查看: 7718|回復: 8
188數碼管如何用單片機點亮? 求幫助
ID:366959 發表于 2019-4-25 15:24 | 顯示全部樓層 |閱讀模式
10黑幣
188數碼管資料。
YF2342SW-5 160613.pdf
301.37 KB, 下載次數: 120
最佳答案
查看完整內容
void PALY1(unsigned char sm) { switch(sm) { case 0: break; case 1: YA=YB=YC=YD=0;YD=1;LED2=LED4=0;delay_ms(1);LED2=LED4=1;break; } } void PALY2(unsigned char sm) { YA=YB=YC=YD=0; switch(sm) { case 0: YA=YB=YC=YD=1;LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YC=1; LED2=0;delay_ms(1);LED2=1;break; case 1: YB=YC=1; LED1=0;delay_ms(1);LED1=1;break; ...
ID:162317 發表于 2019-4-25 15:24 | 顯示全部樓層
        switch(sm)
                  case 0: break;
        YA=YB=YC=YD=0;
        switch(sm)
                 case 2: YA=YB=YD=1;   LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YB=YC=1;   LED2=0;delay_ms(1);LED2=1;break;//
                 case 3: YA=YB=YC=YD=1;LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YB=1;      LED2=0;delay_ms(1);LED2=1;break;//
                 case 4: YB=YC=1;      LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YB=1;   LED2=0;delay_ms(1);LED2=1;break;//
                 case 5: YA=YC=YD=1;   LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YB=1;   LED2=0;delay_ms(1);LED2=1;break;//
                 case 6: YA=YC=YD=1;   LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YB=YC=1;LED2=0;delay_ms(1);LED2=1;break;//
                 case 7: YA=YB=YC=1;   LED1=0;delay_ms(1);LED1=1;break;
                 case 8: YA=YB=YC=YD=1;LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YB=YC=1;LED2=0;delay_ms(1);LED2=1;break;
                 case 9: YA=YB=YC=YD=1;LED1=0;delay_ms(1);LED1=1;YA=YB=YC=YD=0;YA=YB=1;   LED2=0;delay_ms(1);LED2=1;break;
                 case 10: YB=1;LED2=0;delay_ms(1);LED2=1;break;
void PALY3(unsigned char sm)
        YA=YB=YC=YD=0;
        switch(sm)
                 case 0: YA=YB=YC=YD=1;LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YC=1;   LED4=0;delay_ms(1);LED4=1;break;
                 case 1: YB=YC=1;      LED3=0;delay_ms(1);LED3=1;break;
                 case 2: YA=YB=YD=1;   LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YB=YC=1;   LED4=0;delay_ms(1);LED4=1;break;//
                 case 3: YA=YB=YC=YD=1;LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YB=1;      LED4=0;delay_ms(1);LED4=1;break;//
                 case 4: YB=YC=1;      LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YB=1;   LED4=0;delay_ms(1);LED4=1;break;//
                 case 5: YA=YC=YD=1;   LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YB=1;   LED4=0;delay_ms(1);LED4=1;break;//
                 case 6: YA=YC=YD=1;   LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YB=YC=1;LED4=0;delay_ms(1);LED4=1;break;//
                 case 7: YA=YB=YC=1;   LED3=0;delay_ms(1);LED3=1;break;
                 case 8: YA=YB=YC=YD=1;LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YB=YC=1;LED4=0;delay_ms(1);LED4=1;break;
                 case 9: YA=YB=YC=YD=1;LED3=0;delay_ms(1);LED3=1;YA=YB=YC=YD=0;YA=YB=1;   LED4=0;delay_ms(1);LED4=1;break;
                 case 10: YB=1;LED4=0;delay_ms(1);LED4=1;break;
ID:604162 發表于 2019-8-27 15:17 | 顯示全部樓層
YA YB YC YD  LED1 LED2 LED3 表示什么?
ID:64269 發表于 2019-11-4 01:30 | 顯示全部樓層
不錯不錯.
ID:635545 發表于 2019-11-5 20:25 | 顯示全部樓層
請問你看懂YA YB YC YD  LED1 LED2 LED3 LED4是什么意思嗎?
ID:311661 發表于 2020-4-16 16:38 | 顯示全部樓層
最近剛好在做數碼管驅動,很不錯的分享,程序自己再慢慢摸索
ID:92781 發表于 2024-7-2 16:25 | 顯示全部樓層
南柯一夢 發表于 2019-4-25 15:24
        switch(sm)
簡單明了,非常感謝
ID:1125252 發表于 2024-7-22 15:39 | 顯示全部樓層
最后的攝氏度怎么點亮?
ID:619259 發表于 2024-7-26 22:20 | 顯示全部樓層
“最佳答案“點評:
(1)188三位分別按字段掃描,其中“1”字的掃描最簡單,程序邏輯是正確的。
(2)程序中出現大量的相似程序行或程序段,沒有采用循環是一大遺憾。
(3)函數名稱使用不規范,如PALY1()、PALY2()、PALY3(),不如使用Display。
(4)函數參數使用sm,有用拼音的嫌疑,非要用,建議加個注釋。
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
