查看: 1944|回復: 4
為什么用FOR循環取余數碼管顯示就不正常呢
ID:505859 發表于 2019-4-6 17:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit LA=P2^2;
sbit LB=P2^3;
sbit LC=P2^4;
unsigned char code smguan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                            0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char Ledbuf[6]={0x00,0x00,0x00,0x00,0x00,0x00};
unsigned int counter=0;
unsigned char buf[6];
unsigned int stopwatch=65000;
void T1_Timer();
void main(void)
         unsigned char i=0;
         T1_Timer();
                 if(counter==1000)
                                 counter=0;
                                 stopwatch--;
                                  for(i=0;i<6;i++)
                                                        buf[i]=stopwatch%10;
                                                         stopwatch /=10;
void T1_Timer()
          TMOD=0X01;
          TH0=0XFC;
          TL0=0X18;
          TR0=1;
          EA=1;
          ET0=1;
void Keyscan()
         static unsigned char i=0;
         P0=0X00;
         switch(i)
                 case 0: LA=0;LB=0;LC=0;break;
                 case 1: LA=1;LB=0;LC=0;break;
                 case 2: LA=0;LB=1;LC=0;break;
                 case 3: LA=1;LB=1;LC=0;break;
                 case 4: LA=0;LB=0;LC=1;break;
                 case 5: LA=1;LB=0;LC=1;break;
                 case 6: LA=0;LB=1;LC=1;break;
                 case 7: LA=1;LB=1;LC=1;break;
                 default:break;
           P0=smguan[buf[i]];
                 i++;
            if(i==8)i=0;
void interrupt_Timter1() interrupt 1
                  TH0=0XFC;
              TL0=0X18;
                  counter++;
                  Keyscan();
ID:164602 發表于 2019-4-6 22:09 | 只看該作者
是你的程序問題,與for無關
給你改好了,試試看
#include<reg52.h>
sbit LA=P2^2;
sbit LB=P2^3;
sbit LC=P2^4;
unsigned int stopwatch=12345,ST;
void T1_Timer();
void main(void)
         unsigned char i=0;
         T1_Timer();
                                 ST=stopwatch;
                 if(counter>=1000)
                                 counter=0;
                                 stopwatch--;
                                  for(i=0;i<6;i++)
                                                        buf[i]=ST%10;
                                                         ST /=10;
void T1_Timer()
          TMOD=0X01;
          TH0=0Xfc;
          TL0=0X18;
          TR0=1;
          EA=1;
          ET0=1;
void Keyscan()
         static unsigned char j=0;
         P0=0X00;
         switch(j)
                 default:break;
           P0=smguan[buf[j]];
                 j++;
            if(j==8)j=0;
                  TH0=0Xfc;
              TL0=0X18;
                  counter++;
                  Keyscan();
ID:213173 發表于 2019-4-6 22:43 | 只看該作者
你這樣處理只循環1次stopwatch就面目全非了,需要加一個臨時變量過渡才不會破壞stopwatch。
void main(void)
        unsigned char i=0;
        unsigned int count;
        T1_Timer();
                if(counter==1000)
                        counter=0;
                        stopwatch--;
                        count=stopwatch;
                        for(i=0;i<6;i++)
                                buf[i]=count%10;
                                count/=10;
ID:505859 發表于 2019-4-7 08:33 | 只看該作者
wulin 發表于 2019-4-6 22:43
void main(voi ...
好的,謝謝
HC6800-ES-V2.0 發表于 2019-4-6 22:09
是你的程序問題,與for無關
給你改好了,試試看
#include
好了,謝謝!
