查看: 2238|回復: 0
C8051F定義了DAC的值,當上位機來命令時,DAC輸出幾V點壓,但是控制不了?
ID:478255 發表于 2019-4-10 14:07 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
30黑幣
主函數
#include <c8051f330.h>                 // SFR declarations
#include "string.h"
#include <stdio.h>
#include "SPI.h"
#include <intrins.h>
unsigned char  index = 1;
unsigned char buf[2];
unsigned char flag = 0;
unsigned char UART_RX_idx = 0;
void re(unsigned char a);
void delay(unsigned long delaytime)
                for(;delaytime>0;delaytime--)
                _nop_();
void delay10000(unsigned long delaytime)
        unsigned long i;
        for(i = 0;i <10000;i++)
        _nop_();
void UART_Init()
                EA = 0;
                SCON0     = 0x50;
                TCON      = 0x40;
                TMOD      = 0x20;
                TH1       = 0x96;
                CKCON     = 0x00;
                TR1 = 1;
                ET0= 1;
                ES0 =1;
                TI0 = 0;
                RI0 = 0;
                EA = 1;
                UART_RX_idx = 0;
                RXflage = 0;
void Send_data(unsigned char dat)
                SBUF0 = dat;
                TI0 = 1;
                delay(10);
                while(!TI0);
void uart() interrupt 4
        unsigned char aa;
        if(RI0)
                EA = 1;
                RI0 = 0;
                aa = SBUF0;
                re(aa);
        switch(index)
                case 1://正在等待接受0xaa
                        if(a == 0xaa)
                                //繼續接受0x55;
                                index++;
                                index =0;
                        break;
                case 2:
                                if(a == 0x55)
                                //繼續接受0x55;
                                        index++;
                                        index =0;
                        break;
                case 3:
                                buf[0] = a;
                                index++;
                        break;
                case 4:
                                buf[1] = a;
                                index++;
                        break;
                case 5:
                        if(a == '$')
                                index++;
                                index =0;
                        break;
                case 6:
                        if(a == '&')
                                flag = 1;
                                index =0;
                        break;
void main (void)
        PCA0MD &= ~0x40;
        OSCICN |= 0x03;
        XBR0    = 0x01;
        XBR1    = 0x40;
        P0MDIN |= 0x00;
        P1MDIN |= 0x00;
        P0MDOUT|= 0xff;
        P1MDOUT|= 0xff;
        UART_Init();
        delay10000(20);
        init_dac8562();
  cfg_dac8562_1();
                        if(flag == 1)
                                cfg_dac8562_1(buf[0]*256+buf[1]);
                                flag = 0;
dac設置
#include <C8051F120.H>
#include "SPI.h"
#include "intrins.h"
unsigned char RX_dat[20];
unsigned char RXflage;
unsigned long  Rx_Freq;
unsigned long  HMC704_03;
double temp;
unsigned long temp_ulong;
unsigned long cfgdat;
void Set8562(unsigned long datin)
        unsigned long dat;
        unsigned char i = 0;
        unsigned char ii = 0;
        DAC8562_CS = 0;
        dat = datin;
        dat = dat << 8;
        for(i = 0;i < 24;i++)
                DAC8562_CLK = 1;
                DAC8562_DAT = dat & 0x80000000;
                dat = dat << 1;
                DAC8562_CLK = 0;
        DAC8562_DAT = 0;
        DAC8562_CLK= 0;
        dat = dat << 1;
        DAC8562_CS = 1;
void init_dac8562()
        cfgdat = 0x380001;
        Set8562(cfgdat);
        cfgdat = 0x184000;
        Set8562(cfgdat);
        cfgdat = 0x194000;
        Set8562(cfgdat);
void cfg_dac8562_1(unsigned long datin)
                        cfgdat = 0x180000+datin;
                        Set8562(cfgdat);
