查看: 2802|回復: 0
數模轉換,可預設電源電壓輸出(單片機程序+Proteus仿真例程)
/* 主程序 */
        uchar j,key;
    uint temp;
        P20 = 1;
        P21 = 1;                                                        // 關閉數碼管顯示
        TMOD = 0x11;                                                // T0,T1工作方式1
        /* 2ms 定時設置 */
        TH0 = -2000/256;
        TL0 = 2000%256;
        /* 啟動計數器0,關閉計數器1 */
        TR0 = 1;
        ET0 = 1;
        TR1 = 0;
        ET1 = 1;
        EA = 1;
        count = 0;                                                // 初始計數器設為0
        enterflag = 0;                                        // 沒有按下確認鍵
        lh = 0;
        pwflag = 0;                                                // 標志先置為0
        digbit = 0x01;                                        // 從第一位數碼管開始動態掃描
        /* 剛加電時,bu顯示*/
        for (j=0;j<2;j++)
                wordbuf[j] = 17;
        showflag = 1;                                        // 打開數碼管顯
                key = keyscan();                                        // 調用鍵盤掃描函數
        switch(key)
                      case 0x11:                                                // 1行1列,數字1
                                if (count<2)
                                        wordbuf[count] = 1;        // 對應位上顯示“1”
                                        pwbuf[count] = 1;
                                        if(count==0)
                    {a=1;
                                        if(count==1)
                    {b=1;
                                        count++;
                                break;
                        case 0x21:                                                // 1行2列,數字3
                                if (count<2)
                                        wordbuf[count] = 2;        // 對應位上顯示“2"
                                        pwbuf[count] = 2;
                                        if(count==0)
                    {a=2;
                                        if(count==1)
                    {b=2;
                                        count++;
                                break;
                        case 0x41:                                                // 1行3列,數字3
                                if (count<2)
                                        wordbuf[count] = 3;        // 對應位上顯示“3"
                                        pwbuf[count] = 3;
                                        if(count==0)
                    {a=3;
                                        if(count==1)
                    {b=3;
                                        count++;
                                break;
                        case 0x12:                                                // 2行1列,數字4
                                if (count<2)
                                        wordbuf[count] = 4;        // 對應位上顯示“4"
                                        pwbuf[count] = 4;
                                        if(count==0)
                    {a=4;
                                        if(count==1)
                    {b=4;
                                        count++;
                                break;
                        case 0x22:                                                // 2行2列,數字5
                                if (count<2)
                                        wordbuf[count] = 5;        // 對應位上顯示“5"
                                        pwbuf[count] = 5;
                                        if(count==0)
                    {a=5;
                                        if(count==1)
                    {b=5;
                                        count++;
                                break;
                        case 0x42:                                                // 2行3列,數字6
                                if (count<2)
                                        wordbuf[count] = 6;        // 對應位上顯示“6"
                                        pwbuf[count] = 6;
                                    if(count==0)
                    {a=6;
                                        if(count==1)
                    {b=6;
                                        count++;
                                break;
                        case 0x14:                                                // 3行1列,數字7
                                if (count<2)
                                        wordbuf[count] = 7;        // 對應位上顯示“7"
                                        pwbuf[count] = 7;
                                        if(count==0)
                    {a=7;
                                        if(count==1)
                    {b=7;
                                        count++;
                                break;
                        case 0x24:                                                // 3行2列,數字8
                                if (count<2)
                                        wordbuf[count] = 8;        // 對應位上顯示“8"
                                        pwbuf[count] = 8;
                                        if(count==0)
                    {a=8;
                                        if(count==1)
                    {b=8;
                                        count++;
                                break;
                        case 0x44:                                                // 3行3列,數字9
                                if (count<2)
                                        wordbuf[count] = 9;        // 對應位上顯示“9"
                                        pwbuf[count] = 9;
                                        if(count==0)
                    {a=9;
                                        if(count==1)
                    {b=9;
                                        count++;
                                break;
                         case 0x18:                                                // 4行1列,數字*
                                count = 0;
                                P3=0;
                                px=0;                                        // 顯示清零
                                for (j=0;j<2;j++)
                                        wordbuf[j] = 17;                        // 數碼管不顯示
                                        pwbuf[j] = 0;                // 用FFFFFF清除已經輸入的密碼
                                break;
                        case 0x28:                      // 4行2列,數字0
                                if (count<2)
                                        wordbuf[count] = 0;        // 對應位上顯示“0"
                                        pwbuf[count] = 0;
                                        if(count==0)
                    {a=0;
                                        if(count==1)
                    {b=0;
                                        count++;
                                break;
                        case 0x48:                                                // 4行3列,數字#
                                 enterflag = 1;                                // 確認鍵按下
                                 if (count==2)                                 // 只有輸入2個數后按確認鍵才有效輸出
                                    pwflag = 1;
                                break;
                        default:break;
                if (enterflag==1)                                        // 如果按下確認鍵
                        enterflag = 0;                                         // 標志位置回0
                        count = 0;                      // 計數器清零
                        c=0xff/6;
                        if (pwflag==1)
             P3=a*c+b*c/10+12*c/100;
             temp=a*c+b*c/10+12*c/100;
               if(temp>=0xff)
                  P3=0xff;
全部資料51hei下載地址:
可預設電壓源.zip (87.87 KB, 下載次數: 37)
收藏收藏2 分享淘帖 頂 踩
