查看: 6074|回復: 9
為什么單片機這樣顯示數碼管亮度不夠?延時函數的問題?
ID:438858 發表于 2019-4-10 17:25 | 顯示全部樓層 |閱讀模式
為什么這樣顯示數碼管亮度不夠,為啥顯示函數里不要加延時了,加了延時不能實現功能!
  1. #include <reg52.h>
  2. #define dataport P0
  3. #define uint unsigned int
  5. sbit duanch_1 = P2^2;
  6. sbit weich_2 = P2^3;
  7. sbit key_1 = P3^3;
  8. sbit key_2 = P3^4;
  9. uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6};
  10. uchar weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  11. uchar tempdata[8];
  12. void delayms(uchar t);
  13. void display(uchar firstbit,uchar Num);
  14. void init();
  15. void main()
  16. {
  17.         uchar num;
  18.         key_1 = 1;
  19.         key_2 = 1;
  20.         init();
  21.         while(1)
  22.         {
  23.                 if(!key_1)
  24.                 {
  25.                         delayms(10);
  26.                         if(!key_1)
  27.                         {
  28.                                 while(!key_1);
  29.                                 {
  30.                                         if(num<99)
  31.                                                 num++;
  32.                                 }
  33.                         }
  34.                 }
  35.                 if(!key_2)
  36.                 {
  37.                         delayms(10);
  38.                         if(!key_2)
  39.                         {
  40.                                 while(!key_2);
  41.                                 {
  42.                                         if(num>0)
  43.                                                 num--;
  44.                                 }
  45.                         }
  46.                 }
  47.                 tempdata[0] = duanma[num/10];
  48.                 tempdata[1] = duanma[num%10];
  49.         }
  50. }
  51. void delayms(uchar t)
  52. {
  53.         uchar i,j;
  54.         for(i=0;i<120;i++)
  55.                 for(j=0;j<t;j++);
  56. }
  57. void display(uchar firstbit,uchar Num)
  58. {
  59.         uchar i;
  60.         for(i=0;i<Num;i++)
  61.         {
  62.                 dataport = 0;
  63.                 duanch_1 = 1;
  64.                 duanch_1 = 0;
  65.
  66.                 dataport = weima[i+firstbit];
  67.                 weich_2 = 1;
  68.                 weich_2 = 0;
  69.
  70.                 dataport = tempdata[i];
  71.                 duanch_1 = 1;
  72.                 duanch_1 = 0;
  73.         }
  74. }
  75. void init()
  76. {
  77.         TMOD|=0x01;
  78.         EA = 1;
  79.         ET0 = 1;
  80.         TR0 = 1;
  81. }
  82. void time_0 ()interrupt 1
  83. {
  84.         TH0 = (65536-2000)/256;
  85.         TL0 = (65536-2000)%256;
  86.
  87.         display(0,3);
  88. }
ID:213173 發表于 2019-4-10 21:37 | 顯示全部樓層
你的顯示函數這樣處理當然會出問題,改一下即可。每次中斷只顯示一位。
#include <reg52.h>
#define dataport P0
sbit key_1 = P3^3;
sbit key_2 = P3^4;
uchar num;
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar tempdata[8];
void display();
void init();
        init();
                if(!key_1)
                        delayms(10);
                        if(!key_1)
                                while(!key_1);
                                        if(num<99)
                                        num++;
                if(!key_2)
                        delayms(10);
                        if(!key_2)
                                while(!key_2);
                                        if(num>0)
                                        num--;
        uchar i,j;
        for(i=0;i<120;i++)
            for(j=0;j<t;j++);
void display()
        static uchar i=0;
        dataport=0x00;//消隱
        duanch_1 = 1;
        duanch_1 = 0;
        switch(i)
                case 0:
                        dataport = weima[i];//送十位位碼
                        weich_2  = 1;
                        weich_2  = 0;
                        dataport = tempdata[i];//送十位段碼
                        duanch_1 = 1;
                        duanch_1 = 0;
                        i++;
                break;
                case 1:
                        dataport = weima[i];//送個位位碼
                        weich_2  = 1;
                        weich_2  = 0;
                        dataport = tempdata[i];//送個位段碼
                        duanch_1 = 1;
                        duanch_1 = 0;
                        i=0;
                break;
void init()
        TMOD|=0x01;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        display();
ID:423511 發表于 2019-4-10 22:38 | 顯示全部樓層
延時加大點試試。
ID:164602 發表于 2019-4-11 08:22 | 顯示全部樓層
第一:你的顯示函數中沒有延時程序,所以亮度不夠。數碼管從不亮到亮,現從亮到不亮,都是需要時間的,你開了馬上關,時間太短,所以不太亮。
第二:你的程序說不能加延時,是因為你的定時器為2ms,如果延時過長,就會中斷嵌套,這就不好辦了,所以加了延時就死了,功能不能實現。
第三:兩種解決方案:
(1)定時器時間加大一點,配合的延時時間要算好,中斷程序執行時間不超過定時時間
(2)重新規劃程序,例如定時中斷一次只顯示一位數碼管
ID:230559 發表于 2019-4-11 10:21 | 顯示全部樓層
主要是定時器時間問題,上面的解決方案很好!
ID:509436 發表于 2019-4-11 10:39 | 顯示全部樓層
ID:509511 發表于 2019-4-11 12:34 | 顯示全部樓層
我看主要問題還是在沒有消影
ID:509620 發表于 2019-4-11 14:29 | 顯示全部樓層
延遲的問題,嘗試加長試一試
ID:430571 發表于 2019-4-11 21:23 | 顯示全部樓層
可以加上去延時抖動,如,在
P1=0x01;
delay(5);
P1=0x00;//去延時抖動,解決數碼管顯示不清楚的問題
ID:509991 發表于 2019-4-11 22:02 | 顯示全部樓層
