查看: 1585|回復: 0
求解讀這段單片機按鍵程序的Nopresstime的作用
ID:418451 發表于 2019-4-17 17:54 | 顯示全部樓層 |閱讀模式
#define IO_KEY1                                                P00                                                        //復用LED_SegA        //按鍵復用
#define IO_KEY2                                                P01                                                        //復用LED_SegB
#define IO_KEY3                                                P02                                                        //復用LED_SegC
#define IO_KEY4                                                P03                                                 //復用LED_SegD
#define IO_KEY5                                                P04                                                        //復用LED_SegE
//*********************** 按鍵值 *************************************
#define KEYVALUE_Key1                        0x01                                                //IO_KEY1按鍵有效的對應值
#define KEYVALUE_Key2                        0x02                                                //IO_KEY2按鍵有效的對應值
#define KEYVALUE_Key3                        0x04                                                //IO_KEY3按鍵有效的對應值
#define KEYVALUE_Key4                        0x08                                                //IO_KEY4按鍵有效的對應值
#define KEYVALUE_Key5                        0x10                                                //IO_KEY5按鍵有效的對應值
unsigned  char bdata KEYFlag =0;          //按鍵狀態寄存器
sbit        KEYFlag1                =        KEYFlag^0;                                                //IO_KEY1的按鍵狀態
sbit        KEYFlag2                =        KEYFlag^1;                                                //IO_KEY2的按鍵狀態
sbit        KEYFlag3                =        KEYFlag^2;                                                //IO_KEY3的按鍵狀態
sbit        KEYFlag4                =        KEYFlag^3;                                                //IO_KEY4的按鍵狀態
sbit        KEYFlag5                =        KEYFlag^4;                                                //IO_KEY5的按鍵狀態
unsigned char keydata_temp;        //按鍵掃描值
unsigned char keydata_old;        //上次的按鍵值
unsigned int  keypresscount;                                                        //按鍵按下計時寄存器
unsigned int  NOPressTime;        //按鍵沒有按的計時寄存器???????
void keyscan(void)
        unsigned char i;
        wei1=0;wei2=0; wei3=0; wei4=0;wei5=0;wei6=0;
        P0M = 0xE0;          //0b11100000                //0為輸入,1為輸出 輸入輸出控制寄存器,將各個段碼改為輸入
        P0UR = 0x1F;        //0b00011111                //內置上拉寄存器 1上拉  0無上拉
        for(i=0;i<10;i++)//20us
                _nop_ ();
                _nop_ ();
        keydata_temp = 0;
        if(IO_KEY1 == 0)
                keydata_temp |= KEYVALUE_Key1;
        if(IO_KEY2== 0)
                keydata_temp |= KEYVALUE_Key2;
        if(IO_KEY3 == 0)
                keydata_temp |= KEYVALUE_Key3;
        if(IO_KEY4 == 0)
                keydata_temp |= KEYVALUE_Key4;
        if(IO_KEY5 == 0)
                keydata_temp |= KEYVALUE_Key5;
        P0M = 0xFF;          //0b11111111                //0為輸入,1為輸出 輸入輸出控制寄存器,將各個段碼改為輸入
        P0UR = 0x00;        //0b00000000
void KeyService(void)
{        uchar t;
        if(keydata_temp == 0)
        {//按鍵未按下
                keypresscount = 0;
                keydata_old   = 0;
                NOPressTime++;
                if(NOPressTime>=2500) NOPressTime=2501;
                if(keydata_temp == keydata_old)
                        NOPressTime = 0;
                        keypresscount++;
                        if(keypresscount>60000) keypresscount =60000;
                        if(keypresscount == 25)
                                if(keydata_temp == KEYVALUE_Key1)
                                        KEYFlag1 =1;
                                if(keydata_temp == KEYVALUE_Key2)
                                        KEYFlag2 =1;
                                if(keydata_temp == KEYVALUE_Key3)
                                        KEYFlag3 =1;
                                if(keydata_temp == KEYVALUE_Key4)
                                        KEYFlag4 =1;
                                if(keydata_temp == KEYVALUE_Key5)
                                        KEYFlag5 =1;
                        if(keypresscount < 5)
                                keypresscount = 0;
                                keydata_old = keydata_temp;
