查看: 5668|回復(fù): 7
前幾天做51單片機(jī)16X16點(diǎn)陣仿真程序
前幾天幫人做的設(shè)計--51單片機(jī)16X16點(diǎn)陣,直接上圖,勿噴!
附件是所有資料,有需要的隨便下載就行了!
單片機(jī)源程序如下:
  1. /**************************************************************************/
  2. /* 作品名稱:基于51單片機(jī)的16*16點(diǎn)陣設(shè)計
  3. /*  時  間 :2019年4月11日晚
  4. /**************************************************************************/
  5. #include <reg51.h>
  6. char code table[]={
  7. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  8. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",12*/
  9. 0x80,0x00,0x90,0x80,0x8C,0x80,0x84,0x84,0x84,0x46,0x84,0x49,0xF5,0x28,0x86,0x10,
  10. 0x84,0x10,0x84,0x2C,0x84,0x23,0x84,0x40,0x94,0x80,0x8C,0x00,0x80,0x00,0x00,0x00,//安,0
  11. 0x20,0x10,0x18,0x08,0x08,0x04,0x08,0x02,0x08,0xFF,0xC8,0x40,0x38,0x20,0xCF,0x00,
  12. 0x08,0x03,0x08,0x04,0x08,0x0A,0x08,0x11,0xA8,0x20,0x18,0x40,0x00,0x40,0x00,0x00,//農(nóng),1
  13. 0x20,0x22,0x30,0x67,0xAC,0x22,0x63,0x12,0x20,0x12,0x18,0x12,0x80,0x40,0x82,0x42,
  14. 0x42,0x42,0x22,0x42,0x12,0x7E,0x1A,0x42,0x26,0x42,0x42,0x42,0x80,0x40,0x00,0x00,//經(jīng),2
  15. 0x00,0x00,0x00,0x00,0xF8,0x1F,0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,0xFF,0x7F,
  16. 0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0xF8,0x9F,0x00,0x80,0x00,0xF0,0x00,0x00,//電,3
  17. 0x20,0x00,0x10,0x00,0x4C,0x00,0x47,0x00,0x54,0x00,0x54,0x00,0x54,0x00,0x54,0x00,
  18. 0x54,0x00,0x54,0x00,0x54,0x00,0xD4,0x0F,0x04,0x30,0x04,0x40,0x00,0xF0,0x00,0x00,//氣,4
  19. 0x00,0x10,0x00,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,
  20. 0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,0x00,0x10,0x00,0x10,0x00,0x00,//二,5
  21. 0x84,0x10,0x84,0x30,0xFC,0x1F,0x84,0x08,0x84,0x88,0x00,0x42,0xF8,0x21,0x00,0x18,
  22. 0xFF,0x07,0x00,0x00,0x84,0x20,0x84,0x20,0xFC,0x3F,0x84,0x20,0x84,0x20,0x00,0x00,//班,6
  23. //0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  24. //0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  25. //0x00,0x00,0xE0,0x00,0xF0,0x01,0xF8,0x03,0xFC,0x07,0xFC,0x0F,0xF8,0x1F,0xF0,0x3F,
  26. //0xF8,0x1F,0xFC,0x0F,0xFC,0x07,0xF8,0x03,0xF0,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  29. };
  30. void delay(int c)
  31.     {
  32.     int i,j;
  33.     for(i=0;i<c;i++)
  34.         for(j=0;j<10;j++)
  35.             ;
  36.      }
  37. void main()
  38.     {
  39.     unsigned char i,j;
  40.     unsigned int b=0;
  41.     unsigned char a;
  42.                 while(1)
  43.                     {
  44.                     j=0;
  45.                     if(a>80)
  46.                      {
  47.                         a=0;
  48.                         b+=32;
  49.                         if(b>=512-64-6*32)
  50.                             {
  51.                             b=0;
  52.                             }
  53.                       }
  54.                      P3=1;
  55.
  56.                      for(i=0;i<16;i++)
  57.                       {
  58.                         P1=i;
  59.                         P0=table[j+b];
  60.                         P2=table[j+b+1];
  61.                         delay(10);
  62.                         P0=0x00;
  63.                         P2=0x00;
  64.                         j+=2;
  65.                       }
  66.                      P3=0;
  67.
  68.                      for(i=0;i<16;i++)
  69.                       {
  70.                         P1=i;
  71.                         P0=table[j+b];
  72.                         P2=table[j+b+1];
  73.                         delay(10);
  74.                         P0=0x00;
  75.                         P2=0x00;
  76.                         j+=2;
  77.                       }
  78.                         a++;
  79.
  80.                     }
  81. }
16-16點(diǎn)陣.zip (59.17 KB, 下載次數(shù): 118)
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏5 分享淘帖 頂3 踩
ID:532069 發(fā)表于 2019-5-12 22:52 | 只看該作者
第8行和第9行是什么意思啊,我弄的LED一直顯示亂碼
ID:114694 發(fā)表于 2019-5-13 08:13 | 只看該作者
新手學(xué)習(xí)了,謝謝
ID:555212 發(fā)表于 2019-6-5 01:33 | 只看該作者
你這個P代表的是行,K代表的是列對吧?
ID:682977 發(fā)表于 2020-1-7 15:36 來自觸屏版 | 只看該作者
請問是什么仿真軟件?proteus嗎?
ID:704664 發(fā)表于 2020-3-8 19:11 | 只看該作者
小哥,代做16*16點(diǎn)陣滾動漢字嗎,原理和你的這個差不多一樣,就是protues里面用到的不是595,而是574,價錢可以商量哈
ID:861102 發(fā)表于 2020-12-16 09:10 | 只看該作者
你這個P代表的是行,K代表的是列對吧?
ID:843682 發(fā)表于 2021-1-29 21:35 | 只看該作者
能介紹一下,程序中變量 i,j ,b,a,都是什么意思嗎?謝謝了
