分享一下GY-271 HMC5883L的資料 手冊 單片機例程 希望對需要的老哥們有幫助。!
內(nèi)容
2019-4-9 15:38 上傳
- #include "reg52.h"
- #include "intrins.h"
- #include "math.h"
- #include "iic.h"
- #include "lcd.h"
- #include "stdio.h"
- u8 ge=0,shi=0,bai=0,qian=0,wan=0; //顯示變量
- u8 BUF[8]=0; //數(shù)據(jù)緩沖區(qū)
- //******************************顯示在LCD的數(shù)據(jù)取位********************************//
- void Conversion(u16 temp_data)
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運算
- ge=temp_data+0x30;
- void main()
- // u16 i;
- int X=0,Y=0,Z=0;
- double Angle_XY=0,Angle_XZ=0,Angle_YZ=0;
- Delay_ms(200);
- Init_Lcd();
- Init_QMC5883();
- Delay_ms(300);
- while(1)
- Multiple_Read_QMC5883(); //連續(xù)讀取三軸角度數(shù)據(jù),存儲在BUF中
- //---------顯示XY軸
- X=BUF[1] << 8 | BUF[0]; //Combine MSB and LSB of X Data output register 最高有效位
- Y=BUF[3] << 8 | BUF[2]; //Combine MSB and LSB of Y Data output register
- Z=BUF[5] << 8 | BUF[4]; //Combine MSB and LSB of Z Data output register
- if(X>0x7fff)X-=0xffff;
- if(Y>0x7fff)Y-=0xffff;
- if(Z>0x7fff)Z-=0xffff;
- Display_One_Char(0,0,'Q');
- Display_One_Char(1,0,'M');
- Display_One_Char(2,0,'C');
- Display_One_Char(3,0,'5');
- Display_One_Char(4,0,'8');
- Display_One_Char(5,0,'8');
- Display_One_Char(6,0,'3');
- Angle_XY= atan2((double)Y,(double)X) * (180 / 3.14159265) + 180; //計算XY平面角度
- Angle_XY*=10;
- Conversion(Angle_XY); //計算XY平面角度數(shù)據(jù)和顯示
- Display_One_Char(8,0,'X');
- Display_One_Char(9,0,'Y');
- Display_One_Char(10,0,':');
- Display_One_Char(11,0,qian);
- Display_One_Char(12,0,bai);
- Display_One_Char(13,0,shi);
- Display_One_Char(14,0,'.');
- Display_One_Char(15,0,ge);
- Angle_XZ= atan2((double)Z,(double)X) * (180 / 3.14159265) + 180; //計算XZ平面角度
- Angle_XZ*=10;
- Conversion(Angle_XZ); //計算XZ平面角度數(shù)據(jù)和顯示
- Display_One_Char(0,1,'X');
- Display_One_Char(1,1,'Z');
- Display_One_Char(2,1,':');
- Display_One_Char(3,1,qian);
- Display_One_Char(4,1,bai);
- Display_One_Char(5,1,shi);
- Display_One_Char(6,1,'.');
- Display_One_Char(7,1,ge);
- Angle_YZ= atan2((double)Z,(double)Y) * (180 / 3.14159265) + 180; //計算YZ平面角度
- Angle_YZ*=10;
- Conversion(Angle_YZ); //計算YZ平面角度數(shù)據(jù)和顯示
- Display_One_Char(8,1,'Y');
- Display_One_Char(9,1,'Z');
復(fù)制代碼- //***************************************
- // HMC5883 51串口測試程序
- // 使用單片機STC89C51
- // 晶振:11.0592M
- // 顯示:PC串口
- // 編譯環(huán)境 Keil uVision2
- // 參考宏晶網(wǎng)站24c04通信程序
- // 時間:2011年3月1日
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- //使用的端口,請按照以下接線
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^0; //IIC時鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據(jù)引腳定義
- #define SlaveAddress 0x3C //定義器件5883在IIC總線中的從地址
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- int dis_data; //變量
- void delay(unsigned int k);
- void Init_HMC5883(void); //初始化5883
- void conversion(uint temp_data);
- void Single_Write_HMC5883(uchar REG_Address,uchar REG_data); //單個寫入數(shù)據(jù)
- //uchar Single_Read_HMC5883(uchar REG_Address); //單個讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read_HMC5883(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- //以下是模擬iic使用函數(shù)-------------
- void Delay5us();
- void Delay5ms();
- void HMC5883_Start();
- void HMC5883_Stop();
- void HMC5883_SendACK(bit ack);
- bit HMC5883_RecvACK();
- void HMC5883_SendByte(BYTE dat);
- BYTE HMC5883_RecvByte();
- void HMC5883_ReadPage();
- void HMC5883_WritePage();
- //串口初始化
- //9600 bps @ 11.059 MHz
- void init_uart()
- TMOD=0x21;
- TH1=0xfd;
- TL1=0xfd;
- SCON=0x50;
- PS=1; //串口中斷設(shè)為高優(yōu)先級別
- TR0=1; //啟動定時器
- TR1=1;
- ET0=1; //打開定時器0中斷
- ES=1;
- //*********串口數(shù)據(jù)發(fā)送******************
- void SeriPushSend(uchar send_data)
- SBUF=send_data;
- while(!TI);TI=0;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- 延時5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時鐘過快時需要修改
- 當(dāng)改用1T的MCU時,請調(diào)整此延時函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 0; //產(chǎn)生下降沿
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- 停止信號
- SDA = 0; //拉低數(shù)據(jù)線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 1; //產(chǎn)生上升沿
- Delay5us(); //延時
- 發(fā)送應(yīng)答信號
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- 接收應(yīng)答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- CY = SDA; //讀應(yīng)答信號
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return CY;
- 向IIC總線發(fā)送一個字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- HMC5883_RecvACK();
- 從IIC總線接收一個字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- dat |= SDA; //讀數(shù)據(jù)
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return dat;
- HMC5883_Start(); //起始信號
- HMC5883_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫信號
- HMC5883_SendByte(REG_Address); //內(nèi)部寄存器地址,請參考中文pdf
- HMC5883_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),請參考中文pdf
- HMC5883_Stop(); //發(fā)送停止信號
- //********單字節(jié)讀取內(nèi)部寄存器*************************
- uchar Single_Read_HMC5883(uchar REG_Address)
- { uchar REG_data;
- HMC5883_SendByte(REG_Address); //發(fā)送存儲單元地址,從0開始
- HMC5883_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號
- REG_data=HMC5883_RecvByte(); //讀出寄存器數(shù)據(jù)
- HMC5883_SendACK(1);
- HMC5883_Stop(); //停止信號
- return REG_data;
- //連續(xù)讀出HMC5883內(nèi)部角度數(shù)據(jù),地址范圍0x3~0x5
- void Multiple_read_HMC5883(void)
- { uchar i;
- HMC5883_SendByte(0x03); //發(fā)送存儲單元地址,從0x3開始
- for (i=0; i<7; i++) //連續(xù)讀取6個地址數(shù)據(jù),存儲中BUF
- BUF[i] = HMC5883_RecvByte(); //BUF[0]存儲0x32地址中的數(shù)據(jù)
- if (i == 6)
- HMC5883_SendACK(1); //最后一個數(shù)據(jù)需要回NOACK
- else
- HMC5883_SendACK(0); //回應(yīng)ACK
- Delay5ms();
- //初始化HMC5883,根據(jù)需要請參考pdf進行修改****
- void Init_HMC5883()
- Single_Write_HMC5883(0x02,0x00); //
- Single_Write_HMC5883(0x01,0xE0); //
- //主程序********
- void main()
- { // bit sign_bit;
- unsigned int i;
- int x,y,z;
- double angle;
- delay(100);
- init_uart();
- Init_HMC5883();
- while(1) //循環(huán)
- Multiple_Read_HMC5883(); //連續(xù)讀出數(shù)據(jù),存儲在BUF中
- x = BUF[0] << 8 | BUF[1];
- y = BUF[4] << 8 | BUF[5];
- z = BUF[2] << 8 | BUF[3];
- angle= atan2((double)y,(double)x) * (180 / 3.14159265) + 180; // angle in degrees
- conversion(angle); //計算數(shù)據(jù)和顯示
- SeriPushSend(bai);
- SeriPushSend(shi);
- SeriPushSend(ge);
- SeriPushSend(0x0d);
- SeriPushSend(0x0a);
- for (i=0;i<10000;i++); //延時
GY-271 QMC5883L電子指南針羅盤模塊 三軸磁場傳感器(1).zip
(3.18 MB, 下載次數(shù): 33)
2019-4-9 15:38 上傳
GY-271 HMC5883L 下載積分: 黑幣 -5
