查看: 2940|回復: 4
STM32利用DMA+TIME+ADC產生正玄波程序
ID:530366 發表于 2019-5-8 14:32 | 顯示全部樓層 |閱讀模式
  * @file DAC/DualModeDMA_SineWave/main.c
  * @author  MCD Application Team
  * @version  V3.0.0
  * @date  04/06/2009
  * @brief  Main program body.
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "LED.h"
/** @addtogroup StdPeriph_Examples
/** @addtogroup DAC_DualModeDMA_SineWave
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define DAC_DHR12R1       0x40007408
#define DAC_DHR12R2              0x40007414
#define Sin_Out_500Hz          0x8B6
#define Sin_Out_1KHz            0x456
#define Sin_Out_2KHz            0x235
#define Sin_Out_3KHz            0x17A
#define Sin_Out_4KHz            0x119
#define Sin_Out_5KHz            0xE0
#define Sin_Out_10KHz            0x6F
#define Sin_Out_15KHz            0x4A
/* Init Structure definition */
DAC_InitTypeDef            DAC_InitStructure;
DMA_InitTypeDef            DMA_InitStructure;
TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
/* Private macro -------------------------------------------------------------*/
/* Private variables --------------------------------------------------------- */
const uint16_t Sine12bit[258] = { 2048, 2098, 2148, 2198, 2248, 2298, 2348, 2398, 2447, 2496,
2545, 2594, 2642, 2690, 2737, 2785, 2831, 2877, 2923, 2968,
3013, 3057, 3100, 3143, 3185, 3227, 3267, 3307, 3347, 3385,
3423, 3460, 3496, 3531, 3565, 3598, 3631, 3662, 3692, 3722,
3750, 3778, 3804, 3829, 3854, 3877, 3899, 3920, 3940, 3958,
3976, 3992, 4007, 4021, 4034, 4046, 4056, 4065, 4073, 4080,
4086, 4090, 4093, 4095, 4095, 4095, 4093, 4090, 4086, 4080,
4073, 4065, 4056, 4046, 4034, 4021, 4007, 3992, 3976, 3958,
3940, 3920, 3899, 3877, 3854, 3829, 3804, 3778, 3750, 3722,
3692, 3662, 3631, 3598, 3565, 3531, 3496, 3460, 3423, 3385,
3347, 3307, 3267, 3227, 3185, 3143, 3100, 3057, 3013, 2968,
2923, 2877, 2831, 2785, 2737, 2690, 2642, 2594, 2545, 2496,
2447, 2398, 2348, 2298, 2248, 2198, 2148, 2098, 2047, 1997,
1947, 1897, 1847, 1797, 1747, 1697, 1648, 1599, 1550, 1501,
1453, 1405, 1358, 1310, 1264, 1218, 1172, 1127, 1082, 1038,
995, 952, 910, 868, 828, 788, 748, 710, 672, 635,
599, 564, 530, 497, 464, 433, 403, 373, 345, 317,
291, 266, 241, 218, 196, 175, 155, 137, 119, 103,
88, 74, 61, 49, 39, 30, 22, 15, 9, 5,
2, 0, 0, 0, 2, 5, 9, 15, 22, 30,
39, 49, 61, 74, 88, 103, 119, 137, 155, 175,
196, 218, 241, 266, 291, 317, 345, 373, 403, 433,
464, 497, 530, 564, 599, 635, 672, 710, 748, 788,
828, 868, 910, 952, 995, 1038, 1082, 1127, 1172, 1218,
1264, 1310, 1358, 1405, 1453, 1501, 1550, 1599, 1648, 1697,
1747, 1797, 1847, 1897, 1947, 1997 };
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void Delay(__IO uint32_t nCount);
void Delay_500ms()
u32 i,j;
for (i=0; i<0x125; i++)
for (j=0;j<3800;j++);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval : None
int main(void)
  /* System Clocks Configuration */
  RCC_Configuration();
  /* Once the DAC channel is enabled, the corresponding GPIO pin is automatically
     connected to the DAC converter. In order to avoid parasitic consumption,
     the GPIO pin should be configured in analog */
  GPIO_Configuration();
  LED_Init();
  /* TIM8 Configuration */
  /* Time base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = Sin_Out_2KHz;   //正弦波1頻率設置
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = Sin_Out_3KHz;   //正弦波2頻率設置
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* TIM8 TRGO selection */
  TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
  TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
  /* DAC channel1 Configuration */
  DAC_StructInit(&DAC_InitStructure);
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;         //指定DAC1的觸發定時器
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* DAC channel2 Configuration */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;         //指定DAC2的觸發定時器
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
  /* DMA2 channel2 configuration */
  DMA_DeInit(DMA2_Channel3);
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1; //指定DMA2通道3的目標地址為DAC1_DHR12R1
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Sine12bit;        //指定DMA的源地址為數組Sine12bit
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = 256;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA2_Channel3, &DMA_InitStructure);
  /* DMA2 channel3 configuration */
  DMA_DeInit(DMA2_Channel4);
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R2;        //指定DMA2通道3的目標地址為DAC2_DHR12R2
  DMA_Init(DMA2_Channel4, &DMA_InitStructure);
  /* Enable DMA2 Channel2 */
  DMA_Cmd(DMA2_Channel3, ENABLE);
  DMA_Cmd(DMA2_Channel4, ENABLE);
  /* Enable DAC Channel1: Once the DAC channel1 is enabled, PA.04 is
     automatically connected to the DAC converter. */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  /* Enable DAC Channel2: Once the DAC channel2 is enabled, PA.05 is
  DAC_Cmd(DAC_Channel_2, ENABLE);
  /* Enable DMA for DAC Channel1 */
  DAC_DMACmd(DAC_Channel_1, ENABLE);
  /* Enable DMA for DAC Channel2 */
  DAC_DMACmd(DAC_Channel_2, ENABLE);
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
  TIM_Cmd(TIM6, ENABLE);
  while (1)
    LED_R_ON(0);
    LED_B_ON(0);
    LED_G_ON(1);
        Delay_500ms();
        LED_R_ON(0);
          LED_B_ON(1);
          LED_G_ON(0);
        Delay_500ms();
          LED_R_ON(1);
          LED_B_ON(0);
         LED_G_ON(0);
        Delay_500ms();
        LED_R_ON(0);
          LED_B_ON(0);
         LED_G_ON(0);
        Delay_500ms();
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval : None
  /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
     initialize the PLL and update the SystemFrequency variable. */
  SystemInit();
/* Enable peripheral clocks --------------------------------------------------*/
  /* DMA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  /* GPIOA Periph clock enable */
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
  /* DAC Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* TIM8 Periph clock enable */
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM6, ENABLE);
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval : None
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  * @brief  Inserts a delay time.
  * @param nCount: specifies the delay time length.
  * @retval : None
  for(; nCount != 0; nCount--);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
全部資料51hei下載地址:
TwoChannels_SineWave.7z (153.99 KB, 下載次數: 23)
ID:532502 發表于 2019-5-10 14:50 | 顯示全部樓層
STM32不帶DA的吧?請問DA采用的什么芯片?
ID:530366 發表于 2019-5-12 16:59 | 顯示全部樓層
colinh 發表于 2019-5-10 14:50
STM32自帶DA的,可以直接輸出正弦波
ID:465802 發表于 2019-5-13 16:53 | 顯示全部樓層
下載了,先學習學習。
ID:465802 發表于 2019-5-13 17:00 | 顯示全部樓層
代碼里面缺少這個stm32f10x_lib.h文件呀
