查看: 2400|回復: 2
單片機八路搶答器為什么蜂鳴不響,程序要怎么改呢?
ID:503141 發表于 2019-4-11 18:28 | 顯示全部樓層 |閱讀模式
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. unsigned char code SMG_CODE[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  4. //共陰數碼管“0”“1”“2”“3”“4”“5”“6”“7”“8”“9”
  5. sbit AnJan_1=P1^0;
  6. sbit AnJan_2=P1^1;
  7. sbit AnJan_3=P1^2;
  8. sbit AnJan_4=P1^3;
  9. sbit AnJan_5=P1^4;
  10. sbit AnJan_6=P1^5;
  11. sbit AnJan_7=P1^6;
  12. sbit AnJan_8=P1^7;
  13. sbit start=P3^1;    //開始鍵
  14. sbit reset=P3^2;    //復位鍵
  15. sbit BZ=P3^0;      //蜂鳴器
  16. char i,a,state=0;
  17. void Yanshi10ms(unsigned int m)   //誤差0us
  18. {
  19.     unsigned char j,h;
  20.     for(;m>0;m--)
  21.         for(h=38;h>0;h--)
  22.             for(j=130;j>0;j--);
  23. }
  24. void main()
  25. {
  26.     BZ=1;
  27.         TMOD=0x01;                 //定時器0方式1
  28.         TH1=(65536-50000)/256;                //恢復定時器1初值
  29.         TL1=(65536-50000)%256;
  30.         EA=1;
  31.         P0=0x00;
  32.     while (1)
  33.     {
  34.                 while(state==0)
  35.                 {
  36.                         if(start==0)
  37.                         {
  38.                                 Yanshi10ms(1);
  39.                                 if(start==0)
  40.                                 {
  41.                                 P0 = 0x40;
  42.                                 BZ=0;
  43.                                 ET1=1;TR1=1;
  44.                                 a=0;
  45.                                 state=1;
  46.                                 while(start==0);
  47.                                 }
  48.                         }
  49.                 }
  50.                 while(state==1)
  51.                 {
  52.                                 if(AnJan_1==0)
  53.                                 {
  54.                                         P0 = SMG_CODE[1];
  55.                                         BZ=0;
  56.                                         ET1=1;TR1=1;
  57.                                         state=2;
  58.                                 }
  59.
  60.                                 if(AnJan_2==0)
  61.                                 {
  62.                                         P0 = SMG_CODE[2];
  63.                                         BZ=0;
  64.                                         ET1=1;TR1=1;
  65.                                         state=2;
  66.                                 }
  67.
  68.                                 if(AnJan_3==0)
  69.                                 {
  70.                                         P0 = SMG_CODE[3];
  71.                                         BZ=0;
  72.                                         ET1=1;TR1=1;
  73.                                         state=2;
  74.                                 }
  75.
  76.                                 if(AnJan_4==0)
  77.                                 {
  78.                                         P0 = SMG_CODE[4];
  79.                                         BZ=0;
  80.                                         ET1=1;TR1=1;
  81.                                         state=2;
  82.                                 }
  83.
  84.                                 if(AnJan_5==0)
  85.                                 {
  86.                                         P0 = SMG_CODE[5];
  87.                                         BZ=0;
  88.                                         ET1=1;TR1=1;
  89.                                         state=2;
  90.                                 }
  91.
  92.                                 if(AnJan_6==0)
  93.                                 {
  94.                                         P0 = SMG_CODE[6];
  95.                                         BZ=0;
  96.                                         ET1=1;TR1=1;
  97.                                         state=2;
  98.                                 }
  99.
  100.                                 if(AnJan_7==0)
  101.                                 {
  102.                                         P0 = SMG_CODE[7];
  103.                                         BZ=0;
  104.                                         ET1=1;TR1=1;
  105.                                         state=2;
  106.                                 }
  107.
  108.                                 if(AnJan_8==0)
  109.                                 {
  110.                                         P0 = SMG_CODE[8];
  111.                                         BZ=0;
  112.                                         ET1=1;TR1=1;
  113.                                         state=2;
  114.                                 }
  115.                         if(reset==0)
  116.                         {
  117.                                 state=0;
  118.                                 P0=SMG_CODE[17];
  119.                                 BZ=1;
  120.                                 break;
  121.                         }
  122.                 }
  123.                 while(state==2)
  124.                 {
  125.                         if(reset==0)
  126.                         {
  127.                                 state=0;
  128.                                 BZ=1;
  129.                                 P0=SMG_CODE[17];
  130.                                 break;
  131.                         }
  132.                 }
  133.     }
  134. }
  135. void Dingshiqi1() interrupt 3
  136. {
  137.         TH1=(65536-50000)/256;
  138.         TL1=(65536-50000)%256;
  139.         a++;
  140.         if(a>=20)
  141.         {
  142.                 ET1=0;TR1=0;
  143.                 a=0;
  144.                 BZ=1;
  145.         }
  146. }
ID:96682 發表于 2019-4-11 19:44 | 顯示全部樓層
要響得用對蜂鳴器和三極管
ID:123289 發表于 2019-4-12 16:01 | 顯示全部樓層
你向P3.0送個1看它響不響?
