#include <reg52.h> #define uint unsigned int #define uchar unsigned char sbit wex=P2^7; sbit dux=P2^6; uchar num1,num2; uchar code table1[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d}; uchar code table2[]={ 0xfe,0xfd,0xfb,0xf7,0xef,0xdf}; void delayms(uint); void main() { while(1) { for(num2=0;num2<6;num2++) wex=1; P0=table2[num2]; { for(num1=0;num1<6;num1++); { dux=1; P0=table1[num1]; dux=0; delayms(500); } wex=0; } } } void delayms(uint xms) { uint i,j; for(i=xms;i>0;i--) for(j=110;j>0;j--); }
