2019-4-9 14:06 上傳
#include<reg52.h>
unsigned char code dispbitcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char dispbuf[4];
unsigned int i;
unsigned int j;
unsigned int getdata;
unsigned int temp;
unsigned int temp1;
unsigned char count;
unsigned char d;
sbit ST=P2^4;
sbit OE=P2^5;
sbit EOC=P2^6;
sbit CLK=P2^7;
sbit ADD_A=P3^4; //選擇AD的輸入端
sbit ADD_B=P3^5;
sbit ADD_C=P3^6;
sbit D0=P2^0; //數(shù)碼管的位控制端
sbit D1=P2^1;
sbit D2=P2^2;
sbit D3=P2^3;
sbit P17=P1^7; //確定小數(shù)點的位置
sbit s1=P3^2;
sbit s2=P3^3;
#define _v0_5 {s1=1;s2=0;}
#define _v10 {s1=0;s2=1;}
unsigned char m;
void TimeInitial();
void Delay(unsigned int i);
void TimeInitial()
{ TMOD=0x10;
TH1=(65536-200)/256;
TL1=(65536-200)%256;
EA=1;
ET1=1;
TR1=1;
unsigned int j;
for(;i>0;i--)
for(j=0;j<125;j++)
void Display()
P1=dispbitcode[dispbuf[3]];
D0=0;
D1=1;
D2=1;
D3=1;
Delay(10);
P1=0x00;
P1=dispbitcode[dispbuf[2]];
if(m==2)
P17=1;
D0=1;
D1=0;
D2=1;
D3=1;
Delay(10);
P1=0x00;
P1=dispbitcode[dispbuf[1]];
if(m==10)
P17=1;
D0=1;
D1=1;
D2=0;
D3=1;
Delay(10);
P1=0x00;
P1=dispbitcode[dispbuf[0]];
D0=1;
D1=1;
D2=1;
D3=0;
Delay(10);
P1=0x00;
TimeInitial();
ADD_A=0;
ADD_B=0;
ADD_C=0;
_v10;
m=2;
ST=0;
OE=0;
ST=1;
ST=0;
while(EOC==0);
OE=1;
getdata=P0;
OE=0;
if ((s1==0) && (s2==1) && (getdata<6))
ADD_A=1;
_v0_5;
m=10;
else if ((s1==1)&&(s2==0) && (getdata>254))
ADD_A=0;
_v10;
m=2;
temp=(getdata*1.0/255)*500*m;
dispbuf[0]=temp%10;
dispbuf[1]=temp/10%10;
dispbuf[2]=temp/100%10;
dispbuf[3]=temp/1000;
Display();
void t1(void) interrupt 3 using 0
CLK=~CLK;
