查看: 1489|回復: 0
DHT11溫濕度傳感模塊
ID:254412 發表于 2019-5-8 15:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
溫濕度傳感模塊51單片機串口發送
#include <reg51.h>
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點數(32位長度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點數(64位長度) */
#define Data_0_time 4
//----------------IO口定義區--------------------//
sbit P2_0 = P3^7 ;//DATA
sbit P2_1 = P2^1 ;
sbit P2_2 = P2^2 ;
sbit P2_3 = P2^3 ;
//----------------定義區--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定義發送的字節數
U8 indata[5];
U8 count, count_r=0;
U8 str[5]={"RS232"};
U16 U16temp1,U16temp2;
DHT11.rar
2.12 KB, 下載次數: 7, 下載積分: 黑幣 -5
源碼
