類型進行聲明定義
- typedef unsigned char u8;
- #define GPIO_KEY P1
- #define U8 u8
- #define U16 u16
- #define K_PLAY 0x01//F
- #define K_PREV 0x02//B
- #define K_NEXT 0x03//7
- #define Bt_PlayPause_Cmd "MA" //音樂播放\暫停 AT+MA\r\n
- #define Bt_Stop_Cmd "MC" //音樂停止 AT+MC\r\n
- #define Bt_Next_Cmd "MD" //下一曲 AT+MD\r\n
- #define Bt_Previous_Cmd "ME" //上一曲 AT+ME\r\n
- #define TxLEN_MAX 16
- #define RxLEN_MAX 36
- #define MAX_INFO_NUM 0x0A
- #define MAX_INFO_LEN 5
- bit btlink = 0;
- xdata U8 UartRxBuf[RxLEN_MAX];
- xdata U8 UartRxIdx;
- xdata U8 UartTimeout;
- xdata U8 UartTxBuf[TxLEN_MAX+1];
- xdata U8 UartTxIdx;
- xdata U8 UartTxLen;
- #define UARTRI 0X01
- #define UARTTI 0X02
- #define UART_RI 0X01
- #define UART_TI 0X02
- unsigned char KeyValue;
- unsigned char dg_ram1=0,dg_ram2 = 0;
- //用來存放讀取到的鍵值
- unsigned char KeyState;
- //用來存放按鍵狀態
- unsigned char PuZh[]=" Pechin Science ";
- unsigned char dat[]="0123456789ABCDEF";
- void Delay10ms(); //延時50us
- void KeyDown(); //檢測按鍵函數
- * 函 數 名 : main
- * 函數功能 : 主函數
- * 輸 入 : 無
- * 輸 出 : 無
- void scan_key(void);
- void uart_cmd(U8 *cmd);
- void UsartInit()
- SCON=0X50; //設置為工作方式1
- TMOD=0X20; //設置計數器工作方式2
- PCON=0X00;//0x80; //0x80是波特率加倍波特率變19200
- TH1=0XFD;//D;//3; //計數器初始值設置
- TL1=0XFD;//D;//3;
- ES=1; //打開接收中斷
- EA=1; //打開總中斷
- TR1=1; //打開計數器
- code U8 _bt_info[MAX_INFO_NUM][2] = { {'I', 'I'}, // A connect A2DP
- {'M', 'A'}, // music pause
- {'M', 'B'}, // music play
- {'C', '1'},
- {'C', '0'},
- {'I', 'A'},
- };// 通話中
- void uart_dat(void)
- if(UartTimeout)
- if(UartTimeout>2)
- UartTimeout=0x80;
- else
- UartTimeout++;
- if(UartRxIdx>=0x80)
- U8 j;
- for(j=0; j<MAX_INFO_NUM; j++)
- dg_ram1++;
- if(dg_ram1>0x0f)
- dg_ram1 = 0;
- if ((_bt_info[j][0] == UartRxBuf[0])||(_bt_info[j][1] == UartRxBuf[1])||(0x0d == UartRxBuf[2]))
- dg_ram2 = j;
- break;
- if(j < 4)
- btlink = 1;
- else if(j < MAX_INFO_NUM)
- btlink = 0;
- UartRxIdx = 0;
- if(UartTimeout>=0x80)
- UartTimeout = 0;
- UartRxIdx = 0x00;
- if(dg_ram2>0x0f)
- dg_ram2 = 0;
- void main(void)
- unsigned char i;
- LcdInit();
- UsartInit();
- UartTxIdx = 0;
- UartTxLen = 0;
- UartRxIdx = 0;
- UartTimeout = 0;
- KeyState=0;
- for(i=0;i<16;i++)
- LcdWriteData(PuZh[i]);
- while(1)
- // UsartInit();
- uart_dat();
- KeyDown();
- scan_key();
- if(KeyState)
- KeyState=0;
- LcdWriteCom(0x80+0x40);
- LcdWriteData(dat[KeyValue]);
- * 函 數 名 : KeyDown
- * 函數功能 : 檢測有按鍵按下并讀取鍵值
- * 輸 入 : 無
- * 輸 出 : 無
- void KeyDown(void)
- char a;
- GPIO_KEY=0x0f;
- if(GPIO_KEY!=0x0f)
- Delay10ms();
- KeyState=1;
- //測試列
- GPIO_KEY=0X0F;
- // Delay10ms();
- switch(GPIO_KEY)
- case(0X07): KeyValue=0;break;
- case(0X0b): KeyValue=1;break;
- case(0X0d): KeyValue=2;break;
- case(0X0e): KeyValue=3;break;
- // default: KeyValue=17; //檢測出錯回復17意思是把數碼管全滅掉。
- //測試行
- GPIO_KEY=0XF0;
- Delay10ms();
- switch(GPIO_KEY)
- case(0X70): KeyValue=KeyValue;break;
- case(0Xb0): KeyValue=KeyValue+4;break;
- case(0Xd0): KeyValue=KeyValue+8;break;
- case(0Xe0): KeyValue=KeyValue+12;break;
- while((a<100)&&(GPIO_KEY!=0xf0)) //檢測按鍵松手檢測
- Delay10ms();
- a++;
- a=0;
- U8 Uart1TxData(U8 *dat, U8 len)
- U8 i;
- if(UartTxIdx == UartTxLen)
- for(i=0; i<len; i++)
- UartTxBuf[i] = *(dat+i);
- UartTxIdx = 0x0;
- UartTxLen = len;
- SCON &= ~UARTTI; //清TI
- SBUF = *dat; //輸入寫入緩存后硬件自動發送
- return 1;
- else
- return 0;
- U8 cmdbuf[7];
- cmdbuf[0] = 'A';
- cmdbuf[1] = 'T';
- cmdbuf[2] = '+';
- cmdbuf[3] = cmd[0];
- cmdbuf[4] = cmd[1];
- cmdbuf[5] = 0x0d;
- cmdbuf[6] = 0x0a;
- Uart1TxData(cmdbuf, 7);
- if(KeyState)
- switch(KeyValue)
- case K_PREV:
- if(1)
- uart_cmd(Bt_Previous_Cmd);
- break;
- ////////////////////////////下一曲/////////////////////////////////////////
- case K_NEXT:
- if(1)
- uart_cmd(Bt_Next_Cmd);
- break;
- ////////////////////////////播放暫停////////////////////////////////////////
- case K_PLAY:
- if(1)
- uart_cmd(Bt_PlayPause_Cmd);
- break;
- default:
- break;
- void Usart() interrupt 4
- u8 cchr;
- if(RI==1)//接收的中斷
- cchr = SBUF;
- UartTimeout = 1;
- if(UartRxIdx<MAX_INFO_LEN)
- UartRxBuf[UartRxIdx++] = cchr;
- if(cchr == 0x0A)
6199藍牙模塊ok的 - 副本.rar
(1002.5 KB, 下載次數: 14)
2019-5-9 12:22 上傳
下載積分: 黑幣 -5
