查看: 2704|回復: 1
51單片機智能音樂藍牙控制時鐘臺燈源代碼
基于51單片機的音樂藍牙臺燈,擁有音樂播放功能,手機SPF軟件藍牙控制功能,可實現手機控制播放,暫停,切換歌,按鍵同理,
實時檢測溫濕度,時間鬧鐘功能
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <math.h>
  4. typedef unsigned char BYTE;
  5. typedef unsigned int WORD;
  6. #define uchar unsigned char
  7. #define uint unsigned int
  8. uchar receive=0;
  9. int i=0;
  10. bit busy;
  11. bit qhgn=0; //切換功能標志位
  12. sbit dula=P2^6;
  13. sbit wela=P2^7;
  14. sbit leden=P3^4;
  15. sbit ledrs=P3^5;
  16. sbit ledrw=P3^6;
  17. sbit s0=P2^1;  //按鍵
  18. sbit s1=P2^2;
  19. sbit s2=P2^4;
  20. sbit s3=P2^5;
  21. sbit s4=P1^1;
  22. sbit deng=P1^0;  //播歌指示燈
  23. sbit dscs=P1^4;  //ds12c887
  24. sbit dsas=P1^5;
  25. sbit dsrw=P1^6;
  26. sbit dsds=P1^7;
  27. sbit Data=P2^0;  //DHT11
  28. void set_time();
  29. void write_ds(uchar add,uchar date);
  30. void SendData(unsigned char* bytes);
  31. void SendByte(unsigned char byte);
  32. uchar code MP3data1[4]={0xfd,0x02,0x01,0xdf};  //播放
  33. uchar code MP3data2[4]={0xfd,0x02,0x02,0xdf};  //暫停
  34. uchar code MP3data3[4]={0xfd,0x02,0x03,0xdf};  //切歌
  35. uchar code MP3data4[4]={0xfd,0x02,0x06,0xdf};//降低?
  36. //unsigned int MP3data5[6]={0xfd,0x04,0x41,0x00,0x01,0xdf};
  37. uchar num,count,shi,fen,miao,s0num,flag=0,nian,yue,ri;
  38. uint RH,TH;
  39. uchar code table[]="  20  .  .     C";
  40. uchar code table1[]="    :  :      RH";
  41. uchar rec_dat[9]="12369566";
  42. void Delay20ms(unsigned int z)
  43. {
  44.         unsigned int i, j;
  45.         for(i=z;i>0;i--)
  46.         for(j=110;j>0;j--);
  47. }
  48. void Delay_1ms(int i)//1ms延時
  49. {
  50.         int x,j;
  51.         for(j=i;j>0;j--)
  52.           for(x=110;x>0;x--);
  53. }
  54. /********************************************************************
  55. * 名稱 : Com_Init()
  56. * 功能 : 串口初始化,晶振11.0592,波特率9600,使能了串口中斷
  57. * 輸入 : 無
  58. * 輸出 : 無
  59. ***********************************************************************/
  60. void Com_Init()
  61. {
  62.   SCON = 0x50;                //8???,?????
  63.         TMOD = 0x20;                //?????1?8???????
  64.         TL1 = 0xfd;                //??????
  65.         TH1 = 0xfd;
  66.         TR1 = 1;
  67.
  68.                 SM0=0;
  69.                 SM1=1;
  70.                 REN=1;
  71.                 EA=1;
  72.                 ES=1;
  73. }
  74. ///////////////////////////////////DHT11
  75. void DHT11_delay_us(uchar n)
  76. {
  77.     while(--n);
  78. }
  79. void DHT11_delay_ms(uint z)
  80. {
  81.    uint i,j;
  82.    for(i=z;i>0;i--)
  83.       for(j=110;j>0;j--);
  84. }
  85. void DHT11_start()
  86. {
  87.    Data=1;
  88.    DHT11_delay_us(2);
  89.    Data=0;
  90.    DHT11_delay_ms(20);
  91.    Data=1;
  92.    DHT11_delay_us(30);
  93. }
  94. uchar DHT11_rec_byte()
  95. {
  96.    uchar i,dat=0;
  97.   for(i=0;i<8;i++)
  98.    {
  99.       while(!Data);
  100.       DHT11_delay_us(8);
  101.       dat<<=1;
  102.       if(Data==1)
  103.          dat+=1;
  104.       while(Data);
  105.     }
  106.     return dat;
  107. }
  108. void DHT11_receive()
  109. {
  110.     uchar R_H,R_L,T_H,T_L,revise;
  111.     DHT11_start();
  112.     if(Data==0)
  113.     {
  114.         while(Data==0);
  115.         DHT11_delay_us(40);
  116.         R_H=DHT11_rec_byte();
  117.         R_L=DHT11_rec_byte();
  118.         T_H=DHT11_rec_byte();
  119.         T_L=DHT11_rec_byte();
  120.         revise=DHT11_rec_byte();
  121.         DHT11_delay_us(25);
  122.         if((R_H+R_L+T_H+T_L)==revise)
  123.         {
  124.             RH=R_H|R_L;
  125.             TH=T_H|T_L;
  126.         }
  127.      }
  128. }
  129. ///////////////////////////////LCD
  130. void delay(uchar z)
  131. {
  132.   uchar x,y;
  133.         for(x=z;x>0;x--)
  134.           for(y=110;y>0;y--);
  135. }
  136. void write_com(uchar com)
  137. {
  138.   ledrs=0;
  139.         leden=1;
  140.         delay(5);
  141.         P0=com;
  142.         delay(5);
  143.         leden=0;
  144. }
  145. void write_date(uchar date)
  146. {
  147.   ledrs=1;
  148.         leden=1;
  149.         delay(5);
  150.         P0=date;
  151.         delay(5);
  152.         leden=0;
  153. }
  154. void write_sfm(uchar add,date)
  155. {
  156.         uchar shi,ge;
  157.         shi=date/10;
  158.         ge=date%10;
  159.   write_com(0x80+0x40+add);
  160.         write_date(0x30+shi);
  161.         write_date(0x30+ge);
  162. }
  163. void write_nyr(uchar add,uchar date)
  164. {
  165.         uchar shi,ge;
  166.         shi=date/10;
  167.         ge=date%10;
  168.         write_com(0x80+add);
  169.         write_date(0x30+shi);
  170.         write_date(0x30+ge);
  171. }
  172. void write_SHIDU(unsigned char add,unsigned char date)
  173. {
  174.         unsigned char shi,ge;
  175.         shi=date/10;
  176.         ge=date%10;
  177.         write_com(0x80+0x40+add);
  178.         write_date(0x30+shi);
  179.         write_date(0x30+ge);
  180. }
  181. void write_WENDU(unsigned char add,unsigned char date)
  182. {
  183.         unsigned char shi,ge;
  184.         shi=date/10;
  185.         ge=date%10;
  186.         write_com(0x80+add);
  187.         write_date(0x30+shi);
  188.         write_date(0x30+ge);
  189. }
  190. /////////////////////////////按鍵
  191. void keyscan()
  192. {
  193.   if(qhgn==0)        /////////////////改時間
  194.         {
  195.                 if(s0==0)           ////移動光標
  196.                 {
  197.                         delay(2);
  198.                         if(s0==0)
  199.                         {
  200.                                 s0num++;
  201.                                 while(!s0);
  202.                         }
  203.                 }
  204.                 if(s3==0)
  205.                 {
  206.                                 delay(1);
  207.                                 if(s3==0)
  208.                                 {
  209.                                         if(s0num>=1)
  210.                                         s0num--;
  211.                                         while(!s3);
  212.                                 }
  213.                 }
  214.
  215.                                         if(s0num==1)              //////光標位置
  216.                                 {
  217.                                   flag=1;
  218.                                         write_com(0x80+0x40+9);
  219.                                         write_com(0x0f);
  220.                                 }
  221.                                 if(s0num==2)
  222.                                 {
  223.                                         write_com(0x80+0x40+6);
  224.                                         write_com(0x0f);
  225.                                 }
  226.                                 if(s0num==3)
  227.                                 {
  228.                                         write_com(0x80+0x40+3);
  229.                                         write_com(0x0f);
  230.                                 }
  231.                                 if(s0num==4)
  232.                                 {
  233.                                         write_com(0x80+11);
  234.                                         write_com(0x0f);
  235.                                 }
  236.                                 if(s0num==5)
  237.                                 {
  238.                                         write_com(0x80+8);
  239.                                         write_com(0x0f);
  240.                                 }
  241.                                 if(s0num==6)
  242.                                 {
  243.                                         write_com(0x80+5);
  244.                                         write_com(0x0f);
  245.                                 }
  246.
  247.                                 if(s0num==7)                        ///重載時間
  248.                                 {
  249.                                         s0num=0;
  250.                                         write_com(0x0c);
  251.                                         flag=0;
  252.                                         write_ds(0,miao);
  253.                                         write_ds(2,fen);
  254.                                         write_ds(4,shi);
  255.                                         write_ds(7,ri);
  256.                                         write_ds(8,yue);
  257.                                         write_ds(9,nian);
  258.                                 }
  259.
  260.                         if(s0num!=0)                     //////修改時間
  261.                                         {
  262.                                                 if(s1==0)
  263.                                                 {
  264.                                                         delay(2);
  265.                                                         if(s1==0)
  266.                                                         {
  267.        while(!s1);
  268.        if(s0num==1)
  269.        {
  270.        miao++;
  271.        if(miao==60)
  272.        miao=0;
  273.        write_sfm(8,miao);
  274.        write_com(0x80+0x40+9);
  275.        }
  276.        if(s0num==2)
  277.        {
  278.        fen++;
  279.        if(fen==60)
  280.        fen=0;
  281.        write_sfm(5,fen);
  282.        write_com(0x80+0x40+6);
  283.        }
  284.        if(s0num==3)
  285.        {
  286.        shi++;
  287.        if(shi==24)
  288.        shi=0;
  289.        write_sfm(2,shi);
  290.        write_com(0x80+0x40+3);
  291.        }
  292.        if(s0num==4)
  293.        {
  294.        ri++;
  295.        if(ri==31)
  296.        ri=1;
  297.        write_nyr(10,ri);
  298.        write_com(0x80+11);
  299.        }
  300.        if(s0num==5)
  301.        {
  302.        yue++;
  303.        if(yue==12)
  304.        yue=1;
  305.        write_nyr(7,yue);
  306.        write_com(0x80+8);
  307.        }
  308.        if(s0num==6)
  309.        {
  310.        nian++;
  311.        if(nian==99)
  312.        nian=0;
  313.        write_nyr(4,nian);
  314.        write_com(0x80+5);
  315.        }
  316.                                                         }
  317.                                                 }
  318.                                                 if(s2==0)
  319.                                                 {
  320.                                                         delay(2);
  321.                                                         if(s2==0)
  322.                                                         {
  323.        while(!s2);
  324.        if(s0num==1)
  325.        {
  326.        if(miao==0)
  327.        miao=60;
  328.        miao--;
  329.        write_sfm(8,miao);
  330.        write_com(0x80+0x40+9);
  331.        }
  332.        if(s0num==2)
  333.        {
  334.        if(fen==0)
  335.        fen=60;
  336.        --fen;
  337.        write_sfm(5,fen);
  338.        write_com(0x80+0x40+6);
  339.        }
  340.        if(s0num==3)
  341.        {
  342.        if(shi==0)
  343.        shi=24;
  344.        --shi;
  345.        write_sfm(2,shi);
  346.        write_com(0x80+0x40+3);
  347.        }
  348.        if(s0num==4)
  349.        {
  350.        if(ri==0)
  351.        ri=31;
  352.        ri--;
  353.        write_nyr(10,ri);
  354.        write_com(0x80+11);
  355.        }
  356.        if(s0num==5)
  357.        {
  358.        if(yue==0)
  359.        yue=12;
  360.        yue--;
  361.        write_nyr(7,yue);
  362.        write_com(0x80+8);
  363.        }
  364.        if(s0num==6)
  365.        {
  366.        if(nian==0)
  367.        nian=99;
  368.        nian--;
  369.        write_nyr(4,nian);
  370.        write_com(0x80+5);
  371.        }
  372.                                                         }
  373.                                                 }
  374.                                         }
  375.                                 if(s4==0)                    ///切換按鍵功能
  376.                                 {
  377.                                         delay(5);
  378.                                                 if(s4==0)
  379.                                                 {
  380.                                                         write_com(0x80+0x40);
  381.                                                         write_date('M');
  382.                                                         qhgn=1;
  383.                                                         while(!s4);
  384.                                                 }
  385.                                 }
  386.                         }
  387.
  388.
  389.                         if(qhgn==1)                        /////////////////按鍵切歌
  390.                         {
  391.                                                 if(s0==0)           ////播放
  392.                                                 {
  393.                                                         delay(2);
  394.                                                         if(s0==0)
  395.                                                         {
  396.        while(!s0);
  397.        deng=1;
  398.        for(i=0;i<4;i++)
  399.        {
  400.        SendData(MP3data1);
  401.        Delay20ms(2);
  402.        }
  403.
  404.                                                         }
  405.                                                 }
  406.        if(s1==0)           ////暫停
  407.        {
  408.        delay(2);
  409.        if(s1==0)
  410.        {
  411.        while(!s1);
  412.        deng=0;
  413.        for(i=0;i<4;i++)
  414.        {
  415.        SendData(MP3data2);
  416.        Delay20ms(2);
  417.        }
  418.
  419.        }
  420.        }
  421.        if(s2==0)           ////切歌
  422.        {
  423.        delay(2);
  424.        if(s2==0)
  425.        {
  426.        while(!s2);
  427.        for(i=0;i<4;i++)
  428.        {
  429.        SendData(MP3data3);
  430.        Delay20ms(2);
  431.        }
  432.
  433.        }
  434.        }
  435.        if(s3==0)           ////降低音量
  436.        {
  437.        delay(2);
  438.        if(s3==0)
  439.        {
  440.        while(!s3);
  441.        for(i=0;i<4;i++)
  442.        {
  443.        SendData(MP3data4);
  444.        Delay20ms(2);
  445.        }
  446.
  447.        }
  448.        }
  449.
  450.        if(s4==0)                     ///切換按鍵功能
  451.        {
  452.        delay(5);
  453.        if(s4==0)
  454.        {
  455.        while(!s4);
  456.        write_com(0x80+0x40);
  457.        write_date(' ');
  458.        qhgn=0;
  459.
  460.        }
  461.        }
  462.                         }
  463. }
  464. /*??*/
  465. void write_ds(uchar add,uchar date)
  466. {
  467.         dscs=0;
  468.         dsas=1;
  469.         dsds=1;
  470.         dsrw=1;
  471.         P0=add;
  472.         dsas=0;
  473.         dsrw=0;
  474.         P0=date;
  475.         dsrw=1;
  476.         dsas=1;
  477.         dscs=1;
  478. }
  479. uchar read_ds(uchar add)
  480. {
  481.         uchar ds_date;
  482.         dscs=0;
  483.         dsas=1;
  484.         dsds=1;
  485.         dsrw=1;
  486.         P0=add;
  487.         dsas=0;
  488.         dsds=0;
  489.         P0=0xff;
  490.         ds_date=P0;
  491.         dsds=1;
  492.         dsas=1;
  493.         dscs=1;
  494.         return ds_date;
  495. }
  496. void set_time()
  497. {
  498.         write_ds(0,0);   //秒
  499.         write_ds(2,51);   //分
  500.         write_ds(4,12);   //時
  501.         write_ds(7,21);   //日
  502.         write_ds(8,03);   //月
  503.         write_ds(9,19);   //年
  504. }
  505. /*???*/
  506. void init()
  507. {
  508.         ledrw=0;
  509.         wela=0;
  510.         dula=0;
  511.         set_time();
  512.
  513.   write_ds(0x0B,0x26);
  514.   write_ds(0x0A,0x20);        //打開振蕩器并允許RTC計時
  515.   write_ds(0x0B,0x06);   //關鬧鐘
  516.   read_ds(0x0c);
  517.
  518.   write_com(0x38);
  519.         write_com(0x0c);
  520.         write_com(0x06);
  521.   write_com(0x01);
  522.         for(num=0;num<16;num++)
  523.         {
  524.     write_date(table[num]);
  525.                 delay(5);
  526.         }
  527.         write_com(0x80+0x40);
  528.         for(num=0;num<16;num++)
  529.         {
  530.           write_date(table1[num]);
  531.                 delay(5);
  532.         }
  533. }
  534. void SendByte(unsigned char byte)
  535.         {
  536.     ES = 0;
  537.     SBUF = byte;
  538.     while(!TI);
  539.     TI = 0;
  540.     ES = 1;
  541. }
  542.
  543. void SendData(unsigned char* bytes)
  544.         {
  545.     int i = 0;
  546.     for(i=0;i<4;i++)
  547.                         {
  548.         SendByte(bytes[i]);
  549.                                 Delay_1ms(1);
  550.       }
  551.   }
  552. void main()
  553. {
  554.         Com_Init();//串口初始化
  555.   init();
  556.         while(1)
  557.         {
  558.                 keyscan();
  559.                 if(flag==0)
  560.                 {
  561.                         miao=read_ds(0);
  562.                         fen=read_ds(2);
  563.                         shi=read_ds(4);
  564.                         ri=read_ds(7);
  565.                         yue=read_ds(8);
  566.                         nian=read_ds(9);
  567.                         write_sfm(8,miao);
  568.                         write_sfm(5,fen);
  569.                         write_sfm(2,shi);
  570.                         write_nyr(10,ri);
  571.                         write_nyr(7,yue);
  572.                         write_nyr(4,nian);
  573.                 }
  574.                 keyscan();
  575.     DHT11_receive();
  576.                 write_SHIDU(12,RH);
  577.                 write_WENDU(13,TH);
  578.
  579.         }
  580. }
  581. /********************************************************************
  582. * 名稱 : Com_Int()
  583. * 功能 : 串口中斷子函數
  584. * 輸入 : 無
  585. * 輸出 : 無
  586. ***********************************************************************/
  587. void Com_Int() interrupt 4
  588. {
  589.         if(RI == 1)   //當硬件接收到一個數據時,RI會置位
  590.         {
  591.                 RI = 0;
  592.                 receive = SBUF ;
  593.         }
  594.         if(TI==0)
  595.         {
  596.                 TI=0;
  597.         }
  598.                 switch(receive)
  599.                 {
  600.                         case 0x01:SendData(MP3data1);break;//播放
  601.                         case 0x02:SendData(MP3data2);break;
  602.                         case 0x03:SendData(MP3data3);break;
  603.                 }
  604. }
全部資料51hei下載地址:
音樂藍牙臺燈.zip (107.35 KB, 下載次數: 24)
收藏收藏2 分享淘帖 頂 踩
ID:1 發表于 2019-4-5 02:32 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
