查看: 4148|回復: 1
AVR M16單片機NRF2401無線通信開發包(源碼)
M16-NRF2401開發包,很好的學習
M16-NRF2401開發包.rar (462.69 KB, 下載次數: 50)
  1. //ICC-AVR application builder : 2007-8-11 20:37:32
  2. // Target : M16
  3. // Crystal: 8.0000Mhz
  4. #include <iom16v.h>
  5. #include <macros.h>
  6. //------------------------------------------------------------------------------
  7. //--------------------------------NRF24L01接口定義--------------------------------
  8. //------------------------------------------------------------------------------
  9. //#define NRF24L01_MISO          PB4                //輸入0
  10. #define   Hign_24L01_MISO    PORTB |= (1 << PB4)
  11. #define   Low_24L01_MISO     PORTB &= ~(1 << PB4)
  12. #define   Read_24L01_MISO    PINB & (1 << PB4)
  13. //#define NRF24L01_MOSI         PB2              //輸出1
  14. #define   Hign_24L01_MOSI    PORTB |= (1 << PB2)
  15. #define   Low_24L01_MOSI     PORTB &= ~(1 << PB2)
  16. #define   Read_24L01_MOSI    PINB & (1 << PB2)
  17. //#define NRF24L01_CSN                     PB7              //輸出1
  18. #define   Low_24L01_CSN     PORTB &= ~(1 << PB7)
  19. #define   Hign_24L01_CSN           PORTB |= (1 << PB7)
  20. //#define NRF24L01_SCK                  PB6             //輸出1
  21. #define   Hign_24L01_SCK    PORTB |= (1 << PB6)
  22. #define   Low_24L01_SCK     PORTB &= ~(1 << PB6)
  23. #define   Read_24L01_SCK    PINB & (1 << PB6);
  24. //#define NRF24L01_CE                PB5              //輸出1
  25. #define   Hign_24L01_CE    PORTB |= (1 << PB5)
  26. #define   Low_24L01_CE     PORTB &= ~(1 << PB5)
  27. #define   Read_24L01_CE    PINB & (1 << PB5)
  28. //#define  NRF24L01_IRQ     PB3               //輸入
  29. #define   Hign_NRF24L01_IRQ    PORTB |= (1 << PB3)
  30. #define   Low_NRF24L01_IRQ     PORTB &= ~(1 << PB3)
  31. #define   Read_NRF24L01_IRQ    PINB & (1 << PB3)
  32.
  33. //------------------------------數碼管位選--------------------------------------
  34. //#define Display1   PA1                      //輸出1
  35. #define   Hign_Display1     PORTA |= (1 << PA1);
  36. #define   Low_Display1            PORTA &= ~(1 << PA1);
  37. //#define Display2      PA2                  //輸出1
  38. #define   Hign_Display2     PORTA |= (1 << PA2);
  39. #define   Low_Display2            PORTA &= ~(1 << PA2);
  40. //#define Display3     PA3                  //輸出1
  41. #define   Hign_Display3     PORTA |= (1 << PA3);
  42. #define   Low_Display3             PORTA &= ~(1 << PA3);
  43. //#define Display4      PA4                 //輸出1
  44. #define   Hign_Display4     PORTA |= (1 << PA4);
  45. #define   Low_Display4             PORTA &= ~(1 << PA4);
  46. //-------------------------------BELL蜂明器-------------------------------------
  47. #define   Hign_BELL                 PORTD |= (1 << PD5)
  48. #define   Low_BELL                 PORTD &= ~(1 << PD5)
  49. //-------------------------------JDQ繼電器--------------------------------------
  50. #define   Hign_JDQ                  PORTD |= (1 << PD7)
  51. #define   Low_JDQ                    PORTD &= ~(1 << PD7)
  52. //***********************************數碼管0-9編碼*******************************************
  53. char seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};         //0~~9段碼
  54. char TxBuf[32]=
  55. {
  56. 0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,
  57. 0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
  58. 0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
  59. 0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,
  60. };
  61. char sta,tf,KEY0;
  62. //*********************************************NRF24L01*************************************
  63. #define TX_ADR_WIDTH    5           // 5 uints TX address width
  64. #define RX_ADR_WIDTH    5           // 5 uints RX address width
  65. #define TX_PLOAD_WIDTH  32          // 20 uints TX payload
  66. #define RX_PLOAD_WIDTH  32          // 20 uints TX payload
  67. char  TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //本地地址
  68. char  RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //接收地址
  69. //***************************************NRF24L01寄存器指令*******************************************************
  70. #define READ_REG        0x00          // 讀寄存器指令
  71. #define WRITE_REG       0x20         // 寫寄存器指令
  72. #define RD_RX_PLOAD     0x61          // 讀取接收數據指令
  73. #define WR_TX_PLOAD     0xA0          // 寫待發數據指令
  74. #define FLUSH_TX        0xE1         // 沖洗發送 FIFO指令
  75. #define FLUSH_RX        0xE2          // 沖洗接收 FIFO指令
  76. #define REUSE_TX_PL     0xE3          // 定義重復裝載數據指令
  77. #define NOP1             0xFF          // 保留
  78. //*************************************SPI(nRF24L01)寄存器地址****************************************************
  79. #define CONFIG          0x00  // 配置收發狀態,CRC校驗模式以及收發狀態響應方式
  80. #define EN_AA           0x01  // 自動應答功能設置
  81. #define EN_RXADDR       0x02  // 可用信道設置
  82. #define SETUP_AW        0x03  // 收發地址寬度設置
  83. #define SETUP_RETR      0x04  // 自動重發功能設置
  84. #define RF_CH           0x05  // 工作頻率設置
  85. #define RF_SETUP        0x06  // 發射速率、功耗功能設置
  86. #define STATUS          0x07  // 狀態寄存器
  87. #define OBSERVE_TX      0x08  // 發送監測功能
  88. #define CD              0x09  // 地址檢測
  89. #define RX_ADDR_P0      0x0A  // 頻道0接收數據地址
  90. #define RX_ADDR_P1      0x0B  // 頻道1接收數據地址
  91. #define RX_ADDR_P2      0x0C  // 頻道2接收數據地址
  92. #define RX_ADDR_P3      0x0D  // 頻道3接收數據地址
  93. #define RX_ADDR_P4      0x0E  // 頻道4接收數據地址
  94. #define RX_ADDR_P5      0x0F  // 頻道5接收數據地址
  95. #define TX_ADDR         0x10  // 發送地址寄存器
  96. #define RX_PW_P0        0x11  // 接收頻道0接收數據長度
  97. #define RX_PW_P1        0x12  // 接收頻道0接收數據長度
  98. #define RX_PW_P2        0x13  // 接收頻道0接收數據長度
  99. #define RX_PW_P3        0x14  // 接收頻道0接收數據長度
  100. #define RX_PW_P4        0x15  // 接收頻道0接收數據長度
  101. #define RX_PW_P5        0x16  // 接收頻道0接收數據長度
  102. #define FIFO_STATUS     0x17  // FIFO棧入棧出狀態寄存器設置
  103. //**************************************************************************************
  104. void Delay(int s);
  105. void inerDelay_us(char n);
  106. void init_NRF24L01(void);
  107. char SPI_RW(char data);
  108. char SPI_Read(char reg);
  109. char SPI_RW_Reg(char reg, char value);
  110. char SPI_Read_Buf(char reg, char *pBuf, char uchars);
  111. char SPI_Write_Buf(char reg, char *pBuf, char uchars);
  112. void SetRX_Mode(void);
  113. char nRF24L01_RxPacket(char* rx_buf);
  114. void nRF24L01_TxPacket(char * tx_buf);
  115. //*****************************************長延時*****************************************
  116. void Delay(int s)
  117. {
  118.         unsigned int i;
  119.         for(i=0; i<s; i++);
  120.         for(i=0; i<s; i++);
  121. }
  122. /******************************************************************************************
  123. /*延時函數
  124. /******************************************************************************************/
  125. void inerDelay_us(char n)
  126. {
  127.         for(;n>0;n--);
  128. }
  129. //------------------------------串口初始化--------------------------------------
  130. void uart0_init(void)
  131. {
  132. CLI(); //關閉中斷
  133. UCSRB =0x98;    //disable while setting baud rate
  134. UCSRA =0x20;
  135. UCSRC = 0x86;
  136. UBRRL =51; //set baud rate lo
  137. TIMSK = 0x00; //timer interrupt sources
  138. SEI(); //開中斷
  139. }
  140. //----------------------------接收中斷處理函數----------------------------------
  141. #pragma interrupt_handler uart0_rx_isr:12
  142. void uart0_rx_isr(void)
  143. {
  144.   KEY0=UDR;
  145.   UDR=KEY0;
  146. }
  147. /****************************************************************************************************
  148. /*函數:uint SPI_RW(uint uchar)
  149. /*功能:NRF24L01的SPI寫時序
  150. /****************************************************************************************************/
  151. char SPI_RW(char data)
  152. {
  153.         char i,temp=0;
  154.            for(i=0;i<8;i++) // output 8-bit
  155.            {
  156.         if(data & 0x80)
  157.         {
  158.                 Hign_24L01_MOSI ;         // output 'uchar', MSB to MOSI
  159.         }
  160.         else
  161.         {
  162.                  Low_24L01_MOSI;
  163.         }
  164.                 data = (data << 1);           // shift next bit into MSB..
  165.                 temp<<=1;
  166.                 Hign_24L01_SCK ;                      // Set SCK high..
  167.                 if(Read_24L01_MISO )temp++;                         // capture current MISO bit
  168.                 Low_24L01_SCK;                              // ..then set SCK low again
  169.            }
  170.     return(temp);                             // return read uchar
  171. }
  172. /****************************************************************************************************
  173. /*函數:uchar SPI_Read(uchar reg)
  174. /*功能:NRF24L01的SPI時序
  175. /****************************************************************************************************/
  176. char SPI_Read(char reg)
  177. {
  178.         char reg_val;
  179.
  180.         Low_24L01_CSN;                // CSN low, initialize SPI communication...
  181.         SPI_RW(reg);            // Select register to read from..
  182.         reg_val = SPI_RW(0);    // ..then read registervalue
  183.         Hign_24L01_CSN;                // CSN high, terminate SPI communication
  184.
  185.         return(reg_val);        // return register value
  186. }
  187. /****************************************************************************************************/
  188. /*功能:NRF24L01讀寫寄存器函數
  189. /****************************************************************************************************/
  190. char SPI_RW_Reg(char reg, char value)
  191. {
  192.         char status;
  193.
  194.         Low_24L01_CSN;                   // CSN low, init SPI transaction
  195.         status = SPI_RW(reg);      // select register
  196.         SPI_RW(value);             // ..and write value to it..
  197.         Hign_24L01_CSN;                   // CSN high again
  198.
  199.         return(status);            // return nRF24L01 status uchar
  200. }
  201. /****************************************************************************************************/
  202. /*函數:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
  203. /*功能: 用于讀數據,reg:為寄存器地址,pBuf:為待讀出數據地址,uchars:讀出數據的個數
  204. /****************************************************************************************************/
  205. char SPI_Read_Buf(char reg, char *pBuf, char uchars)
  206. {
  207.         int status,uchar_ctr;
  208.
  209.         Low_24L01_CSN;                                    // Set CSN low, init SPI tranaction
  210.         status = SPI_RW(reg);                       // Select register to write to and read status uchar
  211.
  212.         for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
  213.                 pBuf[uchar_ctr] = SPI_RW(0);    //
  214.
  215.         Hign_24L01_CSN;
  216.
  217.         return(status);                    // return nRF24L01 status uchar
  218. }
  219. /*********************************************************************************************************
  220. /*函數:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
  221. /*功能: 用于寫數據:為寄存器地址,pBuf:為待寫入數據地址,uchars:寫入數據的個數
  222. /*********************************************************************************************************/
  223. char SPI_Write_Buf(char reg, char *pBuf, char uchars)
  224. {
  225.         char status,uchar_ctr;
  226.
  227.         Low_24L01_CSN;             //SPI使能
  228.         status = SPI_RW(reg);
  229.         for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
  230.         SPI_RW(*pBuf++);
  231.         Hign_24L01_CSN;           //關閉SPI
  232.         return(status);                      //
  233. }
  234. /****************************************************************************************************/
  235. /*函數:void SetRX_Mode(void)
  236. /*功能:數據接收配置
  237. /****************************************************************************************************/
  238. void SetRX_Mode(void)
  239. {
  240.         Low_24L01_CE;
  241.         SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);                   // IRQ收發完成中斷響應,16位CRC        ,主接收
  242.         Hign_24L01_CE;
  243.         inerDelay_us(130);
  244. }
  245. /******************************************************************************************************/
  246. /*函數:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
  247. /*功能:數據讀取后放如rx_buf接收緩沖區中
  248. /******************************************************************************************************/
  249. char nRF24L01_RxPacket(char* rx_buf)
  250. {
  251.     char revale=0;
  252.         sta=SPI_Read(STATUS);        // 讀取狀態寄存其來判斷數據接收狀況
  253.         if(sta&0x40)                                // 判斷是否接收到數據
  254.         {
  255.             Low_24L01_CE;                         //SPI使能
  256.                 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
  257.                 revale =1;                        //讀取數據完成標志
  258.         }
  259.         SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到數據后RX_DR,TX_DS,MAX_PT都置高為1,通過寫1來清楚中斷標志
  260.         return revale;
  261. }
  262. /***********************************************************************************************************
  263. /*函數:void nRF24L01_TxPacket(char * tx_buf)
  264. /*功能:發送 tx_buf中數據
  265. /**********************************************************************************************************/
  266. void nRF24L01_TxPacket(char * tx_buf)
  267. {
  268.         Low_24L01_CE;                        //StandBy I模式
  269.         SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 裝載接收端地址
  270.         SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);                          // 裝載數據
  271. //        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);                    // IRQ收發完成中斷響應,16位CRC,主發送
  272.         Hign_24L01_CE;                 //置高CE,激發數據發送
  273.         inerDelay_us(10);
  274. }
  275. //****************************************************************************************
  276. /*NRF24L01初始化
  277. //***************************************************************************************/
  278. void init_NRF24L01(void)
  279. {
  280.     inerDelay_us(100);
  281.         Low_24L01_CE;    // chip enable
  282.         Hign_24L01_CSN;   // Spi disable
  283.         Low_24L01_SCK;   // Spi clock line init high
  284.         SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 寫本地地址
  285.         SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 寫接收端地址
  286.         SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //  頻道0自動        ACK應答允許
  287.         SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  允許接收地址只有頻道0,如果需要多頻道可以參考Page21
  288.         SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //   設置信道工作為2.4GHZ,收發必須一致
  289.         SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //設置接收數據長度,本次設置為32字節
  290.         SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);                   //設置發射速率為1MHZ,發射功率為最大值0dB
  291.         SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);                    // IRQ收發完成中斷響應,16位CRC,主發送
  292. }
  293. main()
  294. {
  295.         char i;
  296.         DDRD=0xf2;                  //
  297.         DDRB=0xe4;
  298.         DDRC=0xff;
  299.         DDRA=0x1e;
  300.         PORTA=0x00;
  301.         PORTC=0xbf;
  302.         Hign_BELL;
  303.         uart0_init();
  304.     init_NRF24L01() ;
  305.         nRF24L01_TxPacket(TxBuf);        // Transmit Tx buffer data
  306.         while(1)
  307.         {
  308. if(KEY0==49)                                                //有鍵按下1
  309.                         {
  310.                                  TxBuf[0]=0x11;
  311.                                  tf =1;
  312.                                  PORTC=0xBF;
  313.                         }
  314.         if(KEY0==50)                                                //有鍵按下2
  315.                         {
  316.                                  TxBuf[0]=0x21;
  317.                                  tf =2;
  318.                                   PORTC=0xFE;
  319.                         }
  320.         if(KEY0==51)                                                //有鍵按下3
  321.                         {
  322.                                 TxBuf[0]=0x31;
  323.                                 tf =3;
  324.                                  PORTC=0xf7;
  325.                         }
  326.         if(KEY0==52)                                                //有鍵按下4
  327.                         {
  328.                                 TxBuf[0]=0x41;
  329.                                 tf =4;
  330.                                  PORTC=0xBF;
  331.                         }
  332.         if(KEY0==53)                                                //有鍵按下5
  333.                         {
  334.                                 TxBuf[0]=0x51;
  335. ……………………
  336. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ID:295855 發表于 2020-12-7 08:57 | 只看該作者
謝謝!學習中
