查看: 2947|回復: 3
單片機之間雙向通信,仿真,程序
ID:477374 發(fā)表于 2019-4-10 20:11 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
仿真圖如下:
程序代碼如下:
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. sbit LED1 = P1^0;
  5. sbit LED2 = P1^3;
  6. sbit K1 = P1^7;
  7. uchar NumX = 0x00;
  8. void Delay(uint x)
  9. {
  10.         uchar i;
  11.         while(x--)
  12.         {
  13.                  for(i=0;i<120;i++);
  14.         }
  15. }
  16. void main()
  17. {
  18.         LED1=LED2=1;
  19.         SCON = 0x50;
  20.         TMOD = 0x20;
  21.         PCON = 0x00;
  22.         TH1  = 0xfd;
  23.         TL1  = 0xfd;
  24.         TI   = 0;
  25.         RI   = 0;
  26.         TR1  = 1;
  27.         IE   = 0x90;
  28.         while(1)
  29.         {
  30.                  Delay(100);
  31.                 if(K1==0);
  32.                 {
  33.                          while(K1==0);
  34.                         NumX = NumX%10;
  35.                         SBUF = NumX;
  36.                         NumX = NumX+1;
  37.                         while(TI == 0);
  38.                         TI = 0;
  39.                 }
  40.         }
  41. }
  42. void Serial_INT() interrupt 4
  43. {
  44.         if(RI)
  45.         {
  46.                  RI = 0;
  47.                 switch(SBUF)
  48.                 {
  49.                         case 'X': LED1=1;LED2=1;break;
  50.                         case 'A': LED1=0;LED2=1;break;
  51.                         case 'B': LED2=0;LED1=1;break;
  52.                         case 'C': LED1=0;LED2=0;
  53.                 }
  54.         }
  55. }
另一個單片機要的程序:
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #define uint unsigned int
  5. sbit LED1 = P1^0;
  6. sbit LED2 = P1^3;
  7. sbit K1 = P1^7;
  8. uchar Operation_NO = 0;
  9. uchar code DSY_CODE[]=
  10. {
  11.         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
  12. };
  13. void Delay(uint x)
  14. {
  15.         uchar i;
  16.         while(x--)
  17.         {
  18.                  for(i=0;i<120;i++);
  19.         }
  20. }
  21. void putc_to_SerialPort(uchar c)
  22. {
  23.         SBUF = c;
  24.         while(TI == 0);
  25.         TI = 0;
  26. }
  27. void main()
  28. {
  29.         LED1=LED2=1;
  30.         P0 = 0x00;
  31.         SCON = 0x50;
  32.         TMOD = 0x20;
  33.         PCON = 0x00;
  34.         TH1  = 0xfd;
  35.         TL1  = 0xfd;
  36.         TI   = 0;
  37.         RI   = 0;
  38.         TR1  = 1;
  39.         IE   = 0x90;
  40.         while(1)
  41.         {
  42.                  Delay(100);
  43.                 if(K1 == 0)
  44.                 {
  45.                          while(K1==0);
  46.                         Operation_NO=(Operation_NO+1)%4;
  47.                         switch(Operation_NO)
  48.                         {
  49.                                  case 0:
  50.                                                 putc_to_SerialPort('X');
  51.                                                 LED1=LED2=1; break;
  52.                                 case 1:
  53.                                                 putc_to_SerialPort('A');
  54.                                                 LED1=0;LED2=1;break;
  55.                                 case 2:
  56.                                                 putc_to_SerialPort('B');
  57.                                                 LED2=0;LED1=1;break;
  58.                                 case 3:
  59.                                                 putc_to_SerialPort('C');
  60.                                                 LED1=0;LED2=0;break;
  61.                         }
  62.                 }
  63.         }
  64. }
  65. void Serial_INT() interrupt 4
  66. {
  67.         if(RI)
  68.         {
  69.                  RI = 0;
  70.                 if(SBUF>=0&&SBUF<=9)
  71.                         P0 = DSY_CODE[SBUF];
  72.                 else
  73.                         P0 = 0x00;
  74.         }
  75. }
完整程序,仿真附件:
單片機與單片機串口通訊.rar (61.27 KB, 下載次數(shù): 15)
參與人數(shù) 1黑幣 +50 收起 理由
ID:511556 發(fā)表于 2019-4-13 22:33 | 只看該作者
AT89C51的串口通信工作方式一c語言程序例子有么?
ID:47652 發(fā)表于 2019-5-11 12:43 | 只看該作者
初學100例里面的例子
ID:47652 發(fā)表于 2019-5-11 12:48 | 只看該作者
這樣得來的也可以發(fā)
