查看: 9894|回復: 6
單片機公交車語音報站系統Proteus仿真+程序
操作說明:
1、下行控制報站:首先按下(下行設置按鍵),(下行指示燈)亮,然后按下(手動播報)按鍵控制播報下一站
2、上行控制報站:首先按上(上行設置按鍵),(上行指示燈)亮,然后按下(手動播報)按鍵控制播報下一站
3、按下關閉播報按鍵,則關閉播報功能和清除顯示
  1. /***************主函數*****************/
  2. void main()
  3. {
  4.         uchar num=0;                                 //定時器1,工作在定時方式2
  5.         P0 = P1 = P2 = P3 = 0XFF;
  6.         LcmInit();//初始化12864
  7.         init_12864_dis();
  8.         Send_threelines(0,0);    //語音播報
  9.         while(1)
  10.         {
  11.                 key();         //獨立按鍵程序
  12.                 if(key_can < 20)
  13.                 {
  14.                         if(key_can == 1)
  15.                         {
  16.                                 if(num < geshu)
  17.                                 {
  18.                                         num++;
  19.                                 }
  20.                                 flag_s = 1;
  21.                         }
  22.                         if(key_can == 2)
  23.                         {
  24.
  25.                                         if(num != 0)
  26.                                                 num--;
  27.
  28.                         }
  29.                         if(num == 1)       //報第1個站
  30.                         {
  31.                                 PutStr(1,0,gj_ming);
  32.               PutStr(2,0,table1);
  33.               PutStr(3,0,gj_ming1);
  34.                                 PutStr(3,0,"        ");
  35.                                 Send_threelines(1,0);    //語音播報
  36.
  37.                         }
  38.                         if(num == 2)       //報第2個站
  39.                         {
  40.                                 PutStr(1,0,gj_ming);
  41.               PutStr(2,0,table2);
  42.               PutStr(3,0,gj_ming1);
  43.                                 PutStr(3,0,"        ");
  44.                                 flag_z=1;
  45.                                 Send_threelines(2,0);    //語音播報
  46.                         }
  47.                         if(num == 3)       //報第3個站
  48.                         {
  49.                                 PutStr(1,0,gj_ming);
  50.               PutStr(2,0,table3);
  51.               PutStr(3,0,gj_ming1);
  52.                                 PutStr(3,0,"        ");
  53.                                 Send_threelines(3,0);    //語音播報
  54.                         }
  55.                         if(num == 4)       //報第4個站
  56.                         {
  57.                                 PutStr(1,0,gj_ming);
  58.               PutStr(2,0,table4);
  59.               PutStr(3,0,gj_ming1);
  60.                                 PutStr(3,0,"        ");
  61.                                 Send_threelines(4,0);    //語音播報
  62.                         }
  63.                         if(num == 5)       //報第5個站
  64.                         {
  65.                                 PutStr(1,0,gj_ming);
  66.               PutStr(2,0,table5);
  67.               PutStr(3,0,gj_ming1);
  68.                                 PutStr(3,0,"        ");
  69.                                 Send_threelines(5,0);    //語音播報
  70.                         }
  71.                         if(num == 6)       //報第5個站
  72.                         {
  73.                                 PutStr(1,0,gj_ming);
  74.               PutStr(2,0,table6);
  75.               PutStr(3,0,gj_ming1);
  76.                                 PutStr(3,0,"        ");
  77.                                 Send_threelines(6,0);    //語音播報
  78.                         }
  79.                         if(num == 7)       //報第5個站
  80.                         {
  81.                                 PutStr(1,0,gj_ming);
  82.               PutStr(2,0,table7);
  83.               PutStr(3,0,gj_ming1);
  84.                                 PutStr(3,0,"        ");
  85.                                 Send_threelines(7,0);    //語音播報
  86.                         }
  87.                         if(num == 8)       //報第5個站
  88.                         {
  89.                                 PutStr(1,0,gj_ming);
  90.               PutStr(2,0,table8);
  91.               PutStr(3,0,gj_ming1);
  92.                                 PutStr(3,0,"        ");
  93.                                 Send_threelines(8,0);    //語音播報
  94.                         }
  95.                         if(num == 9)       //報第9個站
  96.                         {
  97.                                 PutStr(1,0,gj_ming);
  98.               PutStr(2,0,table9);
  99.               PutStr(3,0,gj_ming1);
  100.                                 PutStr(3,0,"        ");
  101.                                 if(flag_s == 1)
  102.                                 {
  103.                                         Send_threelines(10,0);    //語音播報
  104.                                 }
  105.                                 else
  106.                                 {
  107.                                         flag_s = 1;
  108.                                         Send_threelines(9,0);    //語音播報
  109.                                 }
  110.                         }
  111.                 }
  112.         }
  113. }
全部資料51hei下載地址:
通用的.zip (45.81 KB, 下載次數: 257)
單片機公交報站仿真.zip (179.14 KB, 下載次數: 360)
收藏收藏8 分享淘帖 頂 踩
ID:667545 發表于 2019-12-18 17:59 | 只看該作者
一開始不顯示字符,后來改用Proteus7.5版本終于成功了 謝謝
ID:698975 發表于 2020-2-27 11:43 | 只看該作者
謝謝樓主分享,好資料,51黑有你更精彩!!!
ID:902246 發表于 2021-4-8 09:25 | 只看該作者
為什么不行
ID:328014 發表于 2021-4-8 17:36 | 只看該作者
要用Proteus7.5打開才可以
ID:901488 發表于 2021-5-9 18:42 | 只看該作者
很好用,謝謝
ID:867005 發表于 2021-5-16 10:54 | 只看該作者
是不是需要添加另外的文件才能夠實現站點信息的顯示,像取模之類的
