查看: 1894|回復: 0
單片機串口通信控制云臺姿態的程序問題
ID:475371 發表于 2019-4-14 13:20 | 顯示全部樓層 |閱讀模式
本設計采用串口通信方式控制云臺的姿態和內部溫度值,通過串口發送控制命令+MPULCD ON控制讀取MPU6050姿態參數,發送控制命令+TEMLCD ON讀取內部溫度參數,并且通過TFTLCD 實時顯示各參數值。
//串口通信顯示函數錯誤,但是TFTLCD能正常顯示MPU6050 參數值和溫度值
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "usart.h"
#include "lcd.h"
#include "tsensor.h"
#include "malloc.h"
#include "sdio_sdcard.h"
#include "w25qxx.h"
#include "ff.h"
#include "exfuns.h"
#include "text.h"
#include "mpu6050.h"
#include "usmart.h"
#include "inv_mpu.h"
#include "inv_mpu_dmp_motion_driver.h"
#include "mpulcd.h"
#include "temlcd.h"
#include "string.h"
int main(void)
    u8 key;
        u16 rlen=0;
        delay_init();                     //延時函數初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
        uart_init(115200);            //串口初始化為115200
         LED_Init();                             //LED端口初始化
        KEY_Init();          //初始化與按鍵連接的硬件接口
          usmart_dev.init(72);         //初始化USMART
        LCD_Init();
    T_Adc_Init();                                  //ADC初始化
    MPU_Init();                                        //初始化MPU6050
        W25QXX_Init();                                //初始化W25Q128
         my_mem_init(SRAMIN);                //初始化內部內存池
        exfuns_init();                                //為fatfs相關變量申請內存
    mpu_lcd();
    tem_lcd();
         f_mount(fs[0],"0:",1);                 //掛載SD卡
         f_mount(fs[1],"1:",1);                 //掛載FLASH.
        while(font_init())                         //檢查字庫
                LCD_Clear(WHITE);                           //清屏
                 POINT_COLOR=RED;                        //設置字體為紅色
                LCD_ShowString(30,50,200,16,16,"ELITE STM32F103 ^_^");
                while(SD_Init())                        //檢測SD卡
                        LCD_ShowString(30,70,200,16,16,"SD Card Failed!");
                        delay_ms(200);
                        LCD_Fill(30,70,200+30,70+16,WHITE);
                        delay_ms(200);
                LCD_ShowString(30,70,200,16,16,"SD Card OK");
                LCD_ShowString(30,90,200,16,16,"Font Updating...");
                key=update_font(20,110,16,"0:");//更新字庫
                while(key)//更新失敗
                        LCD_ShowString(30,110,200,16,16,"Font Update Failed!");
                        delay_ms(200);
                        LCD_Fill(20,110,200+20,110+16,WHITE);
                        delay_ms(200);
                LCD_ShowString(30,110,200,16,16,"Font Update Success!   ");
                delay_ms(1500);
                LCD_Clear(WHITE);//清屏
        POINT_COLOR=DARKBLUE;
        Show_Str(30,50,280,16,"基于STM32單片機無線監控系統的設計",16,0);
        Show_Str(30,70,200,16,"WIFI-通信測試程序",16,0);
    POINT_COLOR=RED;
        Show_Str(30,90,200,16,"作者:LuX",16,0);
        Show_Str(30,110,200,16,"日期:2019年4月10日",16,0);
        Show_Str(30,130,200,16,"按KEY0,更新字庫",16,0);
        LCD_ShowString(30,150,200,16,16,"TEMPERATE: 00.00C");
    while(mpu_dmp_init())
                LCD_ShowString(30,170,200,16,16,"MPU6050 Error");
                delay_ms(200);
                LCD_Fill(30,170,239,130+16,WHITE);
                 delay_ms(200);
        LCD_ShowString(30,170,200,16,16,"MPU6050 IS OK!");
         POINT_COLOR=BLUE;//設置字體為藍色
        LCD_ShowString(30,190,200,16,16," Temp:    . C");
         LCD_ShowString(30,210,200,16,16,"Pitch:    . C");
         LCD_ShowString(30,230,200,16,16," Roll:    . C");
         LCD_ShowString(30,250,200,16,16," Yaw :    . C");
//        LCD_ShowString(30,270,200,16,16,"Send:");
        LCD_ShowString(30,270,200,16,16,"Receive:");
        USART_RX_STA=0;
                if(USART_RX_STA&0X8000)                        //接收到一次數據了
                        LCD_Fill(30,290,240,320,WHITE);        //清除顯示
                         rlen=USART_RX_STA&0X7FFF;        //得到數據長度
                          USART_RX_BUF[rlen]=0;                 //加入結束符
//紅色部分可以這樣嗎?串口里面會報錯?有沒有大神有好的解決方法//
                                if(strcmp((const char*)USART_RX_BUF,"+TEMLCD ON")==0)//關閉LED1
                                   tem_lcd();
                                if(strcmp((const char*)USART_RX_BUF,"+MPULCD ON")==0)//關閉LED1
                                   mpu_lcd();
                         LCD_ShowString(30,290,209,119,16,USART_RX_BUF);//顯示接收到的數據
                         USART_RX_STA=0;
