沒(méi)有使用DS1302模塊,用定時(shí)器完全實(shí)現(xiàn)了題目要求,發(fā)出來(lái)讓沒(méi)有思路的同學(xué)們參考一下。本人水平有限,如果有不足之處多多指正。
單片機(jī)源程序如下:
- #include "intrins.h"
- #include "STC15F2K60S2.h"
- #include "key.h"
- #include "onewire.h"
- sbit S7 = P3^0;
- sbit S6 = P3^1;
- sbit S5 = P3^2;
- sbit S4 = P3^3;
- unsigned char table[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff,0xbf};
- unsigned char distime = 0;
- unsigned char num0[] = {0,0,17,0,0,17,0,0}; //顯示時(shí)鐘
- unsigned char num1[] = {0,0,17,0,0,17,0,0}; //顯示鬧鐘設(shè)置時(shí)間
- unsigned char num2[] = {16,16,16,16,16,0,0,12}; //顯示溫度
- int shizhong = 0; //用于時(shí)鐘的正確運(yùn)行
- unsigned char time_shi = 0 , time_fen = 0 , time_miao = 0; //時(shí)鐘參數(shù)
- unsigned char time_set_mode = 0; //時(shí)鐘設(shè)置模式,0為不設(shè)置,1為設(shè)置時(shí),2為設(shè)置分,3為設(shè)置秒
- unsigned char alarm_shi = 0 , alarm_fen = 0 , alarm_miao = 0; //鬧鐘參數(shù)
- unsigned char alarm_set_mode = 0; //鬧鐘設(shè)置模式,對(duì)應(yīng)同上
- int alarm_count = 0 ;
- bit alarm_start = 0 , alarm_enough = 0;
- unsigned char temper = 0;
- unsigned char DS_mode = 0; //數(shù)碼管顯示模式,0為時(shí)鐘,1為鬧鐘,2為溫度
- bit flash_start = 0 ;
- bit flash0 = 1 , flash1 = 1;
- bit LED_mode = 0;
- unsigned int LED_count = 0;
- void LED_flash()
- if(LED_mode)
- P2 = (P2 & 0x1f) | 0x80;
- P0 = 0xfe;
- P2 &= 0x1f;
- P0 = 0xff;
- else
- P0 = 0xff;
- P2 &= 0x1f;
- P0 = 0xff;
- if(++LED_count==1000)
- LED_mode = ~(LED_mode);
- void display()
- P2 |= 0xc0;
- P0 = 1<<distime;
- P2 &= ~(0xc0);
- P0 = 0xff;
- switch(DS_mode)
- case 0:
- if(flash0)
- P2 |= 0xe0;
- P0 = table[num0[distime]];
- P2 &= ~(0xe0);
- P0 = 0x00;
- else
- if((distime==(3*(time_set_mode-1)))||(distime==(3*(time_set_mode-1)+1)))
- P2 |= 0xe0;
- P0 = 0xff;
- P2 &= ~(0xe0);
- P0 = 0x00;
- else
- P2 |= 0xe0;
- P2 &= ~(0xe0);
- P0 = 0x00;
- break;
- case 1:
- if(flash1)
- P2 |= 0xe0;
- P0 = table[num1[distime]];
- P2 &= ~(0xe0);
- P0 = 0x00;
- else
- if((distime==(3*(alarm_set_mode-1)))||(distime==(3*(alarm_set_mode-1)+1)))
- P2 |= 0xe0;
- P0 = 0xff;
- P2 &= ~(0xe0);
- P0 = 0x00;
- else
- P2 |= 0xe0;
- P2 &= ~(0xe0);
- P0 = 0x00;
- break;
- case 2:
- P2 |= 0xe0;
- P0 = table[num2[distime]];
- P2 &= ~(0xe0);
- P0 = 0x00;
- break;
- if(++distime==8) distime = 0;
- void Timer0Init() //2ms
- AUXR |= 0x80; //?????1T??
- TMOD &= 0xF0; //???????
- TL0 = 0x40; //??????
- TH0 = 0xA2; //??????
- TF0 = 0; //??TF0??
- TR0 = 1; //???0????
- EA = 1;
- ET0 = 1;
- void timer0() interrupt 1
- if(alarm_start) //L1閃爍(鬧鐘)控制
- if(++alarm_count==2500) //5s
- alarm_count = 0;
- alarm_start = 0;
- alarm_enough = 1;
- if(++shizhong==500) //時(shí)鐘正常計(jì)時(shí)控制,1s
- if(time_miao==59)
- time_miao = 0;
- if(time_fen==59)
- time_fen = 0;
- if(time_shi==23)
- time_shi = 0;
- else
- time_shi++;
- else
- time_fen++;
- else
- time_miao++;
- shizhong = 0;
- if(flash_start)
- if(DS_mode==0)
- flash0 = ~(flash0);
- else
- flash0 = 1;
- if(DS_mode==1)
- flash1 = ~(flash1);
- else
- flash1 = 1;
- display();
- void main()
- P2 = (P2 & 0x1f) | 0xa0;
- P0 = 0;
- P2 &= 0x1f;
- P0 = 0xff;
- P0 = 0xff;
- P2 &= 0x1f;
- P0 = 0x00;
- time_shi = 23;
- time_fen = 59;
- time_miao = 50;
- alarm_shi = 0;
- alarm_fen = 0;
- alarm_miao = 0;
- Timer0Init();
- //////////////////////初始化
- while(1)
- num0[0] = time_shi/10;
- num0[1] = time_shi%10;
- num0[3] = time_fen/10;
- num0[4] = time_fen%10;
- num0[6] = time_miao/10;
- num0[7] = time_miao%10;
- num1[0] = alarm_shi/10;
- num1[1] = alarm_shi%10;
- num1[3] = alarm_fen/10;
- num1[4] = alarm_fen%10;
- num1[6] = alarm_miao/10;
- num1[7] = alarm_miao%10;
- if(S7==0) //時(shí)鐘設(shè)定
- Delay10ms();
- if(S7==0)
- DS_mode = 0;
- alarm_set_mode = 0;
- switch(time_set_mode)
- case 0:
- time_set_mode = 1;
- break;
- case 1:
- time_set_mode = 2;
- break;
- case 2:
- time_set_mode = 3;
- break;
- case 3:
- time_set_mode = 0;
- break;
- default:
- break;
- while(S7==0);
- if(S6==0) //鬧鐘設(shè)定
- Delay10ms();
- if(S6==0)
- DS_mode = 1;
- switch(alarm_set_mode)
- case 0:
- alarm_set_mode = 1;
- break;
- case 1:
- alarm_set_mode = 2;
- break;
- case 2:
- alarm_set_mode = 3;
- break;
- case 3:
- DS_mode = 0;
- break;
- default:
- break;
- while(S6==0);
- if(S5==0) //加
- Delay10ms();
- if(S5==0)
- if(time_set_mode!=0&&alarm_set_mode==0)
- case 1:
- if(time_shi==23)
- time_shi = 0;
- else
- time_shi++;
- break;
- case 2:
- if(time_fen==59)
- time_fen = 0;
- else
- time_fen++;
- break;
- case 3:
- if(time_miao==59)
- time_miao = 0;
- else
- time_miao++;
- break;
- default:
- break;
- if(time_set_mode==0&&alarm_set_mode!=0)
- case 1:
- if(alarm_shi==23)
- alarm_shi = 0;
- else
- alarm_shi++;
- break;
- case 2:
- if(alarm_fen==59)
- alarm_fen = 0;
- else
- alarm_fen++;
- break;
- case 3:
- if(alarm_miao==59)
- alarm_miao = 0;
- else
- alarm_miao++;
- break;
- default:
- break;
- while(S5==0);
- if(S4==0) //減;顯示溫度
- Delay10ms();
- if(S4==0)
- case 1:
- if(time_shi==0)
- time_shi = 23;
- else
- time_shi--;
- break;
- case 2:
- if(time_fen==0)
- time_fen = 59;
- else
- time_fen--;
- break;
- case 3:
- if(time_miao==0)
- time_miao = 59;
- else
- time_miao--;
- break;
- default:
- break;
- case 1:
- if(alarm_shi==0)
- alarm_shi = 23;
- else
- alarm_shi--;
- break;
- case 2:
- if(alarm_fen==0)
- alarm_fen = 59;
- else
- alarm_fen--;
- break;
- case 3:
- if(alarm_miao==0)
- alarm_miao = 59;
- else
- alarm_miao--;
- break;
- default:
- break;
- if(time_set_mode==0&&alarm_set_mode==0)
- temper = temper_read();
- num2[5] = temper/10;
- num2[6] = temper%10;
- DS_mode = 2;
- while(S4==0);
- DS_mode = 0;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
電子鐘(自)2018.zip
(53.58 KB, 下載次數(shù): 30)
2019-3-25 15:43 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
