查看: 5236|回復: 3
51單片機MPU6050數字陀螺儀與LCD12864顯示電路+程序
ID:394949 發表于 2019-3-30 18:11 | 顯示全部樓層 |閱讀模式
原理圖
原理圖
#include <REG52.H>
#include <math.h>
#include <stdio.h>
#include <INTRINS.H>
typedef unsigned char  uchar;
typedef unsigned short ushort;
typedef unsigned int   uint;
#define DataPort P0
sbit    SCL=P2^6;
sbit    SDA=P2^5;
sbit LCM_RS   = P3^7;
sbit LCM_RW   = P3^6;
sbit LCM_EN   = P3^5;
sbit LCD12864_PSB  = P1^5;
sbit LCD12864_RSET = P1^3;
// 定義MPU6050內部地址
#define SMPLRT_DIV      0x19    //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG          0x1A    //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG     0x1B    //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG    0x1C    //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H    0x3B
#define ACCEL_XOUT_L    0x3C
#define ACCEL_YOUT_H    0x3D
#define ACCEL_YOUT_L    0x3E
#define ACCEL_ZOUT_H    0x3F
#define ACCEL_ZOUT_L    0x40
#define TEMP_OUT_H      0x41
#define TEMP_OUT_L      0x42
#define GYRO_XOUT_H     0x43
#define GYRO_XOUT_L     0x44
#define GYRO_YOUT_H     0x45
#define GYRO_YOUT_L     0x46
#define GYRO_ZOUT_H     0x47
#define GYRO_ZOUT_L     0x48
#define PWR_MGMT_1      0x6B    //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I            0x75    //IIC地址寄存器(默認數值0x68,只讀)
#define SlaveAddress    0xD0    //IIC寫入時的地址字節數據,+1為讀取
uchar dis[4];
int dis_data;
//整數轉字符串
void lcd_printf(uchar *s,int temp_data)
    if(temp_data<0)
        temp_data=-temp_data;
        *s='-';
    else *s=' ';
    *++s =temp_data/100+0x30;
    temp_data=temp_data%100;     //取余運算
    *++s =temp_data/10+0x30;
    temp_data=temp_data%10;      //取余運算
    *++s =temp_data+0x30;
void delay(unsigned int k)
    unsigned int i,j;
    for(i=0;i<k;i++)
        for(j=0;j<121;j++);
void WaitForEnable(void)
    DataPort=0xff;
    LCM_RS=0;LCM_RW=1;_nop_();
    LCM_EN=1;_nop_();_nop_();
    while(DataPort&0x80);
    LCM_EN=0;
void WriteCommandLCM(uchar CMD)
    WaitForEnable();
    LCM_RS=0;LCM_RW=0;_nop_();
    DataPort=CMD;_nop_();
    LCM_EN=1;_nop_();_nop_();LCM_EN=0;
void WriteDataLCM(uchar dataW)
    WaitForEnable();
    LCM_EN=0;LCM_RS=1;LCM_RW=0;_nop_();
    DataPort=dataW;_nop_();
    LCM_EN=1;_nop_();LCM_EN=0;_nop_();
void LcdPos_xy(unsigned char x,unsigned char y)
    unsigned char pos;
    switch(x)
        case 1:pos=0x80+y-1;break;
        case 2:pos=0x90+y-1;break;
        case 3:pos=0x88+y-1;break;
        case 4:pos=0x98+y-1;break;
        default:pos=0x80+y-1;break;
    WriteCommandLCM(pos|0x80);
void DisplayListChar(uchar X,uchar Y,uchar *DData)
    LcdPos_xy(X,Y);
    while(*DData)
        WriteDataLCM(*DData++);
void InitLcd()
        LCD12864_PSB = 1;//并行通信
        LCD12864_RSET = 0;
        delay(10);
        LCD12864_RSET = 1;
        WriteCommandLCM(0x30);
        delay(5);
        delay(5);
        WriteCommandLCM(0x18);
        delay(5);
        WriteCommandLCM(0x10);
        delay(5);
        WriteCommandLCM(0x01);
        delay(5);
        WriteCommandLCM(0x06);
        delay(5);
        WriteCommandLCM(0x0c);
        delay(5);
        DisplayListChar(1,2,"加速度");
        DisplayListChar(1,6,"角速度");
        DisplayListChar(2,1,"X:");
        DisplayListChar(3,1,"Y:");
        DisplayListChar(4,1,"Z:");
void Delay5us()
    _nop_();_nop_();_nop_();_nop_();
//I2C起始信號
void I2C_Start()
    SDA = 1;                    //拉高數據線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 0;                    //產生下降沿
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
//I2C停止信號
void I2C_Stop()
    SDA = 0;                    //拉低數據線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 1;                    //產生上升沿
    Delay5us();                 //延時
//I2C發送應答信號
//入口參數:ack (0:ACK 1:NAK)
void I2C_SendACK(bit ack)
    SDA = ack;                  //寫應答信號
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
//I2C接收應答信號
bit I2C_RecvACK()
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    CY = SDA;                   //讀應答信號
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
    return CY;
//向I2C總線發送一個字節數據
void I2C_SendByte(uchar dat)
    uchar i;
    for (i=0; i<8; i++)         //8位計數器
        dat <<= 1;              //移出數據的最高位
        SDA = CY;               //送數據口
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    I2C_RecvACK();
//從I2C總線接收一個字節數據
uchar I2C_RecvByte()
    uchar i;
    uchar dat = 0;
    SDA = 1;                    //使能內部上拉,準備讀取數據,
        dat <<= 1;
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        dat |= SDA;             //讀數據
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    return dat;
//向I2C設備寫入一個字節數據
void Single_WriteI2C(uchar REG_Address,uchar REG_data)
    I2C_Start();                  //起始信號
    I2C_SendByte(SlaveAddress);   //發送設備地址+寫信號
    I2C_SendByte(REG_Address);    //內部寄存器地址,
    I2C_SendByte(REG_data);       //內部寄存器數據,
    I2C_Stop();                   //發送停止信號
//從I2C設備讀取一個字節數據
uchar Single_ReadI2C(uchar REG_Address)
    uchar REG_data;
    I2C_Start();                   //起始信號
    I2C_SendByte(REG_Address);     //發送存儲單元地址,從0開始
    I2C_Start();                   //起始信號
    I2C_SendByte(SlaveAddress+1);  //發送設備地址+讀信號
    REG_data=I2C_RecvByte();       //讀出寄存器數據
    I2C_SendACK(1);                //接收應答信號
    I2C_Stop();                    //停止信號
    return REG_data;
//初始化MPU6050
void InitMPU6050()
    Single_WriteI2C(PWR_MGMT_1, 0x00);  //解除休眠狀態
    Single_WriteI2C(SMPLRT_DIV, 0x07);
    Single_WriteI2C(CONFIG, 0x06);
    Single_WriteI2C(GYRO_CONFIG, 0x18);
    Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成數據
int GetData(uchar REG_Address)
    char H,L;
    H=Single_ReadI2C(REG_Address);
    L=Single_ReadI2C(REG_Address+1);
    return (H<<8)+L;   //合成數據
//在12864上顯示10位數據
void Display10BitData(uchar x,uchar y,int value)
    value/=64;                          //轉換為10位數據
    lcd_printf(dis, value);         //轉換數據顯示
    DisplayListChar(x,y,dis);
    delay(500);     //上電延時
    InitLcd();      //lcd12864液晶初始化
    InitMPU6050();  //初始化MPU6050
    delay(150);
        Display10BitData(2,2,GetData(ACCEL_XOUT_H));    //顯示X軸加速度
        Display10BitData(3,2,GetData(ACCEL_YOUT_H));    //顯示Y軸加速度
        Display10BitData(4,2,GetData(ACCEL_ZOUT_H));   //顯示Z軸加速度
        Display10BitData(2,6,GetData(GYRO_XOUT_H)); //顯示X軸角速度
        Display10BitData(3,6,GetData(GYRO_YOUT_H)); //顯示Y軸角速度
        Display10BitData(4,6,GetData(GYRO_ZOUT_H));    //顯示Z軸角速度
        delay(500);
希望老貼們喜歡!!!!!
ID:562317 發表于 2019-7-14 15:36 | 顯示全部樓層
我想問問這個怎么接單片機和陀螺儀的引腳呢?謝謝!
ID:496492 發表于 2019-7-24 16:00 | 顯示全部樓層
淘寶源碼,真的好嗎
ID:808634 發表于 2020-9-9 10:59 | 顯示全部樓層
請問頭文件在哪有
