把i2c庫放到 arduino IDE 庫中
打開第二個文件就可以了
2019-3-29 03:36 上傳
全部資料51hei下載地址:
MPU6050_Kalman-master.zip
(2.3 KB, 下載次數(shù): 82)
2019-3-28 10:38 上傳
下載積分: 黑幣 -5
i2cdevlib-master.zip
(725.08 KB, 下載次數(shù): 71)
2019-3-28 10:38 上傳
下載積分: 黑幣 -5
Arduino源程序如下:
- #include "Wire.h"
- #include "I2Cdev.h"
- #include "MPU6050.h"
- MPU6050 accelgyro;
- unsigned long now, lastTime = 0;
- float dt; //微分時間
- int16_t ax, ay, az, gx, gy, gz; //加速度計陀螺儀原始數(shù)據(jù)
- float aax=0, aay=0,aaz=0, agx=0, agy=0, agz=0; //角度變量
- long axo = 0, ayo = 0, azo = 0; //加速度計偏移量
- long gxo = 0, gyo = 0, gzo = 0; //陀螺儀偏移量
- float pi = 3.1415926;
- float AcceRatio = 16384.0; //加速度計比例系數(shù)
- float GyroRatio = 131.0; //陀螺儀比例系數(shù)
- uint8_t n_sample = 8; //加速度計濾波算法采樣個數(shù)
- float aaxs[8] = {0}, aays[8] = {0}, aazs[8] = {0}; //x,y軸采樣隊列
- long aax_sum, aay_sum,aaz_sum; //x,y軸采樣和
- float a_x[10]={0}, a_y[10]={0},a_z[10]={0} ,g_x[10]={0} ,g_y[10]={0},g_z[10]={0}; //加速度計協(xié)方差計算隊列
- float Px=1, Rx, Kx, Sx, Vx, Qx; //x軸卡爾曼變量
- float Py=1, Ry, Ky, Sy, Vy, Qy; //y軸卡爾曼變量
- float Pz=1, Rz, Kz, Sz, Vz, Qz; //z軸卡爾曼變量
- void setup()
- Wire.begin();
- Serial.begin(115200);
- accelgyro.initialize(); //初始化
- unsigned short times = 200; //采樣次數(shù)
- for(int i=0;i<times;i++)
- accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); //讀取六軸原始數(shù)值
- axo += ax; ayo += ay; azo += az; //采樣和
- gxo += gx; gyo += gy; gzo += gz;
- axo /= times; ayo /= times; azo /= times; //計算加速度計偏移
- gxo /= times; gyo /= times; gzo /= times; //計算陀螺儀偏移
- void loop()
- unsigned long now = millis(); //當前時間(ms)
- dt = (now - lastTime) / 1000.0; //微分時間(s)
- lastTime = now; //上一次采樣時間(ms)
- float accx = ax / AcceRatio; //x軸加速度
- float accy = ay / AcceRatio; //y軸加速度
- float accz = az / AcceRatio; //z軸加速度
- aax = atan(accy / accz) * (-180) / pi; //y軸對于z軸的夾角
- aay = atan(accx / accz) * 180 / pi; //x軸對于z軸的夾角
- aaz = atan(accz / accy) * 180 / pi; //z軸對于y軸的夾角
- aax_sum = 0; // 對于加速度計原始數(shù)據(jù)的滑動加權(quán)濾波算法
- aay_sum = 0;
- aaz_sum = 0;
- for(int i=1;i<n_sample;i++)
- aaxs[i-1] = aaxs[i];
- aax_sum += aaxs[i] * i;
- aays[i-1] = aays[i];
- aay_sum += aays[i] * i;
- aazs[i-1] = aazs[i];
- aaz_sum += aazs[i] * i;
- aaxs[n_sample-1] = aax;
- aax_sum += aax * n_sample;
- aax = (aax_sum / (11*n_sample/2.0)) * 9 / 7.0; //角度調(diào)幅至0-90°
- aays[n_sample-1] = aay; //此處應(yīng)用實驗法取得合適的系數(shù)
- aay_sum += aay * n_sample; //本例系數(shù)為9/7
- aay = (aay_sum / (11*n_sample/2.0)) * 9 / 7.0;
- aazs[n_sample-1] = aaz;
- aaz_sum += aaz * n_sample;
- aaz = (aaz_sum / (11*n_sample/2.0)) * 9 / 7.0;
- float gyrox = - (gx-gxo) / GyroRatio * dt; //x軸角速度
- float gyroy = - (gy-gyo) / GyroRatio * dt; //y軸角速度
- float gyroz = - (gz-gzo) / GyroRatio * dt; //z軸角速度
- agx += gyrox; //x軸角速度積分
- agy += gyroy; //x軸角速度積分
- agz += gyroz;
- /* kalman start */
- Sx = 0; Rx = 0;
- Sy = 0; Ry = 0;
- Sz = 0; Rz = 0;
- for(int i=1;i<10;i++)
- { //測量值平均值運算
- a_x[i-1] = a_x[i]; //即加速度平均值
- Sx += a_x[i];
- a_y[i-1] = a_y[i];
- Sy += a_y[i];
- a_z[i-1] = a_z[i];
- Sz += a_z[i];
- a_x[9] = aax;
- Sx += aax;
- Sx /= 10; //x軸加速度平均值
- a_y[9] = aay;
- Sy += aay;
- Sy /= 10; //y軸加速度平均值
- a_z[9] = aaz;
- Sz += aaz;
- Sz /= 10;
- for(int i=0;i<10;i++)
- Rx += sq(a_x[i] - Sx);
- Ry += sq(a_y[i] - Sy);
- Rz += sq(a_z[i] - Sz);
- Rx = Rx / 9; //得到方差
- Ry = Ry / 9;
- Rz = Rz / 9;
- Px = Px + 0.0025; // 0.0025在下面有說明...
- Kx = Px / (Px + Rx); //計算卡爾曼增益
- agx = agx + Kx * (aax - agx); //陀螺儀角度與加速度計速度疊加
- Px = (1 - Kx) * Px; //更新p值
- Py = Py + 0.0025;
- Ky = Py / (Py + Ry);
- agy = agy + Ky * (aay - agy);
- Py = (1 - Ky) * Py;
- Pz = Pz + 0.0025;
- Kz = Pz / (Pz + Rz);
- agz = agz + Kz * (aaz - agz);
- Pz = (1 - Kz) * Pz;
- /* kalman end */
- Serial.print(agx);Serial.print(",");
- Serial.print(agy);Serial.print(",");
- Serial.print(agz);Serial.println();
