查看: 6806|回復: 9
arduino nano+I2C LCD1602+SHT3XD溫濕度顯示器
忙碌了一周,終于做成了基于arduino nano和I2C模式下,以sht3xd為傳感器的溫濕度計。頭文件是“adafruit sht3xd.h"和”LiquidCrystal_lCD1602_I2C.h". 兩個器件都用的是I2C模式,都用到了nano的A4、A5腳,所以各自地址要清楚。sht3xd的是0x44, lcd1602的是0x3F(也有0x27/0x20的)。常用的玩意,就不上程序了。可借鑒Dht11的程序,祝大家成功!
參與人數 2黑幣 +60 收起 理由
azi197417 + 10 贊一個!
ID:328014 發表于 2019-4-20 17:06 | 只看該作者
好東東 能分享源碼等資料嗎?
ID:452731 發表于 2019-4-20 23:51 | 只看該作者
有資料共享嗎?
ID:274121 發表于 2019-4-28 07:01 | 只看該作者
各位網友,我在某寶購買了sht30和sht31后,頁面會附上adafruit sht3xd材料的網址,其中的文件包就包含<adafruit sht3xd.h>,再在度娘上搜I2C_Lcd1602頭文件很方便,借鑒arduino+dht11的文章以及aruduino+I2C_Lcd1602 test等文章,修改一下就行。祝你們成功!有問題歡迎交流
ID:274121 發表于 2019-4-29 21:00 | 只看該作者
請參考/***************************************************
  This is an example for the SHT31-D Humidity & Temp Sensor
  Designed specifically to work with the SHT31-D sensor from Adafruit
  These sensors use I2C to communicate, 2 pins are required to
  interface
  Hardware connections for Arduino Nano:
  VDD to 3.3V DC
  SDA to A4
  SCL to A5
  GND to common groud
#include <Arduino.h>
#include <Wire.h>
#include "Adafruit_SHT31.h"
#include "LiquidCrystal_I2C.h"
Adafruit_SHT31 sht31 = Adafruit_SHT31();
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
   #define Serial SerialUSB
#endif
void setup() {
//#ifndef ESP8266
// while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
//#endif
  Serial.begin(9600);
  Serial.println("SHT31 test");
  if (! sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
    Serial.println("Couldn't find SHT31");
    while (1)
    delay(1);
void loop() {
  float t = sht31.readTemperature();
  float h = sht31.readHumidity();
  if (! isnan(t)) {  // check if 'is not a number'
    Serial.print("Temp *C = "); Serial.println(t);
  } else {
    Serial.println("Failed to read temperature");
  if (! isnan(h)) {  // check if 'is not a number'
    Serial.print("Hum. % = "); Serial.println(h);
  } else {
    Serial.println("Failed to read humidity");
  Serial.println();
  delay(5000);
ID:471632 發表于 2019-4-30 20:38 | 只看該作者
這個傳感器就是個貴呀!
ID:521698 發表于 2021-3-18 23:10 | 只看該作者
這個可以換成其他的I2C引腳嗎
ID:274121 發表于 2022-8-10 15:49 | 只看該作者
51hei團團 發表于 2019-4-20 17:06
好東東 能分享源碼等資料嗎?
后悔沒有存代碼,現在我也在找這類材料
ID:274121 發表于 2022-8-10 15:52 | 只看該作者
那個人_H 發表于 2021-3-18 23:10
這個可以換成其他的I2C引腳嗎
A4.A5是IIC專用SCL和SDA
ID:138707 發表于 2023-7-29 17:59 | 只看該作者
非常感謝,很需要這代碼
