查看: 2152|回復(fù): 0
NY8A053A單片機(jī)芯片手冊(cè)下載
ID:14325 發(fā)表于 2019-4-4 00:01 | 顯示全部樓層 |閱讀模式
General Description
NY8A053A is an EPROM based 8-bit MCU tailored for I/O based applications like home appliances or meter
equipment. NY8A053A adopts advanced CMOS technology to provide customers remarkable solution with low cost,
high performance and high noise immunity benefits. RISC architecture is applied to NY8A053A and it provides 55
instructions. All instructions are executed in single instruction cycle except program branch and skip instructions
which will take two instruction cycles. Therefore, NY8A053A is very suitable for those applications that is
sophisticated but compact program size is required.
As NY8A053A address I/O type applications, it can provide 12 I/O pins for applications which require abundant input
and output functionality. Moreover, each I/O pin may have additional features, like pull-high/pull-low resistor and
open-drain output type through programming. Moreover, NY8A053A have built-in large infrared (IR) carrier
generator (340mA@3V) with selectable IR carrier frequency and polarity for applications which demand remote
control feature.
NY8A053A also provide 2 sets of timers which can be used as regular timer based on system oscillation or event
counter with external trigger clock. Moreover, NY8A053A provide 1 set of 8-bit resolution Pulse Width Modulation
(PWM) output and buzzer output in order to drive motor/LED and buzzer.
NY8A053A employ dual-clock oscillation mechanism, either high oscillation or low oscillation can be derived from
internal resistor/capacitor oscillator or external crystal oscillator. Moreover, based on dual-clock mechanism,
NY8A053A provide kinds of operation mode like Normal mode, Slow mode, Standby mode and Halt mode in order
to save power consumption and lengthen battery operation life. Moreover, it is possible to use internal highfrequency oscillator as CPU operating clock source and external 32KHz crystal oscillator as timer clock input, so as
to accurate count real time and maintain CPU working power.
While NY8A053A operate in Standby mode and Halt mode, kinds of event will issue interrupt requests and can
wake up NY8A053A to enter Normal mode and Slow mode in order to process urgent events.
NY8A053A_v1.1.pdf
2.4 MB, 下載次數(shù): 17, 下載積分: 黑幣 -5
NY8A053A
