查看: 4772|回復: 3
proteus仿真msp430,實現一個按鍵矩陣掃描和UART發送
功能概述:
       實現一個4x4按鍵矩陣,通過按鍵掃描,當有按鍵按下時,識別按鍵值,并通過UART串口發送,同時在lcd1602顯示。
功能實現:
1.    按鍵掃描
  1. void keyboardScan(){
  2.   P1OUT = 0xef;//P1.4 = 0
  3.   if((P1IN & 0x0f) != 0x0f){
  4.     delay_ms8M(5);//消抖
  5.     if((P1IN & 0x0f) != 0x0f){
  6.       if((P1IN & 0x01) == 0){ keyValue = '3';while((P1IN & 0x01) == 0);};
  7.       if((P1IN & 0x02) == 0){ keyValue = '7';while((P1IN & 0x02) == 0);};
  8.       if((P1IN & 0x04) == 0){ keyValue = 'B';while((P1IN & 0x04) == 0);};
  9.       if((P1IN & 0x08) == 0){ keyValue = 'F';while((P1IN & 0x08) == 0);};
  10.       keyboard_envent = ~keyboard_envent;
  11.     }
  12.   }
  13.   P1OUT = 0xdf;//P1.5 = 0
  14.   if((P1IN & 0x0f) != 0x0f){
  15.     delay_ms8M(5);//消抖
  16.     if((P1IN & 0x0f) != 0x0f){
  17.       if((P1IN & 0x01) == 0){ keyValue = '2';while((P1IN & 0x01) == 0);};
  18.       if((P1IN & 0x02) == 0){ keyValue = '6';while((P1IN & 0x02) == 0);};
  19.       if((P1IN & 0x04) == 0){ keyValue = 'A';while((P1IN & 0x04) == 0);};
  20.       if((P1IN & 0x08) == 0){ keyValue = 'E';while((P1IN & 0x08) == 0);};
  21.       keyboard_envent = ~keyboard_envent;
  22.     }
  23.   }
  24.   P1OUT = 0xbf;//P1.6 = 0
  25.   if((P1IN & 0x0f) != 0x0f){
  26.     delay_ms8M(5);//消抖
  27.     if((P1IN & 0x0f) != 0x0f){
  28.       if((P1IN & 0x01) == 0){ keyValue = '1';while((P1IN & 0x01) == 0);};
  29.       if((P1IN & 0x02) == 0){ keyValue = '5';while((P1IN & 0x02) == 0);};
  30.       if((P1IN & 0x04) == 0){ keyValue = '9';while((P1IN & 0x04) == 0);};
  31.       if((P1IN & 0x08) == 0){ keyValue = 'D';while((P1IN & 0x08) == 0);};
  32.       keyboard_envent = ~keyboard_envent;
  33.     }
  34.   }
  35.   P1OUT = 0x7f;//P1.7 = 0
  36.   if((P1IN & 0x0f) != 0x0f){
  37.     delay_ms8M(5);//消抖
  38.     if((P1IN & 0x0f) != 0x0f){
  39.       if((P1IN & 0x01) == 0){ keyValue = '0';while((P1IN & 0x01) == 0);};
  40.       if((P1IN & 0x02) == 0){ keyValue = '4';while((P1IN & 0x02) == 0);};
  41.       if((P1IN & 0x04) == 0){ keyValue = '8';while((P1IN & 0x04) == 0);};
  42.       if((P1IN & 0x08) == 0){ keyValue = 'C';while((P1IN & 0x08) == 0);};
  43.       keyboard_envent = ~keyboard_envent;
  44.     }
  45. <div>  }</div><div>}</div>
2.    UART初始化
  1. void uartInit(){
  2.   DCOCTL = 0;
  3.   BCSCTL1 = CALBC1_1MHZ;                    // 選擇1MHZ作為波特率發生器輸入時鐘頻率
  4.   DCOCTL = CALDCO_1MHZ;
  5.
  6.   P3SEL = 0X30;         // P3.4 TX    P3.5 RX
  7.   UCA0CTL1 |= UCSSEL_2;//clk = SMCLK 輔助時鐘   select clock source
  8.   UCA0BR0 = 104;       // 1MHZ / 9600 = 104.17
  9.   UCA0BR1 = 0;         // baud rate 9600
  10.   UCA0MCTL = UCBRS0;//波特率調整  0.17 * 8 = 1.36 取整 1
  11.
  12.   UCA0CTL1 &= ~UCSWRST;              // 初始化USCI,復位釋放,結束初始化
  13. }
3.    LCD1602初始化
  1. void lcd1602Init(){
  2.   P3DIR |= BIT0 + BIT1 + BIT2;
  3.   dataout;
  4.   rst_en;
  5.   P1DIR = 0X70;
  6.   write_com(0x38);//8 bit data, doule line, 5x7 point matrix
  7.   write_com(0x0c);//open display, close cusor,close blink
  8.   write_com(0x06);//auto move to next char after write or read
  9.   write_com(0x01);//clear screen
  10. }
實現過程中遇到的問題:
1.    按鍵按下后會連續不斷的發送,就算以很快的速度按下還是會發送兩次。
解決辦法:等待按鍵放開。
2.    Proteus虛擬終端關閉后再也打不開。
解決辦法:感覺這是一個bug,只能重新建一個項目。
ID:345368 發表于 2019-5-7 21:37 | 只看該作者
IAR和proteus文件夾里是空的
ID:429971 發表于 2019-5-8 14:29 | 只看該作者
jaedong 發表于 2019-5-7 21:37
IAR和proteus文件夾里是空的
不是吧,我傳的時候是有的,要不你留一個郵箱我發給你吧
ID:304785 發表于 2020-6-18 22:00 | 只看該作者
這不是一個bug,你只要點擊菜單欄debug-》virtual儀器,就可以重新打開。
