你喝過雞尾酒么?是自己調制的么?我沒有喝過,但是做了一個雞尾酒主題交互傘?喜歡么?想自己試一試不?可以私信我要源代碼哦。對了,在此聲明,此分享不是商-業作品,非成套售-賣品,感興趣的可以私信我或者留郵箱等聯系方式分享更多細節和資料,然后自己動手做一個。
視頻放不上來。。。。。。。。。。。先給幾張圖片吧
2019-4-10 16:00 上傳
2019-4-10 16:00 上傳
2019-4-10 16:00 上傳
2019-4-10 16:00 上傳
Arduino源程序如下:
- #include <SPI.h>
- #include <SD.h>
- #include "LcDef.h"
- #include <Wire.h>
- #include <Adafruit_PWMServoDriver.h>
- #include <LiquidCrystal.h>
- LiquidCrystal lcd(4, 6, 9, 11, 12, 13);
- File myFile;
- Adafruit_PWMServoDriver pwm1 = Adafruit_PWMServoDriver(0x40);
- Adafruit_PWMServoDriver pwm2 = Adafruit_PWMServoDriver(0x41);
- Adafruit_PWMServoDriver pwm3 = Adafruit_PWMServoDriver(0x42);
- Adafruit_PWMServoDriver pwm4 = Adafruit_PWMServoDriver(0x43);
- Adafruit_PWMServoDriver pwm5 = Adafruit_PWMServoDriver(0x44);
- Adafruit_PWMServoDriver pwm6 = Adafruit_PWMServoDriver(0x45);
- Adafruit_PWMServoDriver pwm7 = Adafruit_PWMServoDriver(0x46);
- Adafruit_PWMServoDriver pwm8 = Adafruit_PWMServoDriver(0x47);
- Adafruit_PWMServoDriver pwm9 = Adafruit_PWMServoDriver(0x48);
- Adafruit_PWMServoDriver pwm10 = Adafruit_PWMServoDriver(0x49);
- Adafruit_PWMServoDriver servoligne[10] {pwm10,pwm9,pwm8,pwm7,pwm6,pwm5,pwm4,pwm3,pwm2,pwm1};
- int degremin=40;
- int degremax=120;
- int valeurmax=map(degremax,0,180,150,550);
- int valeurmin=map(degremin,0,180,150,550);
- int tabvaleurmin[10][16];
- int tabvaleurmax[10][16];
- int angleconsigne=degremin;
- #define bouton1on (!digitalRead(24))
- #define bouton2on (!digitalRead(26))
- #define bouton3on (!digitalRead(28))
- #define bouton4on (!digitalRead(30))
- byte bouton1onprevious=0;
- byte bouton2onprevious=0;
- byte bouton3onprevious=0;
- byte bouton4onprevious=0;
- int valeurbouton1=0;
- int valeurbouton2=0;
- int valeurbouton3=0;
- int valeurbouton4=0;
- byte ausuivant=0;
- int prochainecol=0;
- int angle[10 ] [ 16];
- void setup()
- pinMode(24,INPUT_PULLUP);
- pinMode(26,INPUT_PULLUP);
- pinMode(28,INPUT_PULLUP);
- pinMode(30,INPUT_PULLUP);
- for (int x=0;x<=9;x++)
- servoligne[x].begin();
- servoligne[x].setPWMFreq(60);
- lcd.begin(16, 2);
- Serial.begin(9600);
- delay(1000);
- randomSeed(analogRead(0));
- for(int y=0;y<=9; y++) {
- for( int x=0;x<=15;x++) {
- tabvaleurmin[y][x]=150;
- tabvaleurmax[y][x]=550;
- Serial.print("Initializing SD card...");//
- lcdaffiche("Initializing SD card...","");
- if (!SD.begin(53)) {// *
- Serial.println("initialization failed!");//
- lcdaffiche("carte SD pas OK","");
- delay(4000);
- //return;// *
- else{//*
- Serial.println("initialization done.");//
- lcdaffiche("carte SD OK","");
- delay(4000);
- lecturecartesd("tabmin.txt",tabvaleurmin);
- lecturecartesd("tabmax.txt",tabvaleurmax);
- void loop()
- reglage();
- menu();
- balle();
- eclosion();
- propagation();
- mouvementsynchrone();
- mouvementsinusoidal();
- mouvementsinusimage();
- lettre("HELLO[[[");
- if(quelboutonpese()==4){menu();}
