查看: 1573|回復: 0
單片機并行口輸入輸出源程序
ID:502070 發表于 2019-3-31 23:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include"reg52.h"
#include<intrins.h>
#define IO_IN P1
#define IO_OUT P0
unsigned char LightData=0x11;
void Delay_Ms(unsigned int time)
        unsigned char i;
        while(time--)
                for(i=0;i<120;i++);
void operate()
        unsigned char temp;
        IO_IN=0X0F;
        temp=IO_IN&0x0F;
        switch(temp)
                case 0x00:
                IO_OUT=0x0F;
                break;
                case 0x01:
                IO_OUT=0x00;
                break;
                case 0x02:
                LightData=_crol_(LightData,1);
                IO_OUT=~LightData;
                Delay_Ms(1000);
                break;
                case 0x03:
                LightData=_cror_(LightData,1);
                IO_OUT=~LightData;
                Delay_Ms(1000);
                break;
                default:
                IO_OUT=temp;
                break;
                operate();
并行口輸入輸出.zip
16.54 KB, 下載次數: 3, 下載積分: 黑幣 -5
