電子密碼鎖仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2019-4-29 16:37 上傳
- #include"lcd.h"
- //--定義使用的IO口--//
- #define KEY P3
- sbit BEEP=P2^6; //接蜂鳴器
- unsigned char mima[6]={1,2,3,4,5,6};
- unsigned char mima3[6]={6,5,4,3,2,1};
- unsigned char mima4[6]={7,7,7,7,7,7};
- unsigned char mima2[6];
- unsigned char state=0;
- unsigned char cuowu=0;
- unsigned char KeyValue;
- unsigned char KeyState; //記錄按鍵的狀態,0沒有,1有
- void TimerConfiguration();
- unsigned char Time=0;
- unsigned char sec=60;
- void KeyDown(); //檢測按鍵函數
- void Delay10ms(unsigned int c) //誤差 0us
- unsigned char a,b;
- for(;c>0;c--)
- for(b=38;b>0;b--)
- for(a=130;a>0;a--);
- void BZ()
- BEEP= 0;
- Delay10ms(100);
- BEEP= 1;
- void BZ2()
- BEEP= 0;
- Delay10ms(30);
- BEEP= 1;
- Delay10ms(30);
- BEEP= 0;
- Delay10ms(30);
- BEEP= 1;
- Delay10ms(30);
- BEEP= 0;
- Delay10ms(30);
- BEEP= 1;
- void main(void)
- unsigned char i=0;
- unsigned char j=0;
- KeyState=0;
- TimerConfiguration();
- LcdInit();
- while(1)
- if(state==0)
- LcdWriteCom(0x01);
- LCDWrite_String(0, 0, 16, "Shu ru mi ma:");
- LCDWrite_String(4, 1, 6, " ");
- while(state==0)
- KeyDown();
- if((KeyState==1))
- if((KeyValue<10)&&(i<6))
- LcdWriteCom(0xc4+i);
- LcdWriteData('*');
- mima2[i]=KeyValue;
- i++;
- if((i==6)&&(KeyValue==15))
- if(
- ((mima2[0]==mima[0])
- &&(mima2[1]==mima[1])
- &&(mima2[2]==mima[2])
- &&(mima2[3]==mima[3])
- &&(mima2[4]==mima[4])
- &&(mima2[5]==mima[5]))
- ||((mima2[0]==mima3[0])
- &&(mima2[1]==mima3[1])
- &&(mima2[2]==mima3[2])
- &&(mima2[3]==mima3[3])
- &&(mima2[4]==mima3[4])
- &&(mima2[5]==mima3[5]))
- ||((mima2[0]==mima4[0])
- &&(mima2[1]==mima4[1])
- &&(mima2[2]==mima4[2])
- &&(mima2[3]==mima4[3])
- &&(mima2[4]==mima4[4])
- &&(mima2[5]==mima4[5]))
- LCDWrite_String(4, 1, 6, " Kai!");
- BZ();
- else
- LCDWrite_String(4, 1, 6, "Cuowu!");
- BZ2();
- cuowu++;
- if(cuowu>=3)
- state=1;
- cuowu=0;
- ET0 = 1;TR0 = 1; //打開定時器0中斷//啟動定時器0
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- if(KeyValue==14)
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- if(KeyValue==13) //qingling
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- if(KeyValue==12) //shemoima
- state=2;
- KeyState=0;
- if(state==1)
- LCDWrite_String(0, 0, 16, "Please wait!... ");
- while(state==1)
- BZ2();
- LcdWriteCom(0xc4);
- LcdWriteData('0'+sec/10%10);
- LcdWriteData('0'+sec%10);
- if(state==3)
- LCDWrite_String(3, 0, 16, "WARRING... ");
- while(state==3);
- if(state==2)
- LCDWrite_String(0, 0, 16, "Jiu mima :");
- while(state==2)
- KeyDown();
- if((KeyState==1))
- i++;
- if(KeyValue==14)
- if(i>0)
- i--;
- LcdWriteData(' ');
- if(KeyValue==13)//qingling
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- if((i==6)&&(KeyValue==15)) //queding
- if(
- state=3;
- else
- BZ2();
- state=0;
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- KeyState=0;
- if(state==3)
- LCDWrite_String(0, 0, 16, "Xin mi ma:");
- while(state==3)
- KeyDown();
- if((KeyState==1))
- i++;
- if(KeyValue==14)
- if(i>0)
- i--;
- if(KeyValue==13) //清零
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- for(i=0;i<6;i++)
- mima[i]=mima2[i];
- i=0;
- state=0;
- for(i=0;i<6;i++)
- mima2[i]=0;
- i=0;
- KeyState=0;
- void KeyDown(void)
- unsigned int a=0;
- KEY=0x0f;
- if(KEY!=0x0f)
- Delay10ms(1);
- a++;
- a=0;
- if(KEY!=0x0f)
- KeyState=1;//有按鍵按下
- //測試列
- KEY=0X0F;
- switch(KEY)
- case(0X07): KeyValue=0;break;
- case(0X0b): KeyValue=1;break;
- case(0X0d): KeyValue=2;break;
- case(0X0e): KeyValue=3;break;
- //測試行
- KEY=0XF0;
電子密碼鎖.zip
(3.13 MB, 下載次數: 82)
2019-4-28 11:41 上傳
下載積分: 黑幣 -5
